amazing chipssss dumoooo
@ Andre..your 56X is good too:)
A few more SB to test this weekend and I will play with 990FX UD7...waiting for FX-8150
can not Regt find out of blck on this motherboard, I had it very easy with asrock xtreme6 =107 blck np
has 2 2600K one can x54 and nr 2 will x57 ,would be great to get a handle on blck on the motherboard here
PCI-E voltset where in bios ? my SSD OCZ AGILITY Disk :banana::banana::banana::banana: up when I want to play with blck,or overclock my GFX too high
i had the chance to test an Asus P8P67 LE and it comes ONLY with vcore OFFSET jeeeze, as it was a build for a friend i have to study all, at first i couldnt get the jumps on volts but later it went good, i could also bench it to x54, and i left it stable at x48
so well i learnt another method
Sergio,
you have 2 Intel SSD,right?
Firmware 1.92 is out.
http://downloadcenter.intel.com/Deta...+und+Caching&P
I can only upload somewhere if you want.
Btw,
today is updated v.1.01.40.
Edit:
OK,uploading now....
Here is:
http://www.mediafire.com/?j9vz3lg5yges8fo
http://www.mediafire.com/?gfct97v98inn3cc
Use 7-zip or hjsplit to join the files.
I was able to get it downloaded so I could upload it for download if need be. Let me know. It took like 3-4 hours, haha.
Sorry guys if anyone was waiting. The cpu I picked up was only a 53X CPU. I will now sell that one and buy another one. I will probably give up soon and wait for SB-E
I haven't bumped any voltages for my agility 3 Raid 0 as well, but I'm only on 5Ghz.
Btw yesterday I manually set the pll voltage to 1.75v and my 5ghz is stable at 1.42v in bios with 75% LLC (havent crashed after 4-5hrs of dragon age 2, which it does if its unstable.) :D fingers crossed though.
Yes,v.1.01.40 dated 02.Sep 2011.
Uploading now.....here:
http://www.mediafire.com/?h8e5e1a61va50uk
