well done! but a bit too toasty for me!
Merry xmas to all in this thread, especially zalbard. This has been by far my favorite thread of the year. Here's to the 5ghz sandybridge club in 2011!
zalbard why my result is not on the main page?
http://www.xtremesystems.org/forums/...postcount=1330
You have to be patient. zalbard will add your entry.
yes, fantastic thread. big thanks to zalbard and everyone else for making it interesting. im a novice to these things but i have learnt alot here... now. who can help me get past 226 bclk cos i need top 10 with my 920. its got so much head room. but board is holding me back :(
Marry Christmas to all! Thanks for making this thread going!
I was out of the town for a few days (Christmas). Merry belated Xmas, guys! :)
Sorry about the delay, the updates are following shortly. :yepp:
Perhaps because you do not spend enough time reading the OP.
(Update: 14 Dec, 2010) Please make sure that LinX is running / calculating (20th+ loop) when you're taking your screenshot (on at least one of your screenshots). You obviously want a CPU-Z window with 4.5GHz+ frequency on the same screenshot, as well.
"(Update: 14 Dec, 2010) Please make sure that LinX is running / calculating (20th+ loop) when you're taking your screenshot (on at least one of your screenshots). You obviously want a CPU-Z window with 4.5GHz+ frequency on the same screenshot, as well.
This rule will be enforced for all the new submissions."
Just noticed im missing a motherboard entry in the i3 list - same Gigabyte P55-UD5 for all my 1156 chips :).
Trying my 950 for more in the shed at the moment. -6c air - its freezing in here :lol:. 4881mhz just failed on loop 17 - so close it hurts!
[EDIT - Nope, failed :(. Dont think its gonna happen with the 470's in. Will have to retry at a later date with the 8400gs instead. Means splitting my loop up though so may be a little while...]
The requirements include the batch number and CPU-Z SS. Surely that means you need to have a model uncovered as well since you aren't suppose to tamper with the SS. Probably why he hasn't been added to the list.
Curious, NDA?
:edit: just noticed the quotes above from others about running the 20th+ loop in a ss
Put me on the first page thank you very much ! :) ON H2O
When i raise my vIOH my gflops drops is that normal ? Best is on 1.11 !
http://img80.imageshack.us/img80/3976/beststabiel.jpg
Nice clock Ace, but too bad TS requires the SS to be taken during the 20+ loops active running.
This will do as an exception... Small note for everyone... Screenshot with LinX running 20th+ loop... And 19 < 20, obviously. So you need to have LinX finish 20 passes and keep working and after that you take a screenshot. I thought my explanation in the OP was clear enough, guess not...
H20
Rampage III Extreme
New submision following rules >_<
First page now ?
Tnx :)
http://img832.imageshack.us/img832/3687/21x215.jpg
Good run. Have you tried lowering CPU PLL to 1.44-1.50? It may allow you to lower your vcore. I was able to get my LinX 20 runs 4.5Ghz vcore down to 1.385v after dropping CPU PLL to 1.44v on my R3E. I am now working on LinX 20 runs 4.5Ghz 4c8t which I can only pass 17 runs so far. Driving me nuts!
Tnx deachus.
Anything lower then 1.81 CPU PLL i crash within 10 runns, so no go there for me..
Bios 0095 did it for me, all the earlier bios i could not get BCLK 215 stable.. 0095 best bios for me so far !!
Good luck on your 4C8T run ! Try bios 0095 !
Did you try going just below 1.81 CPU PLL or all the way down to 1.44v? I only ask because 1.65v-1.8v did nothing for me but 1.44v-1.5v helped and allowed me to lower vcore. Thanks, I have been on 0095 for a few weeks now, someone sent it to me and it is the best bios I have used so far. I see R3E bios 1206 dated 12/20/10 floating around (post in the R3E thread) which I would love to try out.
Gonna try a few runns starting from 1.31 CPU PLL right now.. i remember i had uncore alot higher before and on different bios.. maybe i can pull it off :)
0095 :up:
Seen 1206 too.. cant wait
Edit: No go on the CPU PLL tried from 1.31 all the way up to 1.61... keep crasching within 10 runns
I had to change my ram timings from 6-8-6-20-1T-72 to 7-7-7-21-1T-72 and uncore from 36** to 38** then dropping CPU PLL made a difference. Think I was too tight so it needed the higher CPU PLL which the theory is CPU PLL is tied to QPI PLL which would make sense.
