Settings are as follows:
Multi: 9
FSB Mem Clock Mode: Linked
FSB Mem Ratio: Synced
FSB (QDR) 1780 (SDR = 445mhz)
LDT Freq: 4x
vcore: 1.32v
CPU PLL:1.54v
CPU VTT: 1.3v
Memory: 1.84v
NB Core: 1.58v
SB Core: 1.55v
CPU GTL Ref0:+42mv (I had one weaker core)
All other CPU GTL's @ Default
Memory timings were all at auto for the prime run, as i said in my last post, im just tightening them up now, but having probs with them actually applying properly. Hope that helps :)
I have a question for
Justifire if your around?
I see here
http://bandwidth.se/thumbs/nouser/img080047c7ab84.jpg you are using thermalright mosfet coolers, but you dont mention in your post which ones? Could you let me know? Did they fit ok out the box? Also, is that an evercool VC-RE on the SB? Cos i have one lying around here that I could use. Just thinking of putting my MCW30 on that NB to cool it down a bit more!
