Thanks for your reply.
By the way, how do you drain the liquid from your system? Any tip on that would nice for us newbies.
I have my "patent" for this :)
First i made some "handy pump":
http://www.abload.de/img/dscf0066kyu6.jpg
I use this "monster pump" :D to suck all liquid from loop ( install to res ). But before that i must unscrew this:
http://www.abload.de/img/dscf00672b09.jpg
After that ... my loop is dry ;) and i can demount all hardware etc.
Duration of this "operation" - 1 min
That is a VERY VERY smart idea, thankyou for sharing it with us Mr.Dentist.
I have been thinking about how to drain my loops easily in the future and not really found any nice solution. This sounds like a really cool idea, have to give it a try. Is that fitting your highest point and you can still suck the liquid out?
Lol
why didn't I think of that. Nice one
Now I need to make pump for myself.
If you made a video for this, i reckon lot of people interested in watercooling would watch it.
Plus we could see it how easy it works.
Kindly make a video next time you are planning to drain your system.
Again, thank you for sharing this with us
What a great idea! With these secrets revealed a can finally carry out my master plan!!! (insert evil laugh here)
My opinion is a little late, but I'm glad you are going with custom backplates for the gpus instead of using one VRAM block. The VRAM block just look to bulky on your setup. I think the backplates are going to look a lot better.
-TadZilla
that`s really a good idea!! simple and stylish... :D
either a regular backplate or both need that massive thing.
ram needs the cooler... if for no other reason than it looks awesome
Malik good ideia but i dont get it how it really works .. its a kind of pump i guess
Nice time you drain the system do a video ! :D
OK :) I will make video next time ;)
I'll look forward for it.
Hey Malik
I got question regarding coolant.
You mentioned on this thread that you mixed primochill bloody red with feser one. Feser one doesn't recommend mixing fluids even with different colours from Their brand.
I want to get special green colour. Is it ok to mix them? Did you have any problem mixing different brand coolants to get the desire colour?
No, i don't have any problems with that.
QPI rev.2 - ready:
http://img8.abload.de/img/110zt.jpg
Some update:
- second SLI connector
- QPI block rev.2
New chrome backplates - in progress
For now:
http://www.abload.de/img/2pqqy.jpg
http://www.abload.de/img/31p8x.jpg
http://www.abload.de/img/4jyn1.jpg
http://www.abload.de/img/9du4p.jpg
http://www.abload.de/img/8p6mi.jpg
http://www.abload.de/img/7i5m3.jpg
http://www.abload.de/img/5cam3.jpg
And some HD shots:
http://www.abload.de/thumb/hd1f6wn.jpg http://www.abload.de/thumb/hd2051d.jpg http://www.abload.de/thumb/hd3wu5v.jpg http://www.abload.de/thumb/hd47un7.jpg http://www.abload.de/thumb/hd53u86.jpg
malik. first of all amazing builds you have man...two thumbs up. just wanted to ask a quick question though if you dont mind. the red build that you had done before, can you please tell me which coolant did u use? i really want to get the same blood red colour that you have in your build, but im a bit confused as to which coolant i should get. Thanks
hi Malik :)
Your work is wonderful! Amazing! Very beautiful:clap:
So many blocks and rads with only 1 pump?
Phil
Very nice build Malik!
Question: Do you notice any temp differences when you added the second SLI fitting? I know there are alot of topics regarding this but I'm just curious :D
I have mixed feser one uv red with primochill bloody red
Yes, and everything is ok, performance is also very, very good.
Yes, after added the second SLI connector temps are better on gpu about 2-3 degrees, and flow is better about 5-8l/h
Hey Malik
I've been following your worklog for a while now and all i can say is it looks absolutely fantastic! Like a work of art! :cool:
One question though, what blue coolant did you use that you have in the latest pictures?
Cheers
Malik,
Which version of the BP D-Plugs did you use between your vid cards?
I presume they are only one slot away from each other, so curious which length of D-Plug fittings you used. They look like the 35mm, BP-WTP-C38 ones, but not sure.
So I'm back again after a long break with the busy family. Now it's time to water coanother rig. I want to get some input on whats new during the last year for cooling. I loked through a lo of the cools pix you guys posted. Great job.
What can you guys say about these parts for the new water transition?
Here's my runner up for CPU; Swiftech Apogee XT CPU Waterblock but I' like to know more about the EK lighted clear top model used in this forum. For Rad I am leaning towards the XSPC RX240 Dual 120mm Radiator but have took notice to the Phobya G-Changer 240. Can anybod here confirm if the same x58 NB/SB link type blocks fit the X58 micro Rampage II Gene? What is a good strong but yet quiet pump for today?
I had my eye on the Eheim HPPS i High Power 12V Water Pump or the Laing D5 Vario/Swiftech MCP655. My old one had the fan wire sensor I like that. My end goal here is for a quiet daily overclocked rig but with room inside to chill for fun overclock tweaks on new parts when needed.
I plan to cool the i7 920 in my old mobo moved to the Gene and a single GTX-260, NB/SB, Mosfet, RAM and hard drive water bags.
I'm totally open to other to other high end parts if ypu have links or pix I ca see.
WOW thats serious blockage
just get better
what temp difference did you notice by going from the ht too hf cpu block
also what insert plate did you use in your hf
and final what size bitspower comression fittings and tubing are you using
i'm falling in love again !!!! :D
