My base setup for highest multi test
Its probly universal on most any hardware combo, mine are UD7, corsair A50 push/pull
UD7 bios
1.54Vcore / LLC 10 / PLL enabled / 2 cores / HT off
CPU temp. warning set @ 80C
http://img200.imageshack.us/img200/6...nshot002ex.jpg
54X is the max it can boot to windows (XP32)
55X can but freeez after few seconds, 56X stop @ windows bars
Based on this, its worth the time to put SS cooling on it. With the same bios settings this cpu maxed @ 5.69Ghz
http://img857.imageshack.us/img857/3...nshot002oe.jpg
