Originally Posted by
003
Hey guys... I'm having an issue. I want to set my CPU voltage above 1.6v, but the voltage choices on the Rampage Formula start taking much larger steps once you pass 1.6v, the next one after 1.6 is 1.65, and I don't want that much. Is there anything I can do to get voltages between 1.6 and 1.65?
I did try using 1.65, but for some reason, the board would POST but then give you an error about the CPU voltage being set too high. Umm... wtf, if that is too high then why even include the option for it. And anyway I should be able to use any voltage I want...
Anybody know a way around this?
