Brass backplates ready... now they waiting for chrome ;)
Sorry guys for quality of pics - mobile camera
http://www.abload.de/img/20100212509g6n4.jpg
http://www.abload.de/img/201002125132utk.jpg
Put wc block for the 9800gt also! :D
I was hoping to get some insight on picking a good CPU water block to match the Rad I picked. I decided to go with the XSPC RX240 Dual 120mm for now. But I want to make sure I get a good matched cpu block to work in a ysytem with that rad. I wanted the EK Supreme HF origionally but liked the look of the led's in the LT version. How do you guys think each one of these will do and with what type of pump will I want to look into? Can the HF be fitted with led's for looks later? Will the LT at least match or outperform the Swiftech Apogee XT Extreme?
lol, love your name...
i thought i've read that the xt beats all... no?
Indeed it does, although it's also rather restrictive. Second most restrictive in Bundymania's test, to be more precise: http://www.abload.de/img/durchfluss-2jq1m.jpg
And here we go... some problems in project. Plexi crashed in qpi and ram module, CNC have NA status ( i have only one custom backplate ) ... ehhh :(:(:(
ETA Project: unknown
So now it's looks like this:
http://www.abload.de/img/1afxs.jpg
http://www.abload.de/img/2vf6f.jpg
http://www.abload.de/img/3fciu.jpg
http://www.abload.de/img/4rf6k.jpg
http://www.abload.de/img/5jhzt.jpg
http://www.abload.de/img/6gd6o.jpg
thats very nice malik, stunning!
That are bad news, but awesome shots. Why did your QPI Block crashed? Did you want to rebuild it or did you want something else?
Great shot as always Malik. There is a lot of inspirations in it. I like red theme the most, but is yours build. When you`re starting next one? :D
I don't know why this plexi crashed, but next one i want make from brass ( i'm talking about top of QPI and RAM block ), and of course chrome ;)
All new project will be make in new case. In this one i want just finish this few things.
i want to see this plexi from brass. Is he from this forum? Next project, that would be fanthastic ;)
anyway you could explain how to make those aluminum shrouds you have in there ??????????
dude, can you even use that computer from time to time...
seems that you're doing it over and over all the time!
I have currently the older Apogee GTX block with optional copper top for my olde X48 Rampage. How different is the new XT and as far as low resistance for low speed quiet operation at night gaming use? Who can comment on that EK LT block fitted with led's earlier in this tread? I'd likt to try something with color if it is in close performance to what I'm used to with my old GTX for now. I read the HF version is better at higher low for top end cooling but not as great on low flow idle temps low speeds. Is this pretty much the norm for a block like that due to its higher restriction jetting?
Love the blue.
Have you chosen next case for the job?
BTW, what do you think about new Silverstone FT02?? Is it worth this money?
My friend and I have a discussion about it. He wants to buy it and put in it a 5870, I know it`ll fit there, but I think is to small for it. What case you`ll buy for this GPU? He want midi tower.
Sorry for OT. ;)
malik
which pump do you recommend? I was thinking of buying XSPC. what do you reckon?
For now im thinking about 2 cases - but i dont decide yet.
Your question about FT02 - in my opinion, this is not so good case for LC.
That depends of LC setup... how many blocks, rads etc.
I use swiftech mcp355 with poweradjust controler.
im planning LC with 3 rads, cpu/MB/video/ram blocks. 1/2 ID tubing.
how do you find swiftech mcp355?
heymalik can you share how you made those shrouds
