I will be crunching again in memory of Jon (loonym) as it was his passion and I hope my effort will help someday to find new treatments
Got the UD7 board in this morning, going to test it tonight on H2O outside in the cold with the W3540 and 5970... We'll see what I can do! :)
3d03 5970's scores "fixed", 05 scores "fixed" sort of, aquamark fixed well I saved to usb, bad idea but it moved me no ranks. 320K is a heck of improvement from my 240K........all done in vista ;)
Very impressive scores with your AMD setup and the 5970 on some nice air clocks! :up:
Too bad the multi GPU scores aren't worth much at all anymore... those scores are amazing! :D
320k is much much better but you would be pushing 400k with a i7 system on LN2.... ;)
Nice LN2 S775 CPU run there MTP04! :up:
Jor3lBR, I see you're pushing hard for every gold you can get again... got the X3380 Superpi32M beat today! :up:
Now I guess you need to get the Pifast and Superpi 32M records back with the Q9650.... :p:
@chew
Awesome Aq3! I need to learn the ropes for that bench with ya :clap:
@Linux
Yes I know DDR3 board incoming to get those back I got DDr2 very close on that pifast I did 18.70 against his 18.63 I guess I can squeeze in those 7ms but DDR3 at 1800Mhz would be much easier.
I'm sure you'll make it! :up:
WPrime 32M would look nice though, top five belonging to XS. :D
Did you notice AndreYang and nickshih went back to TeamTaiwan?! More than 3200 points with only two members. Crazy...
Anyone know why they left PURE? I guess it's only a temporary move.
http://img704.imageshack.us/img704/1...anuary10th.jpg
Great work by MTP04 pushing old 65nm Core 2s to the limit on his REX. ( I gotta get one too :D ). :up:
Very nice work thebluemeanie1, scoring almost 55k in 03 with a single 9800 GTX.
Xtreme_Solid has to push some more! :yepp:
A big congrats goes out to Jor3lBR for breaking the Q9550 32M WR yesterday! :clap:
HWBot is recalculating points again, I think we gained some. :)
To the guys that were in Vegas... Brian, Ryan, Charles, Dave and who else. I want to see pics and scores!! :D
Thanks for the kind words Don_Dan and yes if you haven't owned a REX yet and your still benching socket 775 cpus, then I strongly recommend getting one.:D
The SuperPI 1M E6300 run I submitted is garbage and should be quicker for the clocks. I think my OS got damaged from all the crashes I ran into while I was trying for max fsb, I'll probably rebench later on.
About time, wednesday im getting my 15L and 18L filled with some fresh new liquid nitrogen.
Going to bench my 5770 for the last time, but first time on LN2. last time with dry ice on the 5770 i was limited as hell by the temp, so i expect to get 1200+ core. my cpu can go alot higher then previous 5ghz vantage and 06 ( 200 / 300 mhz higher ) , combination of both, with the new 9.12 catalyst should make me reclaim my beloved gold cups!
Going to try to bench aqua / 03 / 05 aswell, so need to try a bit tomorrow if i can get a decent run going on AIR, never really ran those benchmarks actually. o well, lots of fun inc!
Pushed another 5870 on air in Vantage and maxed out at 1064/1272... got a better score than before though my CPU on H2O is still limiting me! :up:
Hopefully I'll get the cascade running again this week and really push some 5870 scores across the board....
@thjis:
Run all of the 3dmark benchmarks! Looking forward to it! :D
Nice work! Almost 100k in 03 is sick! :up:
HWBOINTS revision 3 adjustment "more points for exotic hardware" in effect.
I gained a few points, check your scores! :)
Too bad Smoke joined OCClub a minute ago, they gained 1500 points and two ranks.
Just 1020 points to go into top 10... Let's make it happen! :D
Gotta recruit another bencher, run multiple gpus for team points, push past 300 hardware points for the team, and get on cascade.
There is a little new year's resolution. :rofl:
I'll try to get these goals accomplished this and next month. :D
Hope to see some more results from billdavis and xoqolatl with the new 9.12 driver on their 5870s! ;)
I can't get LN2 temporarily, and benching HD5870 on dice is not fun after you've tried LN2 on them.
I'm going to bench some older GPUs on dice soon.
EDIT: Congrats thijs, you have been mentioned in The Overclocker! Go to http://cde.cerosmedia.com/The_Overcl...bb6e3e3558.cde, page 29.
I still need to freeze one of my REX and the E8600 to get some big points. I'm back to work so probably won't happen till next week :-(
About the server updates: is it just me or after those reviews they mess up with your gold cups. This is the second time after an update that I get Gold Cup results demoted to Silver with less points and there is no Gold result, I still have the fastest time :shakes:
If everything works out I'll grab some hardware points today or this weekend with some stuff coming in and be at 400 points or a little over. :up:
Got LN2 thijs? :D
