I want the new bios for better support of the 2x2gb kits!!!!
max fsb stable?
My appologies if this shouldnt be on this thread but I have the UT-X48-T2R and am using 2x2gb gskill 8500 1066 ram. I wondered if anyone could tell me how accurate the memory voltage reading in smart guardian is?
This memory is designed to run at 2.0-2.1v now if I set it to 2.0 in the bios SG reports 1.91 and if I set it to 2.1v it comes in at 2.03v. It would appear to be quite unstable at 2.0v set in the bios but it may just be that I need to work on the timings more.
[edit] bios reports 2.06v when set to 2.1v and it appears to be more stable, still getting complete lockup's in memtest so i'll have to try tweaking some more. maybee I need to up the NB volts.
Regards
BS
I'm getting close to just giving up with this board; no matter what the damn setting it doesn't even like running stock settings. One thing that doesnt make this board easier to use is the fact that it seems little is known about gtls, or how to adjust them effectively without spending your life and soul sitting in a basement trying random settings (Sorry, but this board just pisses me off so far). I'm starting to wonder if my board is just a POS.
The P45 chipset still needs tuning from all board manufacturers. But it looks like the X48 will still be able to hold its own. Top screenshot is from Anandtech on the ASUS P5Q Deluxe. Bottom screenshot is done on the DFI UT X48. Both using OCZ Flex II 2x2GB 1150MHz memory. Impressive when the difference in speeds is taken into account.
http://www.anandtech.com/memory/showdoc.aspx?i=3314
http://www.edgeofstability.com/image...erest_64_l.jpg
I posted a thread on the DK X48 but oh well...it dissapeared.
Does anyone have a DFI DK X48 and has anything good to say about it? or why one should consider the X48 instead of X38 or even P35 ?
am just looking for some info...
thanks
nothing to compare there from my point of view
from different OS optimisations to different system timings
and P45 is "worse" than X48, so X48 has to be faster!
Both screenshots were done with Vista 64Bit. I really doubt that Anandtech is using an optimized operating system. Mine is a stock install as well. The article stated the configuration was stable as is mine. And the timings are naturally going to be different as the chipsets are different. Regardless, both screenshot contains nice results for 2x2GB modules.
which is better, higher or lower numbers?
http://img329.imageshack.us/img329/7...ambenchqf3.png
latency lower
all others higher
does anybody know how to change the tref without having to use memset? or does anybody know the tref per strap? i can only "match" the bandwidth i had on a maximus formula, but cant get to the level that i had on rampage... most likely due to the fact that i cant get pl6 or cas4 + pl5 on this mobo.
A multimeter is useful, as I have found smartguardian is bad at telling voltages. Bios VTT = 1.415 actual = 1.438 with Q6600. Anyone get these results or similar, or am I just reading it wrong?
praz how come the l2 cache latency is so high?
I haven't tried this MB yet (right now, it's at the top of my list;)), but all MBs are notorious for being a little off on the voltage readings (and settings). You really need a multimeter for an accurate reading and setting -- especially if you're planning to push to the very edge.
been playing with the asus p5k deluxe ddr2 version
after 2 days.. into the bin u go.. :P
and back to dfi LP x48.. come home to mama :P
the asus board bios 0405 is freaking flawed..
will wait for more bios update for it
also it has corruption issue with the bios..
one wrong ram timings.. it will revert to the duallie bios to the stock mobo bios which is even worse..
