Does anyone here have like a how to on removing the NB heatsink?
I pushed down on 2 of the wires on each side of the HS(wire clips diagonal from each other) at the same time and then released the other one at a time..very easyQuote:
Originally Posted by XeRo
hey guys.. help please..
I have a corsair 1 gig (2x512mb) 8000UL
I can run DDR2 800 3-3-3-6 1T
but I cant run DDR2 1000 5-4-4-9 2T (spd timing)
I can't pass DDR2 400 in any timing.. why is this.. the debug LED says "C1"
Bingo13, sir Tony anyone.. please help
can you help me with the setting.. mm.. i hope its not a bios issue.. anyone tested corsair 8000UL in this board????
Sounds like we're gonna need a list of RAM kits that make RD600 happy. :P
d9gkx from cellshock done pretty well. Bingo suggested ram need to be run at ddr1120 or so at cas 4, so I gave it a go and it worked out pretty well.
http://img413.imageshack.us/img413/935/45stable4tj.jpg
I only post this to confirm there are no d9gkx issues if setup right. Vdimm is 2.46, which is not as high as some modules need to go this far and 21 hours of blend proves it's quite stable too..
I'll start that list. RD600 loves TeamXtreem D9GMH. Currently at 575mhz SPI 32M @4-4-4-7. More to come ....... :)Quote:
Originally Posted by Polynikes
http://i14.tinypic.com/4bxogpj.jpg
Damn, I should've gotten some of that RAM. My G.Skill DDR2-800 isn't D9 chips and it can't get any higher than DDR2-889. :( I figured almost any (or even all) DDR2-667 kits would be crap chips.
Then again, those 2GB kits are in the $300's, while my 2GB kit was only $200. :)
yup.. i think we need a list.. mm.. if anyone have 5400UL or 800UL please test on the DFIRD600 confirming my findings..
hey anyone ot g.skill HZ in DFI RD600.. gonna buy these mems.. please post your results.. :)
calling bingo and sir tony.. could you test corsair 8000UL on your rigs.. these are old modules of micron fatties.. please help.. :)
I'm at work right now but I'll be home in a couple hours. I'll test some 8000UL's for you then. What specific speed & timmings were you looking for @ 1T? For G. Skills click link in sig of RD600 & 6400:)
Pretty sure Tony won't test any Corsair... :ROTF:Quote:
Originally Posted by erwinz
Bingo might help there ;)
hmm so RD600 dislikes fatbody? :(
Originally Posted by The Nemesis
thanks.. :) I will be looking forward to it.. :)
I think 1T is not a problem to me.. I think.. I can do DDR2 800 3-3-3-6 1T 2.8V
but I can't pass DDR2 800 2T
the 8000UL can do DDR2 1000 5-4-4-9 SPD timing on the DFI Infinity no problem.. but I can't do it in th RD600..
I will be looking forward for your test,.. :) I will be buying a G.Skill HZ.. :)
please post your bios config.. :) a little reference.. this board is giving me sleepless nights.. hehehe :)
hahahaha SO sorry.. :) I would really like to buy OCZ products.. but in our country there is no means.. you'll be paying 3x the memory worth to get it here.. no local distributor.. :(Quote:
Originally Posted by RyderOCZ
My 8000UL's will not boot@ DDR-2 1000 up to 2.35v (C1 error) in orange slots with one or two dimms. In yellow slots using two dimms,same result. Using one Dimm in yellow slot nearest ATX connector system booted fine & completed Pi. Looks as though the board needs to be tweaked for fatbodys. This is indeed a disappointment.:(
waaaa.....
now i think its confirmed.. :( DFI tech please fix these problem.. :D pretty please..
anymore people have these problems..
thanks Nemisis.. :) I thought I'm doing something wrong.. hehehe :D btw nice clocks there.. I hope to be getting a G.Skill HZ also.. I hope to reach your clocks.. :)
@raju: very nice results, I'm glad that the cellshocks work nice on this board :D what are you cooling that setup with? can you post some temps please? thnx ;)
Originally Posted by marauder16
cooling is single stage 'vision', in the phase section, there is some info in a thread somewhere in I believe. Cellshock works great thus far can't complain at all..
regards
Raja
I just bought some memory for this motherboard any clue if it is d9gkx?Quote:
Originally Posted by raju
http://www.ocztechnology.com/product...2_dual_channel
This is my first computer build (total rookie here) and I am in the process of buying all the parts and finding out its expensive, soon I will be eating hot-dogs and rice and living on tap water. Here is what i have so far to date below still looking for any advice of what else is needed for a complete system.
DFI LANPARTY UT ICFX32OO-T2R/G
CORSAIR 620W PSU
POWERCOLOR X1900XTX
2 RAPTOR X 150GB HARD DRIVES.
THERMALTAKE ARMOR Jr. CASE
INTEL 6700 CPU
OCZ VX2 DDR2 PC2-8000 / 1000 MHz / Titanium Alpha / Voltage eXtreme 2 / Dual Channel
That Board loves for sure D9GKX :toast:, had some fun with my G.Skill 2GBGA PC6400 @ PC8500 ->
CPU: Xenon 3060 L631B115 @3,6@1,312V
RAM: G.Skill 2GBGA (D9GKX) @2,3V
http://img259.imageshack.us/img259/7...m1678bx.th.jpg
Off now for more fun :clap:
nice clocks.. :) very nice cpu.. :)Quote:
Originally Posted by Pete@X
ty ... and itīs not the end of the 2GBGA ->Quote:
550 now:
http://img255.imageshack.us/img255/2...m1670wk.th.jpg
That's pretty nice for a first-time setup. You're just diving right in, aren't you? :)
When I took off the paste on the NB, is it ok if that white foam thing comes off?
No that foam prevents the heatsink from crushing or chiping the chip. It allows pressure to be applied somewhat evenly intead of one area which can cause damage.
A lot of people recommended that the foam shim be taken off, I did it and the temperature has been reduced as well. I say as long as you don't apply an retardedly insane amount of pressure when reinstalling the NB heatsink, you should be fine.
