stellar numbers ... dammit!
http://hardwaredebate.com.br/forum/a...nt.php?aid=289
http://hardwaredebate.com.br/forum/a...nt.php?aid=290
Ladies, any chance we can stow the bickering and personal attacks and behave like civil people?
No need to make all this stuff so personal. Unless you are a marketer or have huge stakes in a given companies future... why care so damned much? Spend more time using and enjoying said products instead of fighting about why others should and shouldn't use them...
On point, does anyone know if quiet mode / user mode is hardware selectable (ala 6970) or a software option this time?
Some more results R290X vs GTX 780
Attachment 131591 Attachment 131592
*The R290X is eating the GTX 780 at high resolution, these 512bits in normal resolutions should not make a big difference ... but from 1600p being decisive this ...
Yeah, it's kinda a premature ejaculation thing to cry wolf regarding a reference 290X on air OC performance with 100% fan speed & its loudness, while any other high end, reference cards that i know will behave similarly when their fan pushed to the limit, more or less. Any high end reference card with 100% fan speed = loud, and 290X OC potential is still to be known, nothing is set on stone.
It's quite amusing, isn't it ? :yepp:
I'm wondering about the same, it says nothing about the overclock in the article
http://www.techpowerup.com/191312/ra...ats-titan.html
nossy23, any other links?
People, we may as well discuss loudness of waterfalls and how that affects loudness of gpus because SOME people live near them ...
To teh point, there is no data for R290X loudness.So theres nothing to discuss on the matter.
As for PurePC.pl scores, i can vouch that this is pretty not biased site, which normally is pretty professional in their approach, they never do fakes also.So theres that.
As for my own speculation, i think they got AMD`s blessing on releasing those few scores (high res results only) but the testing and platform was their own.
New Hawaii chip looks like a monster performer :). OC and CF two of those and it will be basically untouchable.
I think he's right. Upper bar looks like a 290X overclocked.
I also guess that 2nd bar and third bar are 290X and 780 both@stock.
Hardware info numberz :
http://tof.canardpc.com/preview2/7d9...949813a0de.jpg
That wattage.
Sounds like its back to to 1200w+ PSUs for triple setups.
-PB
I guess my 1600w is good to go!
Benches came originally from over here:
http://videocardz.com/45753/amd-rade...ster-gtx-titan
"The leaker claims that his sample could run at 1020 MHz core clock and 1250 MHz memory clock. That would be the peak performance for the new Radeon (we don’t know yet if this is the reference clock). You may think that 1250 MHz clock for the memory is not very high, but that’s due to wider memory bus. This is in fact 5Ghz effectives peed with a bandwidth of 320 GB/s. The Radeon R9 290X will operate at lower clock (something between 800 to 900 MHz), It has dual-BIOS feature for a reason. "
Thanks for the link but I can't find anywhere in the article about the R9 290X was OC vs reference clocked Titan when tested. It does does not make much sense to compare video cards like that.
Also from the link:
Nothing about overclock in the charts.Quote:
Speaking of power consumption, the leaker also posted his results in this field. Supposedly AMD Radeon R9 290X would consume less power than GTX TITAN (357W vs 372W). EDIT: Since we actually found the original source and thus charts, I suggest you take a look at them and see how each card performs.
I thought the operating clock range for stock 290x is 800-1000Mhz with clocks sittings at 940-960Mhz in vast majority of gaming workloads?
Well provided the GPU clock speed in this chart, from the same link you posted is correct, that's not overclocking.
Attachment 131604
The article you linked was edited and made up from two sources. Most likely all the benchmark come from Chinese forum posts and a lot might have been lost in Google translation.
Good news is we have ONLY few days before the real benchmark. I doubt the R9 290X is going to be faster than the 1000 USD NV Titan. Maybe true in some games and probably more so in high resolutions.
Maybe those charts with 2 bars for 290X mean the "quiet mode" and "uber mode"? I read somewhere that those modes define TDP limits, and thus the card will boost higher on higher tdp limits.
