htkm1 nice clocks...I still wish I had my old chip that did 2.68ghz on air. I was thinking about going to WC, could you please post your temps idle/load with that clock and your watercooling setup.
Idle Temp. @ 44~45C. But the Temp. reading is F!%ked Upped! Cause even @ 1.8v Vcore it's still reads 44~45C.
My W/C Set up is simple.
- Cascade WB
- Thermochill 120.3 RAD and
- Eheim 1250 pump
http://img.photobucket.com/albums/v1...II/A64/MSI.jpg
Up-date on my W/C results.
http://img.photobucket.com/albums/v1...2-cpuz-300.jpg
http://img.photobucket.com/albums/v1...0-PiSan-01.jpg
Would OCZ EB RAMs boost performance?
Originally Posted by =[PULSAR]=
Damn thats really warm for a second I thought I had high temps too. What kind of fans are you running. I have a XP-120 heatsink with a 95cfm fan and my idles temps with 2.6ghz and 1.85vcore is 43C.
The Thermalchill RAD size is 3 x 120mm Fans. I'm running 6v on them.
my new status!
New beta bios for my MSI K8N Neo (1.5B2)
so I can go higher with my OCZ EB
Complete Config:
A64 3000+@2600MHZ@1,6V
MSI K8N Neo Plat. (1.5B2)
2*256MB OCZ PC3500EB@260 CL3-2-3-5@2,85V
Radeon 9800Pro
CPU+GPU watercooled
http://www.forumdeluxx.de/gallery/da...uperpi_34s.JPG
@boblemagnifique Can you add me in your list?Please! :D
cooling is a 1A-HV3 water cooling with 2 Evo 360
vcore is set to 1,7v...
very unstable, but i could make this screenie ^^
http://vbs1.xn--mareilehppner-pmb.de...s/18_09_04.gif
Anyone got any first hand experience with the 3700+ with air or water cooling? I was thinking about getting one, and noticed that they have CG stepping and 1MB cache. Just curious on overclocking results. TM30 just a couple questions, what exactly is your fan setup like on your rads? Fans? Push/pull? Voltage ran at? and of course your idle/load temps at those clocks you posted.
This seems to be my max overclock. And this gives an error in prime.
Its not my memory, so think it might be my cpu maxing out :(
http://users.pandora.be/lifeless/CPUZ.JPG
My SATA drive is connected to slot n°3.
My memory has 3.08V cpu 1.7.
Anyone got any advise on how i might get higher? or do you think this is the max of my CPU? I do have a batch number of 4xx so thats not that good i think.
Specs:
A64 3000+ CG 0416
2*512mb OCZ EB 3700
DFI LanpartyUT 250Gb
80Gb SATA
Edit, just checked my vcore, and seems to flucuate between 1.648 and 1.712. Is that a lot?
i got this HTT but i cant get it stable
http://users.pandora.be/lifeless/300HTT.JPG
Whats your cooling?
I have watercooling on cpu and chipset ( but chipset seems to get real hot +- 50°C)
just finished testing this, using this as reference since i Just received my 3200 Plat Rev 2.0 and I wanna make sure I can run 1:1 with it :D
according 2 my experiences & observations the following Steppings have a great possibility of a good clock-achievement
5 letter code: CAA..
4 letter code: XPMW
the week code is a little bit more tricky as it seems cause its not always like
the latest is the best especially week 21 seems to suck a lot.
would u confirm this!?
Here is a screen about my OCZ EB!They run great but no more!Now I have A-DATA PC4000
At now I'm running:
AMD64 3000+@260*10@1,55V
MSI K8N Neo Plat.
1*512MB A-DATA PC4000@260 CL3-4-4-8@2,7V
System is now in tuning
http://www.forumdeluxx.de/gallery/da...0173OCZ_EB.JPG
nice one. but i don't like that timings man.
here's my highest overclock:
http://www.forumdeluxx.de/gallery/da...8062777mhz.JPG
five-seven cooling?
air cooling slk948
in few days i'm surely able to achief higher scores....
Wow 2.77Ghz on air where did you get your chip? That is a golden chip and with 1.65V its amazing. CL44amg what kind of video card do you have and the clocks?
Is that with a XT-PE?Quote:
Originally Posted by cl55amg
the r420 chip is not able to get that high AM3 scores...;-)
the r420 is faster in 3dmark01...but i don't care about that.
i have a Gainward 6800 Ultra @ 470\1300Mhz watercooled.
just got a new 3000+ what doe you think about the stepping?
ADA3000AEP4AX
CBAEC 0428TPMW
1053364G40196
looks like a pretty new one to me :)
well, it's an usual newcastle. nothing special ;)
i've just got a AMA3200BEX5AR CAAPC0409WPMW, is it good? will it work on my vnf3-250? i'm using the 04/30/2004 bios :confused:
i'll probaly need to change the cooler, because the chip doesn't have the shim, so it's a bit lower than the normal processors, is that correct? :confused:
nice. looks like a cg stepping. did ythe chip come with a cooler and a retention bracket?
I am trully amazed about this 6800 and AMD A64 3500+ processor.
B4 Radeon 9800 @ AGP 4x max was 119x11(2.4Ghz) now with the GeForce 6800 @ AGP 8x 233x11 (2.45Ghz) running perfect also the CPU is running with default voltage :)
