I wish I had one to find out. Even a 10X multi would be sweet.
thanks! tried these voltages and no stability.Quote:
Originally Posted by zeeke
i'm starting to think it might just be the crucial ballistix.
wish i had another pair of memory to test with this board.
I can't even get 10x to work right... it just doesn't seem to want to move off of 11.Quote:
Originally Posted by coop
^^ do you have a bios version other than 1.1? Downward was made available .
Double post
This is a bit of a nightmare. Yesterday I went out with the intention of buying a 6600 and a p5b deluxe. Just as I was about to pay for the 6600, I mentioned the xeon 3060, and was told one was arriving tomorrow. So I've put a deposit down and opted for that instead. I was then well chuffed to find a shop selling the aw9d here in Thailand, and bought it instead of the p5b.
Reading this thread, I'm hesitant to even take it out the box now. Thinking maybe best bet is to try it unmodded, and if it's not up to much, then sell it and go for the p5b.
Shame it certainly looks a nice bit of kit.
RLM
coop, just seen your message. You mest of sent that a while back.
I can blend prime @ 3.8-3.9ghz with my AW9D/Xeon 3060, just replace the craptastic stock heatpipe chipset cooler.Quote:
Originally Posted by RLM
Ive had a chance to play with a stock P5B/E6400 and had problems even just over 330 fsb (thinking early bios + ram issues ), I do not see why the AW9D is bad...
There really isnt anything wrong with the board. So many people have had success with it. Im very satisfied with my results. It really depends on what type of oc your trying to get out of your cpu and what cooling you intend on using.
I think the P5B Deluxe is a good board but it was the first one i had and i hated it and it was gone within 2 days. My point being that everybody does nothing but praise that board while it seems some people have a dislike of this one. There is no given in overclocking so its really all about cracking the box open and giving it a try.
http://img90.imageshack.us/img90/5358/8hourru0.png
I decided to take hipros advice and give dual instances of sp2004 a try. I have to admit this isnt a true comparison to orthos considering im using the new bios that was updated. I have since gone from about 2hours small ffts stable to over 8hours. I also decided to loosen up my ram timings considering how aggresive they were during my last run.
I think its been shown by myself and others the AW9D-Max issues arent across the board. Some of us are doing well while others arent.
Im going to run blend next just for the hell of it.
good job on getting 2 hrs stable.Quote:
Originally Posted by MrDeeds
and have fun trying to blend at 423 :)
let me know how it goes. i have a feeling it's not going to make it.
but good luck anyway! :)
Im actually 8 hours stable. What i said in the post is i went from 2 hours to 8 hours and i actually stopped it myself.Quote:
Originally Posted by shimmishim
I'm probably going to be on record for first RMA. Post code 8.7, 8.8, then 9.0 with my E6700. Board was fine earlier on.
Any Blend results yet, my friend?
Im at about 2 hours going strong. Im going to try and match the small fft 8hr run. I'll post a pic if i get that far. The last time i ran blend it crapped out at 4hrs 45min.Quote:
Originally Posted by dragonhunter
Heres a link to the previous run when it was at the 3hr mark.
423 Fsb 3hr Orthos Blend Test
Heres the point of failure at 4hrs 45min
423 Fsb 4hr Orthos Blend Test
But as i said before i believe it failed because of my overly aggresive ram timings.
http://img141.imageshack.us/img141/2541/8blend6sp6.png
8 hour orthos blend test@423x9. No mods to the board other than a thermaltake extreme spirit 2 nb cooler and a 92mm fan over the nb area.
Nice MrDeeds, Single stage on CPU?
im workin on super pi 32mb stable @ 460 now..
Wow!
great job mrdeeds!
you probably have one of the best aw9d-max boards i've seen!
i really wish i had another pair of memory to test to see if the problem is memory related and not mobo related.... hmm...
easy to check, change the multiplier / let the ram run at lower speed?Quote:
Haven't read through all the pages of this thread, but is there any info on replacing the northbridge? I can see I would need to take some pliars to the back clips, is that right? but what about removing the pipe?
Also anything to bear in mind, when choosing an alternative?
Thanks ahead for any advice.
RLM
I went with two Coolermasters. This one on the northbridge, & this one on the southbridge. I read this review for performance comparison and chose these for the blue effect to match the boards leds. Cools much better than the heatpipe thing. Oh and I have a Microcool ChipSink Cooling Kit on the mosfets.Quote:
http://img.techpowerup.org/061116/Picture 001.jpg
http://img.techpowerup.org/061116/Picture 002.jpg
the board runs fine at 10 x 375 (orthos blend no errors).Quote:
Originally Posted by catscit
when i try 9 x 400 orthos blend errors out in 4 minutes.
i also tried 8 x 400 orthos blend and the interesting thing is is that it'll run at this speed for 10+ minutes.
now the question is... what is lmiting me, the chip, the ram, or the board?
i'm 99% sure it's not the chip.
so that leaves the ram and board.
i have a feeling it might be the ram but it could also be the board.
i have another board coming so i'll test the memory on that.
if it still has issues, then i'll know it's the mem and not the board.
I thought cause of the bios.I ran 400*8/400 4-4-4-12@2.1v then tried 2.2v,I won't go 2.3v because with 2.3v on P5WDH I can do 400/1000 4-4-4-12 with my Geil ram,but the final result that I still got blend test error after 5 hours and memtest error after 9xxx% testing (something hold my ram and made it error).I am sure it isn't my ram cause with P5WDH same setting I did successfully both test for ~30 hours.
Nemesis, thanks man:)
Im sure a new bios would solve the problem, its just if we ever get one or not.
