Yep
Yep
http://i.imgur.com/eQZoQAw.jpg
finally hit a home run :D
http://i.imgur.com/H3NemuU.jpg
Splave - 6:16:547 - 49x102 - 1326.8MHz - 7-10-7-24-70-1 - ASROCK OC Formula - G.skill 2300c8 2x2gb/PSC - 2.025v - CPU SS @ -50c Mem LN2 @ -100c
2 DIMM FTW!
If you want to try my wazza, 35-36 copies of 01 in a folder. Single copy D->C
2 dimms... :p
01 as in...?
3dmark01.exe install file
Not bad alle, 3d01 ftw
nice result allen!
Keep pushing bro!
If i had a ivy setup i would give this a shot as I love 01 but i dont,unless someones wants to give me some cheap gear? :P
Very nice work Splave,awesome result
Figured it was 3dm01...:D
Cool, I should try doing some Bas Rutten vid wazza. That should help with the buttkicking part.
Dumo - 6:18:234 - 50x100 - 1400MHz - 9-12-12-21-107-1T - MVE - 4X4 Corsair Dommies 2666C10 - 2.1v - air/cpu ss
http://img849.imageshack.us/img849/7...2800twcl61.png
Uploaded with ImageShack.us
On MVE
Dram CP 2, TX slew ab 4, RX slew 5, MCH ds a 14, MCH ds b 15
No mercy for the weak :D
Had a little go again tonight,failed at loop 24,will try your waza out Splave.Seems im losing a lot on the last value output,with correct waza setup this should be in the 16.450s?
http://s4.postimage.org/pmdj2p7v1/fgg.png
So i was giving a shot at this...Day of failure for me and Bullant it seems :p:
Long story short... booted,set voltages,wazza'd and started to run pi...
OOOps no ram timings set so stop spi and memtweak the hell out of it and run straight again...
Oh run seems pretty good (my goal was below 6m17s) so decided to take a video of it why not...
Loop 24 was finished and shuddenly... kaboom system restart...
Decided to let it dry a bit and give it a shot an other time after i insulate the mem area a bit...
If wazza is done correctly maybe 6.16.500 is doable...
vid and mem settings:
http://www.youtube.com/watch?v=Fq5LzgpL1ts
http://img12.imageshack.us/img12/6691/screen002ga.jpg
Are you using ram disk? That will help your last loops.
Something is not right though I think with you're timings 4 dimm should be around 6:16.2**
Hey,im not using ram disc and my waza is just 1x1.8gb file that i move 2x.Will try ram disc,thanks for the help
@ crusty,awesome timings man,tell me crusty you wanted to swear on that fail lol
Totally man... i wanted something to begin with and start crunching it down... no worries though will try again (maybe try twcl6 to see what's happening)
are those PSC or BBSE, crusty?
Hey guys i just notice i haven't been running in debug mode under boot ini advanced options tab, If I tick debug mode it should help?I have themes enabled this is correct?
Ok now it's getting irritating... found some good wazza (big big file d-c 3 times) 5-6mb dif between available and cached...
it starts slow but then it cuts down really really fast and helps with bonus loop too...
dunno with i lost this one...was aiming for 6.16.4xx
http://www.youtube.com/watch?v=aFt6T...ature=youtu.be
bbse ln2 full pot 1.89v (no need for more) cpu is still aircooled maybe i will get it subzero next time...
Still working on my waza and no ram disk but debug mode may have helped,getting there will keep working on it.
bullant - 6:16:578 - 104.2x48 - 1354.3MHz - 7-11-7-26-90-1 - Gigabyte Z77X-UP5TH -G.Skill Pi 2200C7 4X2Gb/PSC - 2.15v -CPU SS -30 / Memory LN2 -110
http://s11.postimage.org/ghc3yt3lf/image.png
My secret manual wazza (after killing explorer, Pi opened and ready to go) :p
https://dl.dropbox.com/u/30576042/manual-wazza.JPG
