ooo tommy, where are those hr-05-ifx's available from?
I bought it from PC-Cooling.de ;)
@Tommy_Hewitt: AWESOME Thermalright setup mate! ;) Planning to do the same. :)
I wonder, would it matter if the 120mm fan on the Ultra-120Ex be on the other side (blowing heat AWAY from the HS) than TOWARDS the HS? & would you recommend putting a fan on the HR-07s?
Thanks! :)
Hehe, thank you :D
I think it wont matter if you put the fan on the other side. And on the HR-07 you dont need a fan
I first made an incision with a dremmel to hide some of the cables like the 24 pin and some other ones. I removed the two 90mm fans since they were kind of useless and I mounted a 120mm to the top instead via tie wraps. I also took the plastic cover off which reduced airflow a ton. Added 2 icages + 2 TT 1225 Led 120mm fans to the front. My idle temps @ 3.5ghz~1.43v (E6420) are Core0: 22C, Core1: 25C according to Core Temp. The added fans dropped temps about 3 or 4 degrees Celsius.
It's been done with two M3 threaded bolts and wing nuts. The TR SKU-800 weights about 900 grams and that's nothing for an X850XT and two M3 bolts. Temperatures were very close to ones i got with watercooling, even on an voltmoded card @ 1.65Vgpu at 650MHz (sucky overclocking gfx, i know)
BEFORE:
http://i6.photobucket.com/albums/y218/gw4k/a1.jpg
My Striker Extreme died = RMAd, then my P5n32E-SLI I bought arrived DOA = RMAd, so I am mixing parts between 2 PCS.
NOW:
http://i6.photobucket.com/albums/y218/gw4k/2x2900.jpg
QX6700
P5k Deluxe Wifi
2x ATI RADEON 2900XT
Enermax Galaxy 1000w
4x 1GB OCZ 8500 Reaper
why don't you drill outtake holes on the top of your case and change all the other fans (front and rear) to bring cool air in.
or if you are too lazy :) try the same without drilling holes, but instead put an outtake fan on the front - top at 5.25' place
Very l33t sexy machine m8 :up:
Love the Colour Contrast, red and black...
Though I'm a Nvidia fanboy (well sort of, I like them :p: ) I loved teh 2 ATI Crossfire.
Red Cable Sleeving would PWN!
Now for my (modest... LOL) setup.
Below Zalman without stock fan (only pic I have atm), lost teh LED and modded one Noiseblocker XE2 following an howto here in XS
http://img262.imageshack.us/img262/1770/001kr9.jpg
http://img262.imageshack.us/img262/6779/014vn3bn9.jpg
Keep it closed in my Extremengine 3T so not much to see in teh end... LOL
http://img508.imageshack.us/img508/9...0resizeua2.jpg
Changed teh rig after that and got a vf900 on my 7900. Waiting for teh perfect case to come along (have a crush on TT Armor :D )...
Behave!
Thermalright hr-05 SLi IFX chipset cooler:
http://i172.photobucket.com/albums/w...X/DSCN1340.jpg
http://i172.photobucket.com/albums/w...X/DSCN1341.jpg
http://i172.photobucket.com/albums/w...X/DSCN1342.jpg
Greetz,
Techie
Shame they didn't make the stock cooler out of copper.. like x1950xtx. :p:
100% OC by Defaults & Autos, on AIR by Gigabyte P35C-DS3R !!!
You intentionally put double chunk cookies in that picture to make me hungry.
Updated My Air Cooled Rig..
Poo Or Not... Updated the BIOS and the temp is reading higher but no load is still 25 Deg C.
Spent the day adjusting the computer for a new CPU and a much longer GPU.. 8800GTX OC2
Each Front Fan is Variable.
All HDD are reversed.
Southbrige Cooler Clocked to make room..
I love how clean it is and the third fan makes the front look..
http://www.msprotege.com/members/Bri...%20-%20(1).jpg
http://www.msprotege.com/members/Bri...%20-%20(2).jpg
http://www.msprotege.com/members/Bri...%20-%20(3).jpg
http://www.msprotege.com/members/Bri...%20-%20(4).jpg
http://www.msprotege.com/members/Bri...%20-%20(5).jpg
http://www.msprotege.com/members/Bri...%20-%20(6).jpg
http://www.msprotege.com/members/Bri...%20-%20(7).jpg
http://www.msprotege.com/members/Bri...%20-%20(8).jpg
http://www.msprotege.com/members/Bri...%20-%20(9).jpg
Looks awesome Brian, very nice. But... no optical drive? External maybe? :confused:
I must say brian, very nice, love the colors that its putting out in the dark, what color CFL's are you using?
