nice pics urealer
nice pics urealer
So how does that 180mm shroud mount? I don't see any screw holes.
between the metal part and the acrylic there are a little space for the screw, so you will need a screw as long as the fan thickness + the shroud thickness.
regards!
between aluminum and plastic frame has space for the screw
http://www.abload.de/img/sam_105277kc.jpg
This one:
VGA Supreme HF Plexi
http://www.ekwaterblocks.com/shop/bl...-hf-plexi.html
http://www.abload.de/img/img_2794a76z.jpg
http://www.abload.de/img/img_2796376r.jpg
http://www.abload.de/img/img_2808o77k.jpg
http://www.abload.de/img/img_281097m0.jpg
http://www.abload.de/img/img_2824r7nf.jpg
http://www.abload.de/thumb/img_2760r757.jpg http://www.abload.de/thumb/img_2763m7pd.jpg http://www.abload.de/thumb/img_2766q75s.jpg http://www.abload.de/thumb/img_2768p7w6.jpg http://www.abload.de/thumb/img_2776z70k.jpg
http://www.abload.de/thumb/img_276907uf.jpg http://www.abload.de/thumb/img_277447bo.jpg http://www.abload.de/thumb/img_2829x7jl.jpg http://www.abload.de/thumb/img_2820sr1d.jpg http://www.abload.de/thumb/img_2818xpte.jpg
New Phobya 180mm shround
http://www.abload.de/img/sam_11419u65.jpg
http://www.abload.de/img/img_0188ud7b.jpg
http://www.abload.de/img/img_01872d5m.jpg
http://www.abload.de/img/img_02614dik.jpg
http://www.abload.de/img/img_27301clu.jpg
http://www.abload.de/img/img_1776md24.jpg
http://www.abload.de/img/img_2721qea8.jpg
http://www.abload.de/img/img_27232d35.jpg
http://www.abload.de/img/img_362474nc.jpg
http://www.abload.de/img/img_3551j4ar.jpg
http://www.abload.de/img/img_3609s6py.jpg
http://www.abload.de/img/img_3618m25r.jpg
http://www.abload.de/img/img_3621m1i9.jpg
http://www.abload.de/img/img_28593uiy.jpg
Old times Bundy :)
The John Long Silver of all Radiators :D
http://www.abload.de/img/img_2946u78u.jpg
http://www.abload.de/img/img_2948ifee.jpg
http://www.abload.de/img/img_29525dpu.jpg
http://www.abload.de/img/img_2939ycjz.jpg
wow bundy.... build a human sized robot with those? :D
Bundy, i think your fittings are worth more than my truck. seriously.
