This is the max. FSB, if i set it higher bluescreen :(
i use Bios R1.03, Timings 4-4-4-8, VCore 1.5v, CPU Stepping QHJJ, Water Cooling (max. 30°C)
http://people.freenet.de/chris070719.../SuperPi-1.jpg
another victim.... :( bad
yup.we want to know what's wrong with those es chip? or maybe the mobo?
stuck fsb made me crazy.....God
cooling by tower120.
my qhjj stuck@228
qkhk stuck@234
looks like same as pentium M - we have B1 .. now B1 in these chips
Has anyone posted BIOS shots of the memory config available on this board? Is there any tool similar to A64 Tweaker that shows full memory timings via Windows?
*Edit just saw FELIX's tweaker, maybe one of the high FSB guys can run that so we can see what if any differences there are ;)
Maybe it's a simple memory/BIOS config causing the problem.
@ Fredyama
What is "graphite sheet" New Beetle is using :)
Somebody should try a retail chip with new revision :)
tried. T2500 retail 0546B121-SL8VPQuote:
Originally Posted by DaWaN
stuck@234 12*234.:(
Well we will know when the next batch hits the states. I will be following these developments closely as this will likely be my next rig and the return to an Intel rig not snice I owned a P1 133MHZ chip:woot:
I praise for aopen that they have to be glad that like 10% doesnt have any problems...
< G H Z
Please see Tarosa's SS for FELIX's tweaker setting.
@ Fredyama
Please take a look at http://industrial.panasonic.com/www-...YA0000_WW.html
Originally Posted by PRTeamJapan
uber thermal tape?? :stick: :D
Interesting, is the graphite between the container & chip?
< G H ZInteresting, is the graphite between the container & chip?
Yep, in lie of thermal grease-- but have to be very carefully using this as core may crack/chip easily, they say.
I 've never used one as I do not own a magic hand:D
would be great on a THIN and LAPPED IHS then :D :slobber:Quote:
Sure you do ;)Quote:
So is the function to raise die temps under DI/LN2?
< G H Z
So is the function to raise die temps under DI/LN2?[/QUOTE]
I do not think so from its heat dissipation property-- they use it to fit Pot/Core as tight as possible to nearly the core breaking point so one needs a magic hand:D
beta bios... no gain
http://img.photobucket.com/albums/v336/wappie/bios.jpg
By Tarosa
LN2 Cooling:
modPI 1.5 XS 1M: 16.750s @3640.7MHz (280.1MHz x 13)
http://www.geocities.jp/gbxfs134/i97...3/pi1M/280.JPG
modPI 1.5 XS 32M: 15m33.110s @3601.4MHz (277.0MHz x 13)
http://www.geocities.jp/gbxfs134/i97...i32M/27732.JPG
wow. wow. wow. wow. wow.
i like to see soem 01 on thate speed :D
I would like to see ANY 3dmark with that speed.. The power is there, rock the ORB! :toast:Quote:
Originally Posted by blind_ripper
:o.
For any 3dmark, please ask hipro5......;)
i just fell from my chair.. me and hicookie are working HOURS... really HOURS.. and then some sick screen come's by :D great work tarosa.
