killer stepping pc ice. would you post the codes next time you 're swopping coolers? i find pi stable is very close to 3dmark stable. have a blast
Now I don't have an 64bit motherboard yet, But here are My specs for a new PC I'll be starting on soon:
Zoom3 Specs: (Proposed-rev1)
Silverstone Temjin Black SST-TJ05-BT ATX Tower Case
2-Opteron 244 1.8Ghz cpus
MSI K8T Master2-FAR motherboard (Uses P4/Xeon heatsink mountings)
2-Thermalright SLK-947U + 92mm Tornado Fans
OCZ 512MB PC3200LL (2x256Mb) ECC/Ram
Enermax 470 Watt PSU(from zoom1)
eVGA 5700 Ultra 128Mb agp card(from zoom1)
WD 75GB ATA100 EIDE 7200rpm HDD(from zoom1)
DVD+RW/CD-RW drive(from zoom1)
Microtek 18.1" LCD Monitor(Shared)
Microsoft IntelliMouse Optical 5-Button USB Mouse(Shared)
Logitech 104-Key USB Keyboard(Shared)
OS: Windows XP Pro SP2 v.2180
It's this or a swiftech water cool kit using:
2-mcw6000a water blocks(Xeon mounts),
1-mcw50 northbridge block,
1-Black Ice 120mmx240mm radiator,
1-12vdc swiftech pump,
1-5.25" 2-bay reservoir
2-120mm fans(Chrome),
1-120mm fan to swiftech case adapter,
1-swiftech tubing back plate,
and plenty of hose.
My best OC so far was 2.71ghz stable off a 3000+ @ 1.85V on all air.
http://www.freepichosting.com/Thumbs/421544985/8/1.jpg
Just Got an A64 NewCastle (0421CG) and Abit KV8Pro Ver 1.1 mobo.
http://img.photobucket.com/albums/v1.../A64-Batch.jpg
The paste on the NB was not properly applied.
http://img.photobucket.com/albums/v1...64/KV8P-NB.jpg
here's my results. VCore@ 1.8v.
http://img.photobucket.com/albums/v1...Z2600Ghz-d.jpg
http://img.photobucket.com/albums/v1...A64/san-02.jpg
Basically I want to do 1:1. instead of the current 5:4 Memory Ratio. Should I get OCZ's 3500 or 3700 EB RAMs? another would be Adata DDR500????
htkm, Go for BH5s. You've done vtt mod right? Pull the 3.3v from pin on the bottom of the board where the ATX 3.3v goes to the Leg of Vdimm mosfet and you should be all set. 3.38v vdimm + 1.67v VTT works good together. A Vcore mod should get you more on the clocks.
Cheers man. :toast: a...which one is the Vdimm mosfet? a bit more detail with pics would be really good. and also the VCore mod. :D
Awesome!
Should I disable my k8nnxp vdimm mod to do that?Quote:
And another thing, i have a friend who is going to "buy" a newcastle 3200+ cpu, wich step would he go to? (he has an informatic shop).
welcome tbonekot. nice chip :D
I just got another 3000+ chip but I'm not sure if it has CO or CG stepping is there a way of telling by lookings at the chip. I rather know before hand so I can return it easier.
Quite simple.Quote:
AP = C0
AR = CG (clawhammer)
AX = CG (newcastle)
the first two letter of the core (ex. CAAOC)
CA = CO or CG core
CB = CG (newcastle core)
My new 3200+ 0416 @ 2525mhz and 1.7v vcore. Watercooled. Load spikes voltage to 1.74 or so as seen in the screenshot. Once I get my OCZ DDR Booster I'll do the vcore mod and see it I can do 2.6ghz (260x10) at 1:1.
http://home.comcast.net/~jhatfie/screen_2525mhz.JPG
ADA3000AEP4AX, AX=CGQuote:
2nd ROLL NOS. 0421 is the Batch.
my new config :D
it's faster then 313*8 but i don't know why? :confused:
http://www.forumdeluxx.de/gallery/da.../101731_5V.JPG
well at 313fsb you memory is iether doing 313x166/200=259mhz or 313x133/200=208. if you memory was divided to 133mhz that would explain why it is slower. cpu is the same speed but memory is down from 250 to 208. therefor entire system is slower. if you are using the 166 memory divider then i can't explain the drop in performance unless you dropped the ldt setting or loosened the memory timings
Ldt was the same (3) and the timings also the same!The memory has also the same speed (258) I don't know why its slower then sychron!
http://www.xs4all.nl/~famchow/A64_3400/3.1GHz.PNG
Need a better board to make it stable and a cascade :p:
which board und which ram?
EPoX 8KDAJ rev 1.0 fully moddedQuote:
2x 256MB Kingston PC3200 BH5@2-2-2-5 1T 3.4v
Whooooottttttt :toast:
congratulation :D
wow kakaroto that's very impressive
especially on that 8kda
:toast:
look at my work done last night:
Wich memo and vdimm?
http://home.arcor.de/dresign/forum/P...mhz_1.376v.jpg
what's goin' on guys :rolleyes:
who has the biggest virtual pen*s of the watercooler-guys here, now ? :D
i can't go past 240MHz because my 2x512MB 3700EBs don't wanna go higher with only 2.82V VDIMM (maxed out @ GB K8N-non-Pro)
w8ing for DFI Lanparty-UT :D
