What is that?
What is that?
looks like an LED strip?
Something tells me those FlexLights are the ones used for this build. :D
btw Xien, have you found a use for all that sleeving mountain? I could use some meters lol. :ROTF:
@FlawleZ
it looks like this :
Hey guys needs some help here...I decided to get some PSU cable extensions and work on some sleeving on them, rather than kill the warranty on my PSU. I plan to do the 8pin mobo, 24 pin mobo and 2 6/8 pin pcie cables...
1. What size of sleeve 4mm/6mm???
2. Size of heatshrink
3. How much would I need to order?
I am getting my stuff from chilled pc as shipping to India is very cheap and the quality looks nice.
^^^^Looks like a flashing whip Xien16
hehehehehe, I enjoyed the bars of LEDs with sleevings!
Laine: You are evil ... I hate to see things that are so beautiful, that I think "there can't be anything more beautiful".
My God Laine......thats jaw-dropping
These are for you. ;)
http://img695.imageshack.us/img695/1310/31688900.jpg
http://img31.imageshack.us/img31/6171/67721943.jpg
And thanks dro!
Somehow the cooler looks pretty fragile in a beautiful way:eek:
can someone tell me what all i will need to sleeve my enermax revolution and all the cables in my machine along with 2 custom 36" long 2 wire cables and a 18" 3 wire cable.
wheres the best place to get it from and whats it gonna cost me?
great pics Laine
Can anyone tell me how I might slip either the sleeve over this molex connection and or take it apart and put it back into a regular molex plug with heat shrink on it?
If I cut the cable and just strip the wire, should I be able to put it back into another molex?
http://farm3.static.flickr.com/2740/...176b8746_o.jpg
Laine, awesome Pics, looks so beautiful :worship:
Has anyone successfully sleeved a dual USB internal cable? I can't seem to find a tool that can remove the usb wires from the adapter itself...
Edit: Nevermind. Apparently in my order of the MDPC-X Sleeve I got a sample of the SATA cabling (I think). Well it worked. It was rough, but I got it to fit over it... :-)
Do you mean this ones?
USB internal
