Buy a bigger case and do some cable management :D :D
Well!
heres mine, Yesterday I updgraded my GPU to a Q6600 and Ultra 8800 from E6600 and GTX 8800, i thoght i post here for a change, WHAT DO YOU THINK, Im from Argentina!!!!
Espero les guste! (Hope you like it!)
http://img178.imageshack.us/img178/6...0013yb0.th.jpg
http://img467.imageshack.us/img467/6...0004gk6.th.jpg
http://img361.imageshack.us/img361/3...0010hg0.th.jpg
Nice setup!
TheMiracle clean that zalman out >_< :P
Nice setups i c here :D, il be posting mine aswell in some days/weeks ><
Jeez thats a hardcore setup man :P
Heres mine........similar to miracle's in a way.........;) (picts are large but you get a "breezier" vision of things
http://olivelb.free.fr/Forum/Comp/HD2900-03.JPG
http://olivelb.free.fr/Forum/Comp/HD2900-04.JPG
http://olivelb.free.fr/Forum/Comp/HD2900-08.JPG
Black Beauty :eek:
http://www.abload.de/img/dsc01020l5s.jpg
http://www.abload.de/img/dsc01021o5f.jpg
6800 ultra, my two best card's. :rofl:
http://img410.imageshack.us/img410/1958/img0059mi8.jpg
http://img410.imageshack.us/img410/1118/img0060nw0.jpg
ah the good old days ;)
here are some pics of my air cooled rig. :D
http://i54.photobucket.com/albums/g1...g/DSC00026.jpg
http://i54.photobucket.com/albums/g1.../NBCooling.jpg
http://i54.photobucket.com/albums/g1...0Rig/Clean.jpg
http://i54.photobucket.com/albums/g1...ig/NewLook.jpg
http://i54.photobucket.com/albums/g1...CaseClosed.jpg
that ribbon cable ruins everything
heheheh that big blue thing you mean? :D Will post some updated pics later. I havn't got pictures for my remodded setup. :D
Update, cut out holes in the back for the cable routing, cut the excess front and back factory grills for 120mm fans, upgraded the Wheels to the case , cut out the blow hole in the bottom for swapping cold air. Also you can see some work in progress of my Engravings, it's not done yet, the work is much more advanced right now then you see now.
http://img233.imageshack.us/img233/2949/80151443nk0.jpg
http://img524.imageshack.us/img524/8084/12407784lf7.jpg
you mean the fan in action /w flash?
http://i54.photobucket.com/albums/g1...g/DSC00029.jpg
