i had messaged jimmyz about a custom one he said that it was doable but never went through with it, since i never raised the money for liquid
If i set the read delay phase to enabled i got a complete nogo, on auto it works. whats the clue for read delay phase ??
Currently i am using the cellshock pc9200 sticks with D9GKX chips.
tia
thks for the further hint buddy.
have changed the tref on fsb 440 and got this:
Attachment 79291
and got this now fsb 450:
Attachment 79292
thks for the great tipps :up:
maybe i will reach the 460 but tomorrow i have to change the radiator :D
greets
are u realy using 1.6V on a 45nm chip, thats not a good idea
saw it after the reboot and in everest. dont know why but probably i changed it by mistake with the other Voltages, but it´s already changed again to 1,35V. it was my fault.
tia
Good call on the tREF Zen. I just started messing with this now that I've tightened every DRAM timming in the BIOS. I'm already seeing an increase Rd/wt/copy and decrease in latency with just a small bump, 3120T to 4041T, in tREF.
I'm running 3 instances of MemTest to 100% between jumps so it might take a while but I'll post a before and after when I'm all done.
Thanks:up:
Do you guys like using OCCT? I hadn't tried it until this system, always used Prime 95. I'm trying to figure out why OCCT fails after 5 mins at the current speed, but Prime 95 had no problems doing 4 threads for 3 hours. I don't consider 3 hours a final test, I usually go 8-9 hours for that, I just hadn't settled on a final setup yet. Should I trust OCCT and assume that P95 just hasn't caught what OCCT has?
well x38 is gone so ill be here with the x48 soon as i get it.. cant wait for it!!!
can someone please explain the issue with the 3807x2 what is the problem exactly??
ZenEffect
When you set tREF in MemSet does it save your settings upon reboot? I can set tREF to 14592T and run Everest cache and bandwidth benchmark and see the improvements but once a reboot MemSet resets tREF to 4041T. Is there a way I can make this change permenent so that I don't have to reset tREF everytime I boot my computer?
Thanks.
Nevermind, figured it out. You first have to delete your old save before you can apply a new one.
Ok now ive managed to get 4005Ghz stable on my E8400 but i need 1.39v as any lower i fail in occt. Without sounding stupid how can i get my v-core to 1.38v and stay there as ive tried the 100.23% with almost all volt settings and i can get 1.39 constant or 1.39 idle and 1.37 load but this make`s occt fail. If i could get 1.38v to stick at load and idle then i would be happy as i could test it in occt because 1.39 seems alot for a 4ghz overclock..
what are good DDR3s that could nicely go with this board?
Ive just run occt for a 2nd time just to be sure im 100% stable with the following settings. This has taken me 4 days to get right:rofl: and these are the only settings that give me a pass.
http://i249.photobucket.com/albums/g...7/ocstable.jpg
http://i249.photobucket.com/albums/g...7/settings.jpg
I have my GTL`s @ 85 83 66 .
Can this board run stable with 4 sticks and 8GB or not really recommend?
Anyone tryd DFI Lanparty UT X48-T2R? Getting my today aswell as an E7200 ;) Is there anything I should know before I boot here upp for the first time? Issues, Buggs...?
System
E7200
Corsair Dominator PC8888 CL4\Cellshock PC9200 CL5
2600XT
Corsair HX520W
