Why does no one have died water? Blue UV FTW!
Originally Posted by Kano
cause it plugs the blocks, easier to use UV tubing :)
http://img.photobucket.com/albums/v3...Picture025.jpg
My old Lian-Li, currently saving to redo it.
RBX w/custom plate, Acetal Maze4 GPU, Danner Mag5, BIX w/panaflo L1A controlled by hacked BIOS, ran almost silent 90% of the time, with a decent overclock...
http://img.photobucket.com/albums/v3...torm/8x325.jpg
Twas a decent rig...
http://img67.imageshack.us/img67/55/dsc020923ka.jpg
http://img163.imageshack.us/img163/8423/inside2hy.jpg
http://jmefidelity.squarespace.com/d...ginalSize=true
http://img47.imageshack.us/img47/202...orsmall4kt.jpg
Detail shots:
http://img226.imageshack.us/img226/8...ilsmall5ir.jpg
http://img218.imageshack.us/img218/5...80small7ty.jpg
http://img47.imageshack.us/img47/608...shsmall9ei.jpg
http://img47.imageshack.us/img47/519...gssmall0ah.jpg
Check out the worklog here
Let me know what you think :)
Benchies:
http://img102.imageshack.us/img102/9...perpi1m8nf.jpg
Since these pics ive added Delta fans on top and a Zalman VF900 GPU cooler :)
condenser-style radiator :( :slap: :stick: :slapass: :nono:
My setup.
I wanted to get a pair of those SHE 3 Blade delta fans, but can't find them in stock anywhere. Everything is dead silent, and performing as well as It can since this motherboard has issues overclocking any further due to chipset limitation.
is running the 200watt psu only for a couple of fans and the pump won't blow it ?
It reminds me of Tt's rads... :sick:Quote:
Originally Posted by creidiki
Currently a rackmount case, untill I get a Lian-Li PC-71 and Phase on my CPU.
http://yngndrw.hostilezone.net/Compu...%20Outside.jpg
http://yngndrw.hostilezone.net/Compu...r%20Inside.jpg
JME F1delity, beautiful case. do u use 2 pumps? or one of that is reservoir?
WC update, testing Swiftech parts:
http://img337.imageshack.us/img337/5779/44ug.th.jpg
http://img310.imageshack.us/img310/3590/84vj.th.jpg
http://img266.imageshack.us/img266/2623/98yd.th.jpg
http://img441.imageshack.us/img441/1585/119vu.th.jpg
http://img266.imageshack.us/img266/2055/123ni.th.jpg
:toast:
Krueml. What vga wb is this?
Looks like an innovatek (lots of alu)
OMG! :eek2:
Have 3 Koolace and storm waterblocks. One thing I discovered about the storm is the system has to be extra clean - I didn't have enough Antifreeze and throw in some junk in my rad and the little holes will gunk up. Hydrogen Peroxide works pretty good cleaning out the gummie stuff.:)
Yep, it is.. never had any problems with their coolers..Quote:
But I'll buy a Watercool GPU-X soon..
Good man, i dont have to take the spank squad out of their training room then.
Thank you :DQuote:
Originally Posted by L'enFer
I do use 2 pumps, yes.
JME F1delity, and 1 rad?
2 Rads..One on top and one on backQuote:
Sexy cases guys :p
JME F1delity, thanx (i could not understand: how cuold it work with 2 pumps and 1 rad...:))
krueml Very clean tubing and wiring.:clap:
Thanks you! :)
