Seriously? I only peek at this thread from time to time because I haven't been able to tweak my board settings.
Is this for all boards and all BIOS versions?
Sorry to repeat the question...
I would like to know if CPU and VTT PWM frequency make any difference at all in overclocking. The only diffence i got was 3-4 C more on my PWM and 1-2 C more on Cpu when i changed from default to max values. Otherwise the vtt volt and vcore was exactly the same to pass linx. Any info on this?
Have a question, just picked up the 759. Can I run 2x 295 in SLI using the 1st and 3rd slots?
2nd 295 arrived I installed in 3rd slot, attached sli cable and started rig. It gets to desktop runs for a minute or so gives 4 quick beeps and shutsdown and restarts. Put card in second slot and same thing. Took out my card installed 2nd card in First slot and 4 beeps and shutdown. Put my card back in and system runs fine .
2nd card or psu to consider faulty.
Does your first card work in slot 2/3?
Will increasing the PCIe bus speed have an affect on PCI cards? I can swap my soundcard over to a PCI one if needed.
Okay, I assume beeps are coming from your classified. :D
According to the following website it's a RAM?! error...
http://en.kioskea.net/contents/pc/bios.php3
Did you already try slots 2-4 in combination w/out slot 1? It's weird problem indeed... if PSU-related, try to use other pcie connectors (maybe from another rail).
Some people say, it could hurt your vid cards, but I cannot imagine it does. It has an effect on NIC, USB and some other on- or offboard devices (such as raid cards). Be careful an do some stresstesting. You WILL notice, if some of the devices die. :D
Looks like a XP 64 problem. I installed Win7 64 and Running both cards in slots 1-3 with SLI enabled no problem so far.
True, more then 2 gpu cores = vista/win7 only.
Thanks guys. Do you know if there is a way to use the HDMI output in SLI config?
lol... problem solved. Weird acting of winxp 64 though. I thought it would just deny to support more than 2 gpus, but work nevertheless... :shrug:
Hmm... i just measured again to make sure about DIMM Voltage...
In Eleet say 1.67v, i have it set in BIOS 1.65v, and measuring with voltimeter gives me 1.634v. All in IDLE.
Under load, ELEET show 1.66v and with voltimeter 1.62v.
I have an X58 Classified E759.
http://img687.imageshack.us/img687/7158/19172.png
Forget the voltage, i'm really drunk last night jajajajaj.
PD: i can't pass 223 bclk stable for superpi , that's sad because this chip requires very low voltage to get high frecuency.
Hi.
I try with 101mhz to 115mhz and nothing.
I have the same problem and also tried 101mhz to 115mhz. Maybe is the heat because I'm in Brazil and its hot as hell this days.
I just ordered an EK Classified full block!
I'll receive it later next week, hopefully with my Silverstone ZM1200M PSU and then I'll overclock the hell out of my 950 !!!
Hello.
My overclock is a 30Cē Ambient temperature :eek:
I'm only 2 hours with her and managed to get blck 230, motherboard 230 blck booting in 106 pci Express
I think I sold the motherboard Shamino :D
http://www.pctunerup.com/up/results/...IED230BLCK.jpg
