Thank you, works now. Without AVX LLC raise's voltage to 1.37v (1.35 set from bios) and now with AVX voltage raises to 1.40v!:(
Temps raised also from ~73 to ~75 after couple rounds.
I see, so that's a gem of a cpu then for sre.
My first 2600k had 3.4 ghz VID of 1.235v (I think) and the 5 ghz VID was 1.390v. And that chip needed 1.5v at load for 5 ghz. The second one was 1.215v VID for 3.4 ghz and 1.368-1.371v VID for 5 ghz, and needs 1.416v at load for 5 ghz
I'll put him under LN2 this weekend on a lan party, I'll post results after that :)
i5 2500K L041C246 SN 1919
P8P67 Deluxe B3 Bios 1503
Corsair Dominator 12800 C7 6gb Rev2.1
Costum WaterCooling
http://img683.imageshack.us/img683/3853/55ghz2133c7.jpg
anyone have try i7 2600K L102B281?
Has anyone had their pc stop after making a pop type noise? After swapping out all parts its looking like a dead cpu and maybe mobo too, has anyone else had their cpu die when running 1.5v under water cooling with good temps?
So, after having so many bad luck with the 2600K, I'm selling my last one and move to 2500K for a change. I know I will miss the HT and 1MB additional L3 cache, but heck with that. Just came back from MC with a new 2500K L101B483 batch and we'll see if this is good or bad. If it's also bad, I'm gonna sell all the SB components and go back to 1366...heheehe...more a joke, but seriously, this SB is probably not for me.
Edit: Just stress-testing a basic OC of CPU Level Up 4.6Ghz on the M4E. Hope it can pass this basic OC. If it does, then I will try a higher speed and see how it goes.
So far it's running very cool! With 4.6Ghz using 1.352v (as shown on CPU-Z), it's showing: 56-57-59-55 with 100% CPU usage (Prime95'ed).
Stay Tuned!
L045B311, 53x probable wall, blinking cursor at 54x, and I didn't want 1.55v with just crappy aircooling
http://valid.canardpc.com/cache/screenshot/1767703.png
In my recollection, whenever someone said they heard a POP, it was the PSU that fried.
Have you tried a new PSU? I have heard of smoke, literally fire, and bad smells... but when a POP was heard it was a PSU. Usually the POP is an electrolytic cap "tin can" exploding.
A P8P67 I had popped and it was a burnt connector strip from the CPU fan on the back of the motherboard with corresponding smoke. I would say psu, mobo, ram frying before a
CPU. It's harder to kill a CPU than the others mentioned above.
Yes I have never killed a cpu either, after it shut down I noticed no smoke etc, no lights on mobo other than power switch lit, press it and the mobo LEDs flickered quickly then nothing. I suspected psu as its an old benching OP1000 so I swapped it for a good psu, still nothing but a red light shows on the psu (CM real power pro 620) . I swapped cpu and rams onto another EVO this one tries to boot, hdd spins up but mobo post stops at cpu with LED lit on mobo and no red light shows on the psu. I will need another 1155 cpu to confirm and I dont really want to buy one just to test these parts but it looks like Im going to be forced to. I did want to try a 2500K anyway so I guess this is a good excuse.
What do you guys reckon? Dead cpu?
:shrug:
I reckon you have a good excuse =)
Newbie question here but does the 2600K OC more than the 2500K ?
Batch # L102B283
This is the most I've pushed it (so far)
http://i21.photobucket.com/albums/b2...o/Untitled.jpg
Hey lithfkn its your rig man you do exactly what you want with it & dont worry about people trying to crap on you....
@ PytonOrm dont think there was a need to poo poo a new member mate, he's obviously quite happy & proud enough to contribute to this thread.... were not all as good as you!!!!!
Well he was offering advice trying to egg you on & mentioning the new BIOS so for that I personally would have been grateful. I just dont get why people with good intentions have to be so harsh.
The vcore is what it is, if thats what it needs there aint much you're going to do about it.... maybe the BIOS PytonOrm mentioned will net you a higher OC maybe it will allow you to lower your voltage :shrug: I would say the best thing you could do would be to read through threads like this, the ASUS P8P67 Pro & the 5GHz club & make your own mind up about your overclock.
Personally 4.8GHz is plenty fast & IMO you'll not notice an everyday 24/7 difference pushing to the magic 5GHz. It all depends what you want to do with your rig & whether you want to be realistic or max it out & potentially learn the hard way....
