hey guys..
this is my first post here, as i just got my account activated.
i was wondering......
i need some help with my cooling issue.
=============SETUP=================
Opteron 165
Gigabyte GA-K8NXP-SLi
Kingston Value Ram
6600GT 128
i just installed my Opteron 165, aswell as my Coolermaster Hyper 48 onto my GA-K8NXP-SLi.
i would have went with the zalman 7700, but the DPS powerunit daughter card on the K8NXP-SLi limits the surrounding space, so i had to get this huge clunker of a HSF. (the thing is like 1 kilo almost) :slobber:
anyways..... i rewired the 4 wire PCM plug to feed the 4th wire with 12v feed from the 2nd wire, in order for the fan to spin at 3500 RPM. without this modification, it spins at 1800 rpm (lowest setting)
i have achieved a highest stable overclock of:
289mhz x 9 HTT = 2601.4 mhz
216 mhz RAM using divider (forget which divider value)
1.425 vcore
load temp with stable Prime95 x 2 running at 64'C
now with the following setup, my temps were 10'C lower.
282mhz x 9 HTT = 2543.0
211.9 mhz RAM using divider
1.375 vcore (just 0.025 over factory vcore :) )
load temp with stable Prime95 x 2 running at 54'C
what i dont understand is that my idle temps are pretty low (36/37'C) but then my load temps shoot up to really high temps. I applied AS5 and i'm thinking of reapplying it.
when i set the vcore to 1.5 to try 300mhz HTT, it shot up to 70'C.
and what bothers me even more is that at 1.375 volts, CPU-Z tells me its 1.425 or sometimes 1.45 on load. and the temps seem to me like they're a little too high. I'm using Sisoft Sandra and EasyTune5 (came with mobo) to test temps... MBM5 wont work worth a damn for me and sometimes gives me weird ratings of -78 and stuff.
any suggestions? ideas? im thinking of reapplying the AS5, this time with an ultra thin layer, using a razor... although my last layer was pretty darn good, i'd say.
