Thanks very much! I'll try as soon as i can!
ok i have send all user pm those post wrongly wrote (...not correctly write the update post...)
its a lot of work for EnJoY to change all post...and searching for the right numbers...help him and change you post to the right format, plz.
-> look here:
TH€_BR@!N | 2x1GB OCZ PC4000EB Platinum - Infineon CE-6 | 3-3-2-8 1T @ 285MHz | 3.0v | Link! - SPi 32M Stable: Yes
with Athlon 64 ( or Athlon XP, Pentium 4, Pentium M...)
thx for your understanding
This is the max i can do for now :D
Cordovader[CST] | 2x1gb Crucial Ballistix PC4000 - Micron 5B D | 3-3-3-8 1T@ 311mhz | 2,83v | Link - SPi 32M Stable: Yes
http://img236.imageshack.us/img236/6...ello7rl.th.jpg
http://www.xtremesystems.org/forums/...ad.php?t=88647
^^ this is a grat rekord 311mhz, extreme....you want sell your ram?
perfekt!! and thx :banana:Quote:
Originally Posted by Kunaak
Originally Posted by Rukee
perfectly and thx :toast:
Hi dear.....I changed the link on page 52.....sorry but I have not the CPU-Z verification......:mad:Quote:
Originally Posted by TH€_BR@!N
Thnx for your job !
have you the latest version of cpu-z? 1,32...Quote:
Originally Posted by lobotronic
here is the link to manual upload the id file
http://valid.x86-secret.com/
What drive/data are you all using for your ballistix? I can't seem to get mine stable at 280 :confused: I narrowed it down to 2 errors in Test 5 on Memtest.. lol (with auto drive/data, Weak Something / Lvl 1 <- says everest)
I put eveything on auto and got up to 295.
First, I would always test each stick individually. Remember, you will always be limited to the weakest one.
Is this post OK ??, it seems to have been overlooked, I sent a PM too :) http://www.xtremesystems.org/forums/...postcount=1294
Originally Posted by alpha0ne
yes this is very good :)
thx
Hi!Quote:
Originally Posted by Cordovader
I have tried lot of settings to get my Ballistix stable with no much luck...
Your setting is very similar to my best one, so i have some question!
1) What Drive & Data Strenght you set? If i leave it to Auto, the Bios set something Weak but very unstable...my best so far is 7 (Drive) / 4 (Data)
2) What Voltage you set IN BIOS? I have seen MBM report 2.83, but the real one in BIOS?
3) My mobo is the DFI Expert 12/07/2005 Bios...by the way i have seen that the great majority of Ballistix user's have ALL FOUR MEM CLK ENABLED (---> see A64 Tweaker!) but mine show that only Mem Clk 0/1 are enabled...maybe is this related to my Expert mobo?
Thanks for the replies! :)
yes, this is great. thx :toast:Quote:
LOL, just figured out that one of my sticks of ballistix won't game over ~130MHz, despite being stable in superpi/prime/memtest all day at 270MHz+. The other stick games no problem at least at 250 (the :banana::banana::banana::banana: one failed at 200 in Far Cry Volcano).
Since I'll be sending them both back, I decided to crank up the volts and go for some nice pi runs, but they won't even do 300MHz with 3v :( I was hoping for like 305MHz. So I decided to go for some suicide screenshots, managed 323.9MHz with 3.2v. It wouldn't even boot at 325, I used 320 and then clockgen to set it. I had 326.2 going and almost saved it but it froze :Mad:
http://img485.imageshack.us/img485/1...tled2xl.th.jpg
Drive & data strenght were set to auto in bios and the voltage was 2,8+0,03v. Not tested yet the ballistix on my expert so i can´t tell you ;)Quote:
Originally Posted by OTT
i have kick ass my ram to a new privat record :banana:
290Mhz -> now testing
http://img300.imageshack.us/img300/2...hbrn4pi.th.jpg
That 3D stable too?
prime runs and runs...... i have rock the 287mhz i think.
3d games i dont test, but comes...
287mhz * the timming is low but if it stable i will test it high
http://img466.imageshack.us/img466/2...hbrn7kv.th.jpg
TheMeatFrog | 2x1gb Crucial Ballistix PC4000 - Micron 5B D | 3-3-3-8 1T@ 306mhz | 3.08v | Link - SPi 32M Stable: Yes
http://img122.imageshack.us/img122/2...3v035jv.th.png
Validation: http://valid.x86-secret.com/show_oc?id=71462
Would be nice to see some ram competing with ballistix up near the top, it is dominating. I decided to shy away from it because of the latest problems. Playing with some G.Skill HZ which seems to be pretty popular.
