Originally Posted by
Bluesign
They finally let me in... Thank you!
I've read the most part of this thread and... it's only me or the P35-DQ6 is not such a great board after all? I think it is about time to draw a conclusion. I've been using this board (rev.1.0) for a month now and I must say that I am pretty satisfied with it, though there is a minor glitch that I'd like to mention. Therefore, I overclocked my E6750 to 3GHz and everything was rock stable. Then I tried 3.2GHz and it was also rock stable though the temps were pretty high. BUT... after reverting to the default settings (333x8) and overclocking again after a few days, I noticed that I can't adjust the FSB in 1MHz increments anymore (except the 333 default value), only in 2MHz increments. I mean even if it shows 375 in BIOS, for instance, it is in fact 374 during POST or as CPUZ shows, 377 is 376 and so on. This may not be such a big problem but it is nevertheless annoying and I wonder if there is a way to fix it. I tried pretty much everything, from resetting the BIOS to fail-safe defaults to rewritting the BIOS and even reinstalling my OS and still nothing. So I think there is no place better than this to get any more suggestions on how to fix this. And I mean really... If you, guys can't help me, I'll probably give up and forget about it. However, if this is something common with these boards and you have experienced the same weird behavior, then please let me know and I'll probably feel better. Oh... and could you post a link for the F6 bios for DQ6? I'd like to give it a try. Thank you!
