the UT adn LT are the same board so it dosnt matter
and dont get teh 7x00 they have 3MB of cash and thats a huge drawback, but there shouldent be any problems except some GKX based ram dosnt do cas 5
Anyone was successfully able to run the g.skill 8500 ram with this mobo at its supposed speed (1066mhz)? If so please share me the bios settings cause I have big trouble actually running this ram.
Between the ram works, I've successfully tested it on my friend pc which had an Asus Rampage Formula mobo and it worked flawless at 1066mhz, so it's not the ram fault but some bios settings on the DFI mobo.
If the X48 DFI is anything like the X38 the standard settings are simpley way too tight for most ram modules. Check memory settings and set them from turbo to normal or maybe fast. Turbo is simply not working with many PC1066 modules out there (including my apogee GT's).
My CellShock D9Gkx runs great on this board with no issues.
i just discovered t2 dispatch. i set it to enable and went from 56ns to 53.4.
finally found something that works lol.
Anyone know any other timing related tweaks that could improve memory performance?
http://img2.putfile.com/thumb/5/14722054743.jpg[/IMG]
u need a bigger screen shot or a cropped with the everst/mem set
if those are double sided balistex try 333/800 with 5-5-5-15 with aggressive on your sub timings and e-a-e-e-e/e-a-a-e-e for your phases, and u will need like 2.15V ram and 1.5-1.55V NB
and set your performance lvl so its the same on both banks (8 or7) and set the same for mhc latency
yeah i know its abit slow.
two are single sided two are dble sided.cant get dble sided anymore they dont make em.:down:
ive tried a few other settings but lost stability. ill try phases like u suggest ,thanks .
i set mhc and performance level to 8 and lost stability ,so i took out the 2x 1gb single sided modules.
ill see how i go with 2 gb of dlbe sided instead of 4 gb with mixed types. i did get 52 ns with 2gb of dble sided as oposed to 53.4 with 4gb mixed.
i think crusial lied to me when they said single sided modules perform better than the older doulble sided, thats why they dont make them anymore.
seems like there either wrong or lieing.
yep , its alot more stable now that i took the single sided modules out. no more c1 errors etc.
it is a shame because its almost impossible to get double sided modules now. ill have to use my crucials for boomarang practice and just buy some new sets. was thinking mushkins or gskill.
mushkin and gskill have no revD microns, u have to go team or cell shock or year old modules that are hard to find
or risk tank guys and get the gmh 1000mhz team thats back in stock
http://www.tankguys.com/product_info...oducts_id=1809
or some cell shock
http://www.memoryc.com/computermemor...c28000cl5.html
ignore those ur OZ sorry
thats what i use, but the 667 rated ones
and they come with a spreader unless u ask for no spreader
Hey , Guys just wanted to stop in and say Hi:welcome:
How are all you fellas doing? Praz , emoaners , etc;)http://i259.photobucket.com/albums/h...ot_fun-1-1.gif
are u the GIF master now
Why you opposed to a little color to Brighten you're Day?:)
Anybody can share its bios settings for a stable OC a 8x450mhz 24/7 usage (I have the Q9450 cpu), if this aint work I will consider 8x425 or 8x400 solutions, I really care on stability, thanks in advance.
I'm thinking about getting the UT version of this board...... But I seen alot of post about G-Skills memory. I have the DDR2-800, will it give me any problems :confused:
