Done. :)
Sorry, man, such stuff happens all the time, I am working with a fecking huge notepad file here to edit all the stuff, you don't wanna see it... :shakes:
In fact, neither do I! :rofl:
I dont envy you or the job with keeping this thread up to date. But we all appreciate it very much, so thanks for all the hard work :)
some_one | i5-655k [2C 4T] @ 4512MHz | 1.4125 Vcore L1 | Gigabyte P55UD6 | Mega, Warm Air (33C)
http://img255.imageshack.us/img255/2892/4512s.png
Using just physical cores with HT still enabled results in higher GFLops and lower power / heat. The dual core difference doesn't seem as pronounced as the higher multicores.
http://img18.imageshack.us/img18/8588/2corexs.png
@zalbard-Awesome!!!:up: Thank you very much, I just noticed that.
I need to give info for my e8400 run, didnt notice that I hadnt before.
Gigabyte EP45-DQ6, Water, Will have to find the chip top get batch#.
Also the last entry for i7-920 4828mhz was the same chip that I used for 4725mhz, 3937B785. It is slowly degrading.:yepp:
i7-870 batch# is L926B294
Shiranui Gen-An | i7 980x [6C-12T]@4498MHz Batch #3005F803T | 1.435v | EVGA E762 4-Way Classified | Air (Venomous X+2x Scythe Ultra Kaze 2000RPM)
With the insanely cold temperatures we've been having in the Atlanta area lately, I decided to give 4.5GHz with HT on another go. I set up my Classified in the garage which currently has an ambient temp of about 11.6°C. It was able to pass 20 runs of LinX at the same vcore that my previous HF-off run needed. I did bump up QPI PLL voltage so this may have had as much of an influence as the low temps.
http://img32.imageshack.us/img32/189...7bclkdomin.jpg
http://img441.imageshack.us/img441/1...7bclkdomin.jpg
Everyone, please make sure to read the changes in the OP carefully before submitting the results. You have to post a screenshot with CPU-Z and LinX running 20th+ pass (means it's still in progress).
Thank you.
I agree this a great idea zalbard :up: prove it if you can pass it 20 times , time to open my windows turn Ht off and slam this baby
@Shiranui Gen-An its the 4.5ghz club :D:D
Shiat! means hv set alarm at 1hour to take screenshot.
OLDcomer | C2Q Q9650 [4C] @ 4599MHz | 1.424 | Gigabyte GA-EP45-UDP rev. 1.0 | Water | L826B006
http://img33.imageshack.us/img33/1142/4600linx.th.jpg
Very nice run :up:
Third submission... i7 920 #3849B018
Ambient temps... ~ -1 C.
Cooling: Air... Megahalems with push/pull.
Vdroop enabled (LLC disabled).
Load:
http://i695.photobucket.com/albums/v...nX4C4Tload.png
Voltages measured with my Fluke during load:
Vcore: ~ 1.322v
Vtt: ~ 1.288v
DRAM: ~ 1.634v
Idle:
http://i695.photobucket.com/albums/v...nX4C4Tidle.png
With the exact same settings and HT enabled I could only net ~ 4.44GHz.
I've had no luck so far with various settings in getting a succesful 20 pass LinX HT at 4.5GHz (the best attempts so far have the o.c. failing between 10 to 15 passes).
Load:
http://i695.photobucket.com/albums/v...HzLinXload.png
Vcore: ~ 1.314v
Vtt: ~ 1.286v
DRAM: ~ 1.630v
Idle:
Very nice OLDcomer :up:
PolRoger... nice low vcore -1oC Brrrrrr
i7 920
Batch: 3918A495
Custom SS
Foxconn Bloodrage GTI
http://img838.imageshack.us/img838/9...6162458.th.jpg
