http://valid.canardpc.com/show_oc.php?id=512180
4.4@air:D 1.5X VCore (1,52-1,57.... can't remember)
CACVC AC 0850 CPMW
CACVC AC 0850 CPMW
Not really Xtreme but thought I would post that my first real OC of my PII (multi's only) and with stock (Auto) volts achieved:
NB @ 2000
CPU @ 3400
CPU volts = 1.342 at idle 1.328v at 100% load - Folding 24/7
Temps : CPU=50c (load) NB=43c SB=40c
i found an ES stepping 2 945BE :D
http://valid.canardpc.com/show_oc.php?id=512373
cooler was a mugen(1), no idea about indoor temp, window was open and outside was between 0 and +5°C , 1.55V
PRIME:
SUICIDE & SUPERPI1MQuote:
CPU Model Used: Phenom II 920
CPU Full Stepping: CACVCAC0849BPEW
CPU Frequency: 3700 Mhz
CPU Vcore: 1,58V
NB Frequency: 2664Mhz
HT Link Frequency: 1776Mhz
Memory Frequency: 592Mhz
Memory Configuration (2x1gb, 2x2gb, etc) 2 x 1gb
Memory Ganged/Unganged: Unganged
Mainboard Model: M3A32-MVP
Cooling Type: Water
Windows Version and x86 or x64: Win XP64 Professional
http://www.abload.de/img/3700fertig4zdy.jpg
CPU Frequency: 4038 Mhz
CPU Vcore: 1,552V
NB Frequency: 2907Mhz
HT Link Frequency: 2907Mhz
Memory Frequency: 646Mhz
Cooling Type: Water
Windows Version and x86 or x64: Win XP32 Professional
http://www.abload.de/img/superpi4fertigjfiq.jpg
Good job there tech, keep us updated with your results.
omg, i waiting always on x4 945 (in May?) and can only watch at this impressive results...
new clock. please update.
i put a fan on the NB to reduce ambient case air. 3.82GHZ:
http://img128.imageshack.us/img128/7...phenomii3w.jpg
http://img128.imageshack.us/img128/4...lphenomii3.jpg
I'm currently at a 3.6GHz wall. My chip HATES the heat - Once it gets above 52* I instantly get a BSOD, no matter how much voltage (less seems to be more stable since its cooler) I purchased a nice 220CFM Delta fan and a lap kit, lets see if it makes any difference. Does anyone else have a solution, other than spending $200 on water cooling?
have you tried replacing the chip with a different one? you could go and get the Thermal Take V10 cooler with its built in TEC.
Couldnt validate this due to my registry being borked but....if the registry wasn't borked it would have saved.
http://members.cox.net/bostonreefer3/5150.JPG
and to show that it was more than capable of being validated.....
http://members.cox.net/bostonreefer3/PI%201m.JPG
The coolermaster v10? No, I'm not spending $150 on a cooler when I can wait for the Xigmatek Thor's Hammer (S126384) for half the cost and still get better results.
http://benchmarkreviews.com/index.ph...1&limitstart=8
Nice OC Chew*. Had a feeling we would be seeing a top notch OC from ya this weekend :up:
CPU Model Used: 940 BE
CPU Full Stepping: unknown
CPU Frequency: 3600MHz
CPU Vcore: 1.36v
NB Frequency: 2000MHz
HT Link Frequency: 1800MHz
Memory Frequency: 533MHz
Memory Configuration: 2x2GB
Mainboard Model: DFI LP DK 790FXB-M2RSH
Cooling Type: Air (CoolerMaster V8)
Windows XP Pro SP2 32-bit
2+ hour Prime95 completed: http://www.rigshowcase.com/pic.php?u=549QkpsX&i=14515
CPU-Z validation: http://valid.canardpc.com/show_oc.php?id=514142
we will see shortly the chip is on its way to me. along with another stepping one. the guy wo had the stepping 2 before me was running 4.5ghz on cheap waterQuote:
Originally Posted by Dumo
First post all, here's my specs: Best boots I could get in Windows Vista stable and suicide run. I run 24/7 at the stable setup. :)
Verification on stable: http://valid.canardpc.com/show_oc.php?id=514176
Stable Screenshot:
http://img291.imageshack.us/img291/7...suicide.th.jpg
Suicide Screenshot:
http://img291.imageshack.us/img291/4...zstable.th.jpg
CPU Model Used
Phenom II 940
CPU Full Stepping
CACVC AC 0849GPAW
CPU Frequency
3.6 GHz (stable)
3.756 GHz (suicide)
CPU Vcore
1.456V (stable)
1.488V (suicide)
NB Frequency
2.2 GHz (stable)
1.878 GHz (suicide)
HT Link Frequency
1.8 GHz (stable)
1.878 GHz (suicide)
Memory Frequency
400 Mhz (stable)
417 Mhz (suicide)
2x2 GB (5-5-5-15-24)
Ganged
Mainboard Model
DFI LanParty 790FX-M2RS (Beta Bios 12-26-08)
Cooling Type
Air - Xigmatek s1283
Windows Vista Home Premium x64
