m4a89gtd http://www.asus.com/Motherboards/AMD...89GTD_PROUSB3/
posted 8/19 but it has a date from july when you goto flash it. ran it for a few hours last night all seemed ok. will try uping th clocks tonight.
too you people :banana::banana::banana::banana::banana:ing about 890 boards. I was promised a new bios for the 790FX way before you guys were asking about bioses for the 890
The latest BIOS's for the 890 chipsets are Bulldozer BIOS's I doubt if there will be any others before Bulldozer is released.
Any chance for BIOS update for M5A97 PRO? I'm yearning for core unlock stability....
Yes sorry typo or brain out of gear.
Hey tonyb, I just sent an email to ya about the 2002 bios.
I was hoping to get a copy of it.
I recently filed down my chipset heatsink standoffs, helped temp's wise but it still didn't get rid of my stability prob.
I'm all for trying another bios.
The only probs I have now stability wise are the crashing explorer after saving a large file(with opera), pic viewer sometimes has corrupt controls(graphic wise), rotating images using transparent selection in mspaint-win7 ver corrupts a 1/3 of the image.
Games and testing programs are stable.
And the prob I have with burning on any type of dvd (tried 4 diff brands of disks), but I think it's the cable, hoping so, the burner is only a month or 2 older then the board :\ (gotta spare burner so I can figuer it out even if I need to replace it).
I'm using the 1902 bios, like to upgrade to something better.
Edit:
Err couldn't edit my post with the latest opera ver lol
Anyone else got the ch4f 2002 bios that can share?
I'm a bit impatient right now, I'de like to get a new bios flashed and a new copy of windows installed tonight.
Hi m8 BIOS sent, sorry I wasn't on yesterday. I see you have 2133mhz ram are you running it at 2133Mhz? I had a few stability problems at 2133mhz took a bit of fiddling to get it stable at that speed I had to increase the actual NB voltage slightly to stabilize the FSB at 267mhz and you will need to increase the CPU/NB voltage as well. Have you tried lowering the memory speed to see if it makes a difference to your problems? they could possibly be down to memory corruption.
Hey dude thanks for up'ing ;).
And no I don't run my ram at that speed, I couldn't figure it out so I run it at 2000mhz (8-9-7 cmd1).
I've tried tons of things, even rma'ed my ram.
It's gotta be either my ram or my vga card.
I'll try a diff vga card tonight and see if that fixes anything.
I gotta try a diff sata cable for my dvd burner anyways.
Anyways I just flashed the 2002 bios, took me a bit to get back online with it, resources changed with this bios (lan resources changed for sure).
Seems quicker though for some odd reason, shutdown times and the internet seems faster, it could be nothing lol :D.
Is this topics still active. Would like to know what the progress on the Sabertooth 990FX is?
Hey Dave i have the same motherboard and cpu could u send me your settings so i can achieve that 5 GHZ lhouston65@hotmail.com
ASUS M5A87 Bios 0701
CPU FX 8120 overclock 4.0 GHz +
CPU throttle when full load. (multiplier drop)
disable C1E , CnQ , APM but it's not work.
need new bios to fix this problem.
thanks.
whats your temps in Coretemp? I found as problem temps in Coretemp everything more than 70C (real it could be about 80-85 C!).
yep. more than 70 C.
but my gigabyte 990fxa-d3 bios f5c (new beta bios) have APM options in bios and I disable it.
multiplier not drop (temp > 80 C)
old bios (f4) multiplier drop same when temp more than 70 C.
Can we pretty pleeease have induvidual core unlockign for Bulldozer chips on other AM3+ boards? (I know it exists for Crosshair) :)
im using the M5A97 Evo
V-friend: its too much for FX, u need colder temps for not throtling or good stability...Max about 65-66C in Coretemp.
correct as Beep said.
Thanks Beep & FlanK.
There is a new BIOS 3030 available for M4A89GTD PRO/USB3.
I'm surprised :-)
and now wondering if this board will be able to run the next BD generation this autumn.
changelog:
M4A89GTD PRO BIOS 3030
Improve system compatibility.
ftp://ftp.asus.com.tw/pub/ASUS/mb/so.../M4A89GTD_PRO/
