Originally Posted by dinos22
makes no sense still.....all that nonsense posting in the thread provided means nothing unless they compile that data with actualy overclocking results from all those CPUs in some sort of standardised way......also using other info such as vcores, temps, ambient temps, cooling, MaxTcase value at stock/OCd, under stock heatsink, steppings..................once you have that info you can prove whether the MaxT Case value actually means anything if you correlate the data properly and use regression analysis or some other form of data analysis......if you read it now you can just draw wrong conclusions......
