he must be using older linx library...see that also Gflops are not even
It was my second run at the same freq. Furst time it was 61 Gflops, but I used lower Vcore, Vmem and Vtt and the systeme crashed on 13-14 loop.
CPU Vcore +160mV
CPU Vtt +140mV (Everest read 1.3V) I guess you mean QPI/DRAM
CPU PLL 1.617V
IOH Core 1.18V
IOH VCCA 1.168V
http://10pix.ru/img1/2410/3017995.th.jpg
http://10pix.ru/img1/2426/3017997.th.jpg
I can not say what is the processor - NDA.
Cold water - MB, VGA, CPU & RAM.
wanted to go to 5050 MHz, but at 6 minutes got an error, so that the 5000 MHz beautiful number for the club from 4500 MHz, it is time to open the 5000 MHz LinX Stable Club :ROTF:
E8600
Batch no Q820A727
Custom SS cooling
DFI UT P35 T2R
1.568 Vcore
5.153ghz
Real Temp was a waste of time because the evap temp never moved from -58c the whole time.
http://oi51.tinypic.com/2ntjjvn.jpg
Very impressive! Great job, guys! :up:
Updating in a bit. :)
Zalbard I forgot to post cooling information for my submission to the 4.5 club,
below is what I am running 24/7 at 4.6 ghz.
Batch: 3032A340
Pack Date: 10/14/2010
MB: Rampage 3 Extreme 1102 bios
Voltages:
CPU Load Line Calibration set to Auto
QPI Load Line Calibration disabled
Vcore: 1.34375 actual reading 1.336 with ROG
CPU PLL: Auto actual reading 1.812 with ROG
VTT: Auto actual reading 1.330 with ROG
DRAM: 1.64 actual reading 1.641 with ROG
Cooling: H20-220 Ultima XT Plus
Just in case anyone is looking, there is a 3849B*** for sale here: http://www.overclock.net/main-compon...18-lapped.html
Cpu should be called golden when it's able to show such results unlapped imho.
Taking a break from x58, decided to give this 655k another try. P55A-UD6, 2x1gb Kingston HyperX, water cooled. Failed at 17 passes, next time 18, finally got it to pass, vcore is way high.
Thanks Sergio.
Core i7 980X (3013A524) - 4500.4MHz
EK Supreme HF-CU+HL480X+MCP355+xspc top res+NMB-MAT : room 26C
GIGABYTE X58A-UD9
A-DATA 2000G V2
http://img340.imageshack.us/img340/8371/lin980xrun.png
http://img403.imageshack.us/img403/6184/lin980x.png
Finaly with bios 0095 she is stable @ Bclk 215.. gonna run more tests @ lower volts
http://img101.imageshack.us/img101/2990/stabilio.jpg
I'VE FINALLY DONE IT!!
i7 920 @ 4600 (21x219) HT OFF 1.472v on air, no tricks and with case closed.
I guess i can lower the vcore, 1.472v was just to be sure it would be enough.
]siNNer[ | i7 920 [4C 4T] @ 4600MHz | 1.472 | Gigabyte X58A-UD3R | Air (TR Venomous X) | 3945A927
https://dl.dropbox.com/s/1q2n0ipxju5...inx%204600.jpg
i7 920 - HT Off
Batch: 3918A495
Custom SS
Foxconn Bloodrage GTI
http://img441.imageshack.us/img441/8...2191408.th.jpg
My System
Cpu : Intel Corei7 930 HT On Vcore 1.525
MB :asus RamPage 2 Extreme Bios 1914
Ram : Kingston HyperX Bus1866 3*2GB (BBSE Chip)
Cooling : Water Cooling
PowerSupply : Gigabyte Odin 550W GT
http://www.pc-cm.com/modules/Forums/...20loop_142.jpg
http://www.pc-cm.com/modules/Forums/...m_post_579.png
