Originally Posted by
dejanh
Ok, I have a problem that I am finding rather puzzling...
In the last few weeks I started noticing that my computer would hang at DET DRAM when I am powering it up in the morning and I naturally assumed this is the cold boot issue. However, I found this strange as I managed to eliminate cold boot right around 0705 BIOS so I kept an eye on this and soon after I noticed that this seems a bit different than cold boot, or seems so anyway. Why? Because I cannot get the computer to go past DET DRAM without removing at least one memory stick, the booting, then resetting the BIOS settings to defaults, booting again, shutting down, reinstalling the rest of the memory, and then finally booting up successfully and setting my OC settings in the BIOS again...
Very messed up. Memtest86+ 2.11 and Memtest HCI do not show any problems after testing the memory for 3+ hours at either 1600MHz 7-8-7-18-1T or 1800MHz 8-9-7-19-1T. The system is also Prime stable and LinX stable. All voltages are within normal limits, i.e., 1.36250V CPU, 1.35000V QPI/DRAM, 1.65681V DRAM. The rest is all on auto.
No other apparent problems either. Once the system is up and running I can keep powering it down and powering it back up as much as I want and no effect. However, in the morning it never loads and I always have the same problem. Stange thing is that removing power from the system, using the CMOS reset, anything...well...none of it works :confused:
Only once I do the procedure in the above specified order does the system actually boot. After that it is flawless.
Is my board going on me? I am really at odds with this issue now especially since stress testing shows absolutely nothing, and I mean absolutely no faults, nothing.
