AF on HD2900 cards are slightly better than High Quality AF on X1900 cards. It was slightly optimized over X1900's, but still has that 45-degree angle problem.
We've seen those a million times, and they're fake.
either RV770 has more power than all the specs we have been getting or the numbers have been "modified or falsified" performance should be closer to the 3870x2 not above the 9800gx2. i hope im wrong then i can keep an intel board and have a wicked sweet crossfire for pretty cheap but i think even the ATI boys will take a skeptical look at these numbers. also i would expect the HD4850 numbers to show up first considering they are almost ready to be released and GDDR5 is still pretty green.
Those #'s seem to be fake no??
I'm sorry but I don't expect any IQ setting to be "too high" when I go multi-GPU
9800gx2 vs 4870 garafik result fake..
When does the NDA ends for these cards?
17th june
Maybe you could try not being a miser, and grab proper cards instead of something that barely makes out. nVidia's current chips already use a lot of video RAM, 512MB SLi + high res might look good in FRAPS but not be smooth.
3870 on the other hand has terrible fillrate and texture power that X2ing it is equally dumb as the minimum frame will be bad. At least it uses video RAM effectively.
And FYI, you think people like [H] really play the game for smoothness? They just run through a same scene using FRAPs, and see if the framerate dips below 30fps. The 3870X2 did that, the 8800GT SLI combo won't, but frame swapping at 1920*1200 will definitely happen either way.
very short scene of rv770 graphics demo (city, robot) ; realtime
http://translate.google.com/translate?u=http%3A%2F%2Fwww.4gamer.net%2Fgames%2F 045%2FG004578%2F20080604037%2F&sl=ja&tl=en&hl=ja&i e=UTF-8
and the vids on rapidshare:
http://rapidshare.com/files/120031828/rv770.rar.html
I do own a 8800GT SLI rig and in most games I tested with high settings at 1440*900 and 1680*1050 resolution, there is TERRIBLE micro-stuttering, which gave me perceived FPS's of 30-40 whereas FRAPS was showing 60-70.
SLI sucks, CF sucks, wanna know why? AFR sucks.
Nice to see lots of people confirming SLI/CF sucks :up:
SLI/CF sucks!!!:p:
http://www.informatique.nl/cgi-bin/i...i?M=I&A=515146
First 4850 appeared in a shop! Only 179Euro. More expensive than HD3870 at this moment now. Only some benches needed:D
