Really? Or is that sarcasm?
No man the answer really is YES:D As long as its socket 775 which it is then YES>>>>>>>>:)
Flashed back to official Bios this one is wound up too tight for me to explore as of yet and I have not even gotten a handle on my Overclock yet with previous Bios to even consider starting over.
Hey man I don't mislead people and make them buy stuff just to be a :banana::banana::banana::banana:@:D
That would just be rotten and :banana::banana::banana::banana:ty
New Beta Bios 10/19/2007 on DFI Beta Site:D http://www.dfi.com.tw/Support/Downlo...FLAG=B&SITE=US
Well that was quick it was up and now its gone!
Hey man, not trying to mislead anyone, just what I heard... From here: Want quad-core? Get the G0 X3210
I was referring to what you asked if I was sarcastic and my reply is I don't mislead people to buy stuff that does not work.
Actually the Bios has changed with Ram Values but like I said as much as I would like to use it does not seem logical to complicate the matter/
10/19/07 Beta is up again....just weird!
Just Flashed it Myself heheh::D
OK.......Now I see Improvement in Memory Bandwidth at Same O.C:D Big Daddy very Happy Now:hump:
Whats up JimmyZ:)
@ Oskar Wu.....Please could You Fix the NO Post Screen when Onboard Raid or Dedicated Raid Controller is in Use? Its Like Having a Mercedes Benz with the Frigging Hood Ornament Gone:D
Brother do you mean DIMM1 Clock Fine Delay - Current[14] & DIMM3 Clock Fine Delay - Current[13] have changed to 13 & 12 ?
I will look into this later when I get home & let you know what mine is doing.Code:Ch1 Clock Crossing Setting......... - More Aggressive
DIMM1 Clock Fine Delay............. - Current[14]
DIMM2 Clock Fine Delay............. - Current[5]
Ch1 ControlFine Delay.............. - Current[9]
Ch1 ControlFine Delay.............. - Current[4]
Ch2 Clock Crossing Setting......... - More Aggressive
DIMM3 Clock Fine Delay............. - Current[13]
DIMM4 Clock Fine Delay............. - Current[4]
Ch2 ControlFine Delay.............. - Current[10]
Ch2 ControlFine Delay.............. - Current[4]
I played a couple of hours of Airborne last night on the 1005 BIOS so its not game unstable.
If your Prime blend failed @ 23 minutes it would have been on the 8k FFT test which is a small CPU cache test, this doesn’t point at the RAM settings to me are you sure your voltages were ok.
CN :)
Hey, Craig....On 10/05/07 Beta Yes:) This one I don't know as of yet have not checked because with Raid Controller Card with Staggered spin up on it takes about 54 seconds in addition to normal boot process. Too impatient to start Priming to go through the extra 2 cycles of all that:D
Just to let you know all of the Values had changed in Fine clock delay on 10/05/07 Not just the top two but I could not remember what the others were in comparison!
You know what I'm Saying......... Right my Brother?:D
Me thinks,,,,, we are looking at "New Official Monster Bios" release for Mischief Night / Halloween :shock2:
Is 913 Bios support correctly QX9650 ?
