very clean cable management! props to you man!
thanks pal ...
there will pictures from different angles as you requested.
http://img228.imageshack.us/img228/4654/p7030024.jpg
http://img145.imageshack.us/img145/5655/p6150040.jpg
My media server as it sits currently
http://i18.photobucket.com/albums/b1...e/IMG_2611.jpg
What fans are those, firehawk?
Phobya Nano-G 12 (120mm) 1500rpm Multioption fan (waterproof) (64.3cfm - 25 dB/A and the cooler fans are noctua fans whch i sprayed
Her's a ghetto mod i did to my hp cq5320f,and am awaiting dual cold cathode and led fan from performance-pcs.
http://img718.imageshack.us/img718/2708/img1596r.jpg
The ATX posts doesn't fit at all, except the first rad on the left. I used a plank of wood for extending the tray, and made new holes on that. It worked fine and it is still hanging in there :)
I'm still experimenting with the cooling, moved the Megahalem to CPU#2, and changed to Noctua NH-D14 on CPU#1 (which runs hotter, generally). A new picture of the new cooing arrangement.
http://img.techpowerup.org/100707/Capture019.jpg
http://img.techpowerup.org/100707/Capture022.jpg
http://img.techpowerup.org/100707/Capture024.jpg
mine :D
Nothing changed in my spec since 2 years ago ( e8400 @ 3.6Ghz, 4Gb RAM, DFI Lanparty P35, GTX 260 192sp) except for the Filco Keyboard (bought last May) and the Silverstone FT-02 (I bought 2 weeks to replace my noisy CM 590)..
http://i58.photobucket.com/albums/g2.../Photo1301.jpg
http://i58.photobucket.com/albums/g2.../Photo1302.jpg
The only way Im replacing this keyboard is if they'd sell one with volume keys lol..why cant they add such a simple function? other than that its well worth the price I paid for it..the blue LED gets irritating though as it illuminates my room when all the lights are off..its just too bright :(
http://i58.photobucket.com/albums/g2.../Photo1305.jpg
http://i58.photobucket.com/albums/g2.../Photo1307.jpg
By the way, FT-02 isnt much better at cooling over the CM 590..only that it looks better (personal preference), quieter and of course the FT-02 screams high quality over the CM590. So cooling wise, I dunno if the CM 590 (with the 2 top exhausts installed) just has excellent airflow, or the FT-02 isnt that good (at air cooling) as some people say it is
Awesome job on the Basket case lmao.. that is awesome
Geekhack :P
Desolder or use a black sharpie.
I really like the looks of the Filco, I'll see if I can pick up a tenkeyless version this summer when I go to Asia.
New 5850. That is all.
http://img205.imageshack.us/img205/70/pc1q.jpg
Very nicely done hpv500. Is that plexi at the top?
You really like the blue leds on your ram don't you? ;)
thanks JaccoW....its a plexi fixture actually
http://i209.photobucket.com/albums/b...0/DSCF4375.jpg
love those tracers!! :p:
Finished my project a couple of months ago but I thought I'd share.
http://i1021.photobucket.com/albums/.../HazChem02.jpg
http://i1021.photobucket.com/albums/.../HazChem09.jpg
http://i1021.photobucket.com/albums/.../HazChem10.jpg
http://i1021.photobucket.com/albums/.../HazChem11.jpg
pretty pictures ^_^ I absolutely love what you did with the hints of blue here and thar xD
