That turned out very nice, great job!
dusty bedroom
http://img507.imageshack.us/img507/6...2mr7ic4.th.jpg
he couldnt get a thermochill internally even with the graphics coolers removed. the thermochills are 61mm thick. thats almost 2 and a half inches. look at this pic from a rig darth beavis built. its using thermochill 120.3:
http://img264.imageshack.us/my.php?i...00largelp5.jpg
those are big. he could possibly get it on the outside of the case. and then have the one side with fans be on the inside.
delly with what do you chill the water to get 18.5 degrees?
or is it really cold in your room (air conditioner maybe?)?
Before:D
http://img509.imageshack.us/img509/3...bicafs2.th.jpg
And then:shocked:
http://img527.imageshack.us/img527/4...hte1eh6.th.jpg
http://img244.imageshack.us/img244/5...hte2ko3.th.jpg
http://img517.imageshack.us/img517/8...hte5op2.th.jpg
http://img517.imageshack.us/img517/4...hte6zc9.th.jpg
it look a little bit diferent now,but I don't have a camera,and I want to do something with this cables,they are going on my nerves...
I hope you like it...:up:
Shiki, I cant help but play the "Darth Vader" song when I looked at the "after" pic.
it have a little "space" look:D
i saw it in your "galery" in signature,it looks pretty good...Only the the case could be bigger...
Very nice. Though I see no reason to hide the hoses?
Just sleave the whireing :D?
heres mine :D watercool'd Fragbox 2, will be painting the inside of the case and sound proofing it next week;)
http://img510.imageshack.us/img510/8...6437bl8.th.jpg
http://img475.imageshack.us/img475/1...6373lw2.th.jpg
http://img475.imageshack.us/img475/1...6372zy3.th.jpg
Just got a new case + a Scythe Ninja Plus revision B. :)
http://img.photobucket.com/albums/v6...tec9000004.jpg
http://img.photobucket.com/albums/v6...mplete0012.jpg
http://img.photobucket.com/albums/v6...mplete0014.jpg
http://img.photobucket.com/albums/v6...mplete0015.jpg
http://img.photobucket.com/albums/v6...mplete0022.jpg
http://img.photobucket.com/albums/v6...mplete0030.jpg
I'm still deciding on changing the VGA cooler or not.
Damn thats nice with the lights off :D
Thats it. The nine hundred is staying in the shopping cart. Screw the stacker.
I wonder what it 'll look like with the green light from my zalman 9700 nt and the red light light from an optional 120mm side cooler :)
Can't wait untill it's here.
That is correct; there is absolutely no room inside the case to mount the radiator. Instead, I'm mounting the radiator on the back of my case, using a 120x38mm fan shell as a standoff. There is sufficient clearance to connect cables to the sound card, and the radiator does not obstruct the power cord socket.
