Try using the BBS F8 option to select the hard drive you want to boot from...
yep, tried with 1305 and 1403.. mightve been 1402 but pretty sure it was 1403.
i will give it a whirl!Quote:
Originally Posted by Ic3man
note i tried 1.20v for ICH voltage i think it made a bit of difference.
Has Asus fixed the shutdown bug for the p5w dh dx yet? You know when you save the bios and it shuts the power down for a moment before it begins to boot.
I read the P5b and the Pro version of the P5W has this issue corrected.
TIA
sparx
Hey everyone,
Have been learning a lot about how I should and should not overclock my mother board with my system from this thread. I have an e6600 conroe, an eVGA nvidia 7950 GX2, Corsair XMS2 2G (1G x 2) DDR2, of course the Asus Motherboard running with 1407 bios version, and a BFG 650W Power Supply. Using AiBooster and using the Overclocking Profile I can get the machine up to 3.1MHz, but it seems like that doing that doesn't optmize the memory. I went in and have adjusted the memory to be 4-4-4-12-4, but that didn't seem like it helped very much (my main test I did was 3dMark06 which I got an awful score with the CPU testing; only 1 fps). I was wondering if there is something else that I can use to test the speed of the processer and actually notice a difference other than looking at numbers on these different software apps that monitor your box stats. Also, will changing these voltages affect the performance of my graphics card, or does that pretty much run as is?
The Overclocking Profile thing seems to make everything run smoothly with low temps and all, but when I load up the post messages it says my memory is at PC2-3200. With the Corsair memory that I have, is this a standard level or is it possible to raise it up higher without crashing the system? These are just a few started questions as I'm sure I'll be trying to get this to overclock with the correct settings for a while unless someone else out there as the same setup or similar and can give some hints to try. Sorry for the long message and thanks for taking the time to read.
Peace,
Dave
I've just experienced another quirk with this board. If I keep my mouse receiver (Logitech wireless) connected to the standard 6-pin mouse (PS2?) port, it becomes unusable when the system is reading off my internal CD/DVD drive. The mouse cursor will respond, but in extremely slow mo & stuttered fashion.
If I connect the mouse via USB, problem disappears. WTF?
nope :)Quote:
Originally Posted by Sparx
I think I`m gonna try a vanilla p5b first since the problems are solved when cold booting with this board ( need 2 pci`s ), only I am wondering If I need to install windows again. I went from nforce 4 to p965 without installing windows again, to i975x, ( installed windows again first, don`t know why I did that :p: , Anybody know`s if windows works from a windows p965 pc to i975x ?)
and I`m going from i975x to p965 again, < hopefully > without the need to install windows again :rolleyes: .
I don't have a 965 board, but I am thinking like you of getting one-P5B DX But I doubt the chipset drivers are the same. So a Windows reinstall would be needed for both of us since I have an Abit Aw9D max a 975 chipset board.Quote:
Originally Posted by Pjoeloe
What the hell is ASUS doing not fixing that bug on the Pw5 Dh?
sparx
I think this motherboard is just a compilation of bugsQuote:
If computer is connected to the 220V, and maybe can goes on unexpectedly (after "power loss" for example =)), but waterpump of course not... This is "pierce of sheet" but not motherboard...
http://images.people.overclockers.ru/92140.jpg
http://images.people.overclockers.ru/92139.jpg
I"m was dissapointed in asus this time...
I coulda sworn it didnt do that sometime. I cant remember on which bios or what since I flashed about 40 times, but I know there were some occasion it didnt shut off the power completely; it just rebooted.
On another note, has anyone got the first ethernet port to work with just LAN to a dsl modem? For some reason it never work for me and I have seen the same results on two different boards. Only the 2nd ethernet will recognize my dsl and successfully get an ip. I'm a bit curious and thought maybe it is just me..
The shutdown is needed to be able to set the NB-strap correctly before bootiing again. So it's not a bug.Quote:
hope this saves some one some time it sure Pi$$@# me off trying to figure this out. What I figured out finally and maybe its just me but my 550 dollar corsair PC-2 8500 ram will not run using (manual) setup with a speed set at 1066 mhz in the bios. Note if I choose any other ram setting within the 900-1000 mhz setting the bios will post it properly as 8500. Anyother setting it will post anywhere between a pc- 5400 to pc- 7100 ram <--- what the hell is that 7100? FSB does not seem to be the issue to over clock the processor. The strange thing is when the ram is set within the 900-1000 mhz range the CPU-Z program will show the ram running at 533 mhz and as pc 8500 module and the bios will show in the post as 8500. Therefore I think this may be a bios issue. Same problem with the 1305 bios and the bios this board shipped with.Quote:
Originally Posted by kaisersose
Bottom line if you are having problems Overclocking Check that your Corsair ram is set to manual within the above noted range and check with CPU-Z to see what it is really running at.
Also take it off the SPD settings and put in the proper timings as mine was defaulting to 5-4-4-12. Proper setting for this ram should be 5-5-5-15 runinng at 1066mhz.
and dont forget to disable the hyper 3 thing in the bios
Good luck.
