4 Attachment(s)
Scythe Ninja Rev B Fits p35c-ds3r
Originally Posted by
puscifer
Did the ninja fit? I'm thinkin of a DS3R if they're the only ones out when the 2100 come (or hopefully penryn:).
I installed it in my system,Scythe Ninja Rev B on p35-ds3r with e6750 on a p182 antec case. There is one spot where there is only 1 mm of clearance and that's with the heat sink on the north bridge. but if they ever touch the ninja will probably handle the heat being put out by the north bridge plus the cpu LOL:rofl:
Also it is tricky routing the wires if you don't have a p182 case with this heat sink.
If it fits the p35c-ds3r it will fit the p35-ds3r and the ds3l for sure.
I know that picture at the top looks like it's touching the North Bridge but that my fault..camara couldn't focus well enough...it's got 1 mm clearance.
I wish there were more usefull information on this thread. like when is the next bios update coming. and what else are the changes on each bios since gigabyte doesn't give much detail.:mad:
later on i added two 120 mm antec fans, running them on low at 1100 rpm...very quiet. great temps. i would like to add another one in front of the bottom hard drive cage.
