Originally Posted by
Prodigys
I'm using also the registered non-trail version :) .
I think I'm going to believe JoeBar that the P5E doesn't have the read-out's...
I totally understand what you mean, but if you would think that my chip does 4Ghz on only 1.42Vcore, then I (!) know for sure it can be 24/7 stable on 4.2Ghz ...
For 24/7 use I go till 1.55Vcore, and for now I don't now wich speed I can get on that Vcore, but I know for 95% sure it's higher then 4.2Ghz though ;) .
"I would attempt to boot at your auto settings again and use every utility possible to get the settings used by auto, etc voltages, timings, ram speed, and whatever other settings then try to weed out what settings allowed you to get there.........."
That's what I've tried, I could get till 470 x 7 on all AUTO settings... This was Prime95 stable for 5-6 hours, but when I tried 475 x 7 it would fail within 2 min...
So I know for sure there's is something small that has to be tweaked a little, but what can I do if I don't can read out what the mobo AUTO picks for himself :p: .
BTW, I'm now on 3.8Ghz with 1.36Vcore and he's only 40°C stressed, with a ambient of 18°C, so temps are no problem... Even NB is 37°C stressed with 1.65V right now...
