kyosen: Do you know what week they began producing stepping 8?Quote:
this is the max with multi 12 :(
I think i bought a T2600 with stepping 8
http://people.freenet.de/chris070719.../SuperPi-4.jpg
Wrong :D See your CPU-Z screenie ;)Quote:
Originally Posted by Chri$ch
Is 253 your max fsb or you meant your maximum cpu frequency?
ups, sry ;)
i meant that i will buy a cpu with stepping 8
~3Ghz is max frequency
yes....Quote:
Same idea here , only exception seems to be hicookie
who only gained liiiiitle, when he changed the cpu from 4 to 8 :-)
his step 8 performd worse ;)
@ crotale.. step 8 is from week 42. (qhkh ES)
@ Chri$ch why arent you running x13?
I think he was trying to show the max fsb, you can change multi with christy cpuid.Quote:
Originally Posted by Waus-mod
even if i go to x7 ;) i still have that !#$! 236fsbQuote:
Originally Posted by wwwww
Same as me, got my motherboard yesterday.Quote:
I test a stepping:4 T2500 ES and a stepping:8 T2600 ES last night.
The T2500 can 1.42v 227x12 pass dual 32m pi and dual sp2004, But hard to go more.
The T2600 can 1.435v 233x13 pass dual 32m pi, 1.485v 240x13 pass dual 32m pi.
Bios is 03/23/2006, All adjust in bios, I do not use remote and software.
Seem this chip 3.1G is maximum stable frequency under air cool,
I will try watercool later :fact:
Btw: I found a shortcoming in this motherboard, If the FSB ove 230, when i save the bios, It can't automatism reset, I must turn off the power , wait a second and turn on it.
Can someone please find the VCCA mod... so i can try?
I thought it definately wasn't VCCA ;)Quote:
:D
:DQuote:
share with us :P
hi guys
i haven't an es chip can i join this competition too?:D
after easter i'll get mobo and cpu probably a step 8:D
but that fsb limitation is very bad :(
not every one has been fsb pentrated by the board or cpuQuote:
Originally Posted by Fabius88
so good luck :D
I have 15XT2600 QKHK Stepping 8. Maybe I need to choose one to test.
:D i'll wait and hope......:p:Quote:
Originally Posted by ibby
Week 07 should be ok then :cool:Quote:
Originally Posted by crotale
how do i figure out what week is my t2300 processors are ?
lol, its just that when I said to Waus that I thought increasing VCCA would help the wall, he said it wasn't VCCA and was mobo rev ;)Quote:
:D :woot:Quote:
By New Beetle
(Set up)
M/B:AOpen i975Xa-YDG Vmod / BIOS:R1.02
M/B Bed:「V-TEC ARC Bed Rev.3.3」
CPU:Core Duo T2600 / QHJJ ES 7530A497
CPU Cooling:「Kuri Pro2」+ DICE
Chipset Cooling:Normal
Memory:CORSAIR 5400C4 512MB x2 / CL4-3-2-8
VGA:ATI XPERT 98 PCI 8MB
HDD:IBM-DTLA-307030 / U-DMA 5 (ATA100)
PowerSuplly:Zippy-460WS #2 (3.3V Rail Mod)
Vcore:1.65V/ Vddr:2.25V/ Vio:3.44V
OS:Windows Server 2003
Remarks:DICE Cooling / FSB240MHz Boot / Graphite sheet
modPI 1.5 XS 8M: 3m23.219s @3408.3MHz (FSB262.2MHz x 13)
http://premium1.uploadit.org/fredyam...New-Beetle.png
that's sick! qhjj reach 3.4G+
Looks like you must have missed his previos 1M result:DQuote:
Originally Posted by hicookie
http://www.xtremesystems.org/forums/...postcount=1328
shoule i burn my es chip or mobo? now i have really not thing to do.....had the misfortune, worst experience with yonah...:(Quote:
Originally Posted by PRTeamJapan
