Can someone please help as to why it takes 5 mins to boot when i plug in my printer usb? It takes about 5 mins at post when it says it's detecting USB mass storage device.
Thank in advance,
Thank in advance,
Thanks alot, much appreciated. I'll try this in a minute and report back.Quote:
Originally Posted by catscit
My settings are stable (a modest 401 x 8 MHz). This happens once a week or so.Quote:
Nah, no go. The ICH7R RAID doesn't find the drive. It just finds the other 320GB drive I have connected to the third ICH7 slot, and it says I can't create a RAID with just one drive. I'm majorly confused by this :slapass:Quote:
Originally Posted by jagt
Is there any BIOS settings I need to adjust? Any jumpers?
all these integrated to the mobo raid implementations are NOT true hardware raid... they all pretty much suck imo. if you want to use raid, go out and get a raid card, like a decent Promise or RocketRaid SATA raid card.. even those rely on the cpu (to do most of the raid parity and interleaving calculations) but they're a HELL of a lot better than these onboard raid solutions.. anyways, my $0.02
Only the EZ port on the right can be used as ICH7 port4. To enable this function, simply remove both EZ Backup jumpers. The drive should be picked up like any other ICH7 connected drive.Quote:
The "EZ BACKUP" Raid is true hardware RAID. But it doesn't come with cache and is too slow to be of any use.Quote:
Originally Posted by revenant
That may be true for Windows, but is not for Linux. Linux users should use Linux Software Raid which is usually faster than any affordable hardware RAID solution (and can be moved across controllers).Quote:
Zalman CNPS7000. It's quite, but I'm definitely not too happy with it.Quote:
Originally Posted by rob725
With my E6600 being able to do 3.24Ghz stable at default voltages, I know it has much more in it, but I can't go there with the temp increases I see with any increase in voltage.
Yay! I got it working. One of the SATA cables that followed the mobo is not working right. I swapped it out, and ICH7 found the drive no problem. :woot:Quote:
Originally Posted by coredump
Now I need to figure out how to short down post times (Qfan is already disabled) and how to get the mobo to read SPD correctly. Somehow it sets the timings to 5-5-5, while they should be 4-4-4. Any ideas?
Thanks a bunch!
I presume that the real cold boots are still there on the P5W-DH ? ( the shutdowns on starting ( and restarting ) and the fan and HDD power downs with the scary clicking when overclocking between 375 and 475 mhz fsb ) ,
damz Asus, FIX THIS chipset strapping trfc / Trc bla thing since this is supposedly your high entry freaking level board ..... !!
AndreYang just told me that cold booting on P5W64 and WS pro is only on re-start ( if you rest the system 1 ~ 5 min the problem is gone ) and that it`s cold booting just fine with OC settings so it can be done.
very unprofessional
good that it's working now, i've tried and both orange ports can be used.Quote:
To slow down boot times:
- disable each ide port not used in the bios (not installed setting)
- disable each qfan, and set each rpm to ignore.
works for me, boot times are really fast, only 3-5 seconds from post beep to windows splash screen, with 5 sata drives and plenty usb devices attached!
Okay, I got my boot times down to an acceptable speed. Now I need to figure out why the mobo is reading the SPD timings wrong. CPU-Z clearly reads 4-4-4-12, but the mobo sets them at 5-5-5-12. Any ideas? I'm using bios 1407.
The transformation from AMD to Intel has'nt been an easy one so far :P
Oh, and where can I check memory voltages? Doesn't say anywhere!
Im still playin with my retail e6600. So far ive managed 3.6Ghz with my corsair XMS2 6400 Cas4... 400X9 1:1 Ratio..it would be nice if we could have some pics of bios settings also who is using the latest bios 1407?? any good?? i know it allows lower multipliers..Quote:
Originally Posted by ruler22
I suppose the main thing i wanna know is how good is my RAM. It supports EPP and is SLi ready apparently. I found some info on Corsairs site it refers to intels Nforce5 590 chipset. Any way of disabling EPP?? Does it affect RAM overclocking?? Any1 have the same memory?
Thanx in advance
Irfy
Are you running your ram with SPD timings? If not, could you try setting it to SPD and see what timings the motherboard chooses? I have the same sticks.Quote:
Originally Posted by irfs
I have the same memory. Mine tops out @ 450(900)mhz @4-4-4-12 with 2.1v. Will go past 1000mhz with 2.35vdimm. Happy with them tbh.
irfs: EPP is just additional timings stored in spare space on the memory modules. I believe the chips are originally specified at 5-5-5-15, but if you have a 590 board and you enable EPP in bios, it'll change timings to 4-4-4-12 on its own. My modules are able to do 4-4-3-10 @ 903MHz orthos stable (large ffts), but not gaming stable. Currently running them at 903MHz @ 4-4-4-12. Haven't really tried finding best possible timings yet as I'm still playing with my 6600.
Thanx for the replies guys!! Do you think having 4gb is limiting the overclock?Quote:
Originally Posted by Ic3man
Im gettin rid of 2GB tommorow so i may aswell test'em now while i got the chance. Also is anyone runnin 1T or is this simply impossible?
PCie frequency ? 100 or more?
ICH voltage ?
Hyper 3 enable or disable
which is best bios? ive tried 1305 (works well) trying 1407 now
any input would be greatly appreciated...thanx
With 4GB it's supposedly recommended with x64 OS...
This is what im running.Quote:
Originally Posted by Capo Crimini
i got a better oc with 1407 than with 1305, i didnt have to use as much voltage to achieve teh clock, before i couldnt reach 3.3ghz without reaching 1.46, i reached 3.5 with 1.475v
I get crap OCs with this BIOS. I was able to take my 6400 to 3.6GHz with 450MHz FSB on the 1403, but with this one I can't break 333MHz FSB. I don't understand how Asus could have broken the BIOS so bad...Quote:
Originally Posted by Timmaah
I have:Quote:
PCie frequency 110
ICH voltage Auto
mIch 1.65
Hyper 3 disable
Bios 1407
Originally Posted by Stiffler
sounds unlucky, i got the e6600 and all seemed to work better this time round, i posted 3.6 in bios with 1.5vcore but it wasnt at all stable, wouldnt go into windows and i dont want to be putting more vcore through my new setup so i just let it be.
Have you tried the 1403 BIOS?Quote:
If I have my external WD drive powered on before I boot, my system will not boot and I get an error message that I need to boot off a valid drive. My BIOS settings do not point to this external USB hard drive, but if it is powered on, it prevents my system from booting off of my C drive.
The WD external drive has Dantz Retrospect backups on it (if that matters). Is my master boot record screwed up? I did recently install Acronis True Image Home, which could have changed my master boot record. I don't even know the file name or location for the master boot record (Win XP Pro).
System boots fine when the external WD drive is powered off (I do not even need to go into BIOS to change anything). No BIOS settings seem to point to external USB drives for booting. Very strange. Any help???