At least now I can overclock this sucker
__________________________________________________ ______________
Xgamer 700w PSU
Intel E6400 OC to 2.66GHz (O/C 2.9 mhz 1.23 vlts @ 31 celcius, Corsair PC-2 8500 2.2vlts running at 553 mhz CPU-Z reading)
Stock Cooling (waiting for my Thermalright ULTRA-120 Heatpipe Cooler to arrive)
P5WDH Deluxe 1407 BIOS
2Gb Cosair XMS2 8500C4
Seagate 7200.10 250GB HD
Standard 1.44 Floppy drive
(1) LG DVD Burner
6800 nvidia Video Card (waiting for release of new 88XX series next month)
On board sound
well, I don`t understand why it wouldn`t work. Windows booted flawless when I uninstalled the nforce 4 drivers and installed the bastard without reinstalling windows xp prof sp2. I think if you uninstall the drivers of the p965 chipset you installed and install a i975x motherboard, windows will boot and work :)Quote:
yes we know, but how would you call it then since it can be fixed :p:Quote:
Originally Posted by OneyedK
Thanks for the info man.Quote:
Originally Posted by Strikez
I am with Bios 1407 having a lot more problems using the manual timings and am getting totally sick of this board. Anandtechs review on the board gave it a way better review then it deserved, then Corsair robbs me as i buy their friggin expensive memory(Corsair TWIN2X2048-8500C5) that actually cant be used to its fullest. Then finally, the kiss of death is given to me after buying the P5W DH board and finding out that it sucks even though its their hardcore overclocker motherboard. I could have saved many dollars by waiting but who the hell has the patience?
Enough of the bitterness, I know that I will find a good board in the near future and that my memory still is a good investment for the future.
Anyone got any other recommendations on similar setups. I sure would be interested in some bios-setting-specifications for my exact setup, such as the one Strikez posted.
@ Strikez and breitan
The reason CPUZ shows your ram running at 533mhz is because it is DDR-2 533 x 2 = 1066
Now if you're having problem getting stable with 1000+ then you might need to increase your vmch to 1.65v or more if you have the newer board and vdimm somewhere 2.3-2.4v
Well.. not really.. it's not the ddr- TWO which is importantQuote:
Originally Posted by syne_24
It's the DUAL Data Rate bit
If you go into BIOS Setup with the external drive powered on, is it actually in the list of bootable devices in the Boot section? If so, can you push it to the bottom of the list and have it stay there through several reboots?Quote:
Originally Posted by rpr
(There are two lists: one for floppy/IDE/HD and one for drives. I guess you should check both.)
I'm kinda annoyed that my 'first' drive is attached to the secondary IDE port, but it does no harm so I don't screw with it...
Has anyone purchased this board recently? I just bought one for $228.99 the info on it is:
Serial #: 69MOAG13XXXX
Part #: 90-MBB2X1-GOAAY
Just wondering if anyone has any clocking results with september boards.
I have no complaint about the P5W DH board. It is the best motherboard (most stable) I have ever had. I built my first computer using an Asus motherboard in 1990. I later switched to MSI boards. The previous system I built was a DFI LP Ultra-D. It is a POS. I will never buy a DFI board.
I have to agree with you but I read in another post this board doesnt officially support pc8500 corsair so I have to take my lumps as I had over looked this. I still am hoping ASUS can fix this problem with a BIos fix.Quote:
Originally Posted by breitan
I gave up playing with this ram and have it clocked at pc2 6400 board still can O/C to 3 ghz easy enough but wanted 1066mhz ram speed to. Going sell this board anyway when the new nvidia chipset is out and I hope it supports this ram or just like you stated I could have bought the cheaper ram but spent the extra cash to get the max performance out of boards but I am finding it has been a waste.:confused:
would post CPU-Z pics but dont know how.
OCZ X gamer 700w PSU
Intel E6400 (O/C at 2.9 mhz 1.23 vlts @ 31 celcius, Corsair PC-2 8500 2.2vlts (running as pc2 6400)
(1) LG DVD Burner
On board sound ( Seems better then my old audigy).
I ll give that a shot but cranking up the volts on my ram to 2.4 volts ok? Thats one setting I been shying away from but I m game. Thanks for the response. If this works Ill report back in a few days. Had time to do this now.Quote:
vmch 1.65. Ram 2.3 volts at 1067 mhz manual setting 5-5-5-15. CPU volts at 1.25 system reboots after the windows screen with bar moving is finished.
vmch 1.65. Ram 2.4 volts at 1067 mhz manual setting 5-5-5-15. CPU volts at 1.26 system reboots wont boot or post.
Back to FSB 320. Ram 2.2 volts at 800 mhz manual setting 5-5-5-15 vmch auto. I can move the FSB higer but choose not to in order to keep temps as low as possible. Thanks for the feed back. I like the board but just not good for overclocking with my hardware.
Hi guys.
I have this motherboad, 6600 dual 2 core, 7900gt and this power supply, OCZ X gamer 700w PSU.
The first time when I was building my computer it didn't boot and was crazy find what the hell was wrong. One friend has a Enermax 535W power supply and I tried with it......... my computer booted. Ok, I thought my OCZ is not working, I will return it to NewEgg for a new one.
Today I have it with me and nothing, is not working :(
Any idea before send it back again ???
thanks in advanced.
So the board is not working with a new OCZ or not working with the Enermax, that it did boot with?
I am a little unsure.
And you did remember to plug in the 4 pin power connector?
sparx
Originally Posted by DarkG
I have an OCZ 700 and P5W DH just like you and everything works fine.Did you install it correctly ?.
sorry. I will explain again
With a Enermax it works, not problems. But now with my new OCZ it doesn't boot, or any fan moving, nothing. Yes, everything is connected, 24V, 12V, the connector for my graphics card, etc.
I have a tester for power supplies and I did a bridge betweend green color and black color and the power supply is working.
I don't understand why is not working.
Is any difference between the connectors CPU1 and CPU2 I mean, different voltage ???
