I have some qs for you DFI users with Phenoms;
- Does speedfan still kill/crash your board?
Stay Away from Speed Fan!
- Do you still have voltage problems with only special add option giving you increase Vcore?
~ NO there are no issues that I am aware of on 4 different Bios /phenom!
- Whats max vCore added through BIOS special add option without changing VID?
~ Don't Know Tye will look into it:up:
- Does AOD now work with your boards without crashing,
at all?
~ So Far its a worthless Pile of Doo - Doo and has never functioned Properly
- Can you change VID in BIOS and still set low CnQ VID/Volts?
Don't know would be interested in finding that out myself
- How much difference in options is there in the BIOS for M2R vs M2RS?
~ No Difference in Bios Options just Bios Code is Different do to 4 Phase PWM on M2RS:)
- Do you still have whacko temp feedbacks compared to all other 700 series boards? [most likely :p:]
~ Some Bios are off but for the Most part not by much and they are pretty accurate!
- What's the best Phenom BIOS you have?
~ Cant answer that accurately but so Far 1/30/08 works well & 4/15/2008 Beta seems to be a winner and I like it;)
Have you worked out what these options are or what they affect yet? Don't have a clue in Hell what they are for:D
http://img217.imageshack.us/img217/7512/htlinkhm5.png
