Don't bother with repair, once cracking begins, it won't stop.
Thinking about how to acquire a great many of the failed ones, shouldn't cost much, just shipping.
Maybe mod a special computer case out of them for illustrative purpose's:rofl:
Well my T3 is almost 4 months old so far no cracking, I guess you could call that a Success Story LOL
I just hope it stays that way until the New Delrin T3's come out because I will buy one as soon as they are out.
No offense to PrimoChill, but they'll probably blame us.
Replacing all that hardware could cost them a fortune (not sure how much was lost). They'll probably say they are not responsible, because we handled the T3 improperly (screws too tight, etc).
I've posted a few times here about mine. Must of got lost in the mix of all the T3 threads. ;)
Mine is still running fine, I got one of the yellow band ones and that was replaced as soon as the clear bond ones came out on an RMA.
I'll be replacing it though, as I prefer not to take the chance. If BG gets the delrin version out, I will probably get that, If not I was looking at EK's dual D5 top as a possibility. :D
Well, it is something like one. They mount into the drive bays and you can mount a tube res to it. It's not the samething, but close enough. ;)
If you really want a dual bay res, and don't want to take the chance, or wish to wait on the delrin T3, the XSPC is going to be your best bet.
You will have to change over to DDCs though.
Mine has been purring along for several months now (I don't recall how long). The only problem I have had was with those crappy nylon fittings. ALL of them eventually broke. Fortunately my res is on the bottom of the case so nothing was harmed by the gushing water.
I still have no cracks, no crazes, no problems.:)
Glad to see people are not having problems.
Just pulled out my 4th T3 due to leaking from pump bracket.
The T3 was cracking again at the screw holes for the pump bracket.
They were not overtighened and still cannot get Brian at primochill.
All have leaked at this point and all 4 are sitting gathering dust.
I have ordered a XSPC-750-BPUMP as a standby until this is sorted.
I either want my money back or some sort of compensation.
It seems that once it cracks , no matter how small, they just spread out like wildfire until it leaks.
Primochill SORT IT OUT!!!!!!!!!!!!!!!!!!!!!
This cracking plague everyone is getting is awful :(
It really needs to be sorted out ASAP by Primochill.
My 8-port in my testbed has never been mounted in a case (it's velcro'd to a flat surface) and the mounting holes are starting to crack as well (:wth:). I'm upgrading my testbed again in the next month, so I guess it's time to put a new res on the list as well :fact:
It must use the worst grade of acrylic possible.
The XSPC res I have ordered is cheaper than the T3 and it has a pump built into the res.
I know it's not great but at least I will be using my PC with confidence again.
I have invested over £200 in this res with the cost of res, pump, faceplate and 1 replacement and after 6 months it has all come down to me replacing it all with the XSPC res+pump setup I threw out at the start.
Irony has a funny meaning for me at this point.
Mine broke from the start...
Got a replacement with plastic screws and no metal inserts.
I think its ok ... this morning I found a drop... I need to check it out - no cracks though.