E8400 04/02 BIOS
480x8, Memory 1152MHz
2x2GB OCZ PC2 9200 Flex2
XFX8800 GTS (G92)
Air Cooled - 120 Extreme
tRD - 7, Memset Misreads The Value When Set Manually
Yellow Slots Used For Memory
VDIMM Measured 1.887V
http://www.edgeofstability.com/image...ios/main_s.jpg http://www.edgeofstability.com/image...ios/volt_s.jpg
http://www.edgeofstability.com/image...s/dram_1_s.jpg http://www.edgeofstability.com/image...s/dram_2_s.jpg
http://www.edgeofstability.com/image.../clock_1_s.jpg http://www.edgeofstability.com/image.../clock_2_s.jpg
http://www.edgeofstability.com/image...os/phase_s.jpg http://www.edgeofstability.com/image.../feature_s.jpg
Code:CPU Feature Page
Thermal Management Control................Enabled
PPM (EIST) Mode...........................Disabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Disabled
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown After AC Loss....................Disabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................8x
CPU N/2 Ratio.............................Disabled
CPU Clock.................................480 MHz
Boot Up Clock.............................Auto
DRAM Speed................................333/800
PCIE Clock................................100MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................1.30000V
CPU VID Special Add.......................Auto
DRAM Voltage Control......................1.941V
SB Core/CPU PLL Voltage...................1.510V
NB Core Voltage...........................1.317V
CPU VTT Voltage...........................1.100V
VCore Droop Control.......................Disabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Strong
GTL REF Voltage Control...................Enabled
CPU GTL 1/2 REF Volt.......................65
CPU GTL 0/3 REF Volt......................64
North Bridge GTL REF Volt ................62
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Auto
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
RAS# Precharge (tRP)......................5
Precharge Delay (tRAS)....................15
All Precharge to Act......................5
REF to ACT Delay (tRFC)...................54
Performance Level.........................8
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................1
Write to PRE Delay (tWR)..................13
Rank Write to Read (tWTR).................11
ACT to ACT Delay (tRRD)...................3
Read to Write Delay (tRDWR)...............8
Ranks Write to Write (tWRWR)..............Auto
Ranks Read to Read (tRDRD)................Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................3
ALL PRE to Refresh........................5
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Enabled
Channel 1 Phase 1 Pull-In.................Enabled
Channel 1 Phase 2 Pull-In.................Enabled
Channel 1 Phase 3 Pull-In.................Enabled
Channel 1 Phase 4 Pull-In.................Enabled
Channel 2 Phase 0 Pull-In.................Enabled
Channel 2 Phase 1 Pull-In.................Enabled
Channel 2 Phase 2 Pull-In.................Enabled
Channel 2 Phase 3 Pull-In.................Enabled
Channel 2 Phase 4 Pull-In.................Enabled
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................More Aggressive
DIMM 1 Clock fine delay...................Current 67ps
DIMM 2 Clock fine delay...................Current 445ps
DIMM 1 Control fine delay.................Current 512ps
DIMM 2 Control fine delay.................Current 267ps
Ch 1 Command fine delay...................Current 779ps
Ch2 Clock Crossing Setting................More Aggressive
DIMM 3 Clock fine delay...................Current 67ps
DIMM 4 Clock fine delay...................Current 378ps
DIMM 3 Control fine delay.................Current 356ps
DIMM 4 Control fine delay.................Current 345ps
Ch 2 Command fine delay...................Current 779ps
Ch1Ch2 CommonClock Setting................More Aggressive
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
XP SP3
http://www.edgeofstability.com/image...prime_xp_s.jpg
http://www.edgeofstability.com/image..._3d06_xp_s.jpg
http://www.edgeofstability.com/image..._crysis_xp.jpghttp://www.edgeofstability.com/image...152_ut3_xp.jpg
3dx Max w/V-ray
Time to render: 15min 03sec
http://www.edgeofstability.com/image...chmark_680.jpg
http://www.edgeofstability.com/image...erest_xp_s.jpg
Vista 64 Bit SP1
http://www.edgeofstability.com/image...prime_64_s.jpg
http://www.edgeofstability.com/image..._3d06_64_s.jpg
http://www.edgeofstability.com/image...3dvan_64_s.jpg
http://www.edgeofstability.com/image...cmark_64_s.jpg
http://www.edgeofstability.com/image..._crysis_64.jpghttp://www.edgeofstability.com/image...152_ut3_64.jpg
3dx Max w/V-ray
Time to render: 16min 24sec
http://www.edgeofstability.com/image...erest_64_s.jpg
OK I just updated the UT version bios to my LT board, everything seems to be working just fine. The CPU special VID has been disabled when vcore is set under 1.3000v. The Vcore turns red when going past 1.4500v :) Other than that, no other visible changes (apart from a new POST screen).
I'm still struggling to get my comp prime95 stable with 8 gigs 9x400MHz. I can do 5-8h prime95 blend but after that a BSOD. :(
