@Felix: Could you please add Clarkdale CPUs such as i3-540 if you have a free minute :)
:rolleyes: :up:
First thanks for yours supports guys! (I've never doubted having) :)
=>WonderSausage: sorry for your handicap, but It does not authorize you to be aggressive.
It's not necessary to be "touchy-feely" as you said in your post, simply polished.
Do you think that overclockers and Hardware enthusiasts are teenagers pre-pubescent and pimply... :rofl:
a lot of us have 30 years and over , including me, and, as donmarkoni said:
"Doesn't matter if someone is younger if he knows more I'll gladly read and learn and respect him/her."
You prove to me that intelligence is not the privilege of old age.
I tried to explain to you why I added this limitation, but you don't understand it and I renounce explain again.
Here is a cpu-tweaker version with fixed DPI size problem: CPU-Tweaker13b3.zip
In my lap I have a request to do: please don't post in this thread in future... thank.
Once again you prove how great guy you are making changes to your application right away. :clap:
Many thanks for making this software in your free time and with no financial gain at all.
It is essential for overclockers like a knife and thread for surgeons (yeah, I'm full of crap :rofl: but that is how it is. :yepp:)
And I support you in your kind request for him not to post here any more.
...I didn't receive anything, try to copy/paste the dump here. (use the # Code balise)
Does PC-Tweaker have incompabilities with P55 chipset? Cuz I'm able to open it just fine but can't change any timings, when I click on apply nothing happens and when I open PC-tweaker again the values are back to what it was before.
Running on Windows 7 x64 RC1, i7-860, Gigabyte P55-UD5, PC-tweaker 1.3 beta 3 and 2 tested.
Some BIOS versions / motherboards are locked and don't allow timings changes through Windows, most likely your board is one of those.
I have a Gigabyte board, they shouldn't belong to that category AFAIK (Gigabyte and ASUS were mentioned as compatible a few pages ago I think). I'm using beta bios F5d. And the timings aren't greyed out (which I've seen is the case for some ppl here), I can change them in the drop down list but it simply doesn't save the changes. In the past with memset the timings were simply greyed out for me when MCHBAR was locked.
Can any1 else with a Gigabyte P55 board confirm this? I haven't reinstalled OS since I upgraded and MemSet wasn't uninstalled b4 I installed the new parts so this may possibly be causing conflicts.
=>RPGWiZaRD: could you make a registers dump (with cpuz->last table->registers.txt)
and send it at memset@hotmail.fr .
Thank.
=> RPGWiZaRD: could you try this version: CPU-Tweaker13b3.zip and tell me the result...
Wasn't expecting a response so quickly. :o Works now, THANKS!! You're da man! :clap:
EDIT: Well apply button is working but not "Save" but that's fine. Won't be able to save settings for a reboot. Still keeps saying "Delete save?" whenever I click on the save button and how many times I do it.
Good new if it works, but I don't understand: I need to apply the same unlock procedure than Bloomfield,
contrary at what is indicate in the Lynnfield datasheet ?!? :confused:
But the essential is it works well. :)
EDIT: for the Save problem, could you check that you have a memsave folder in C:\Windows
and tell me what's in that folder;
After, delete this folder and the cpu-tweaker shortcut in the startup folder...
I think I see why it has problem about saving, there's COPYRIGHT.txt, MemSet.exe and MS.ini files in C:\Windows\Memsave\ -- isn't that what belongs to MemSet? :rofl: Like I said I didn't delete memset b4 I installed my new hardware and I deleted memset folder afterwards but couldn't find where the settings folder was stored which is appearently C:\Windows\ now. :p (was under C:\ when I used an older version in Win XP)
EDIT: Saving works after deleting that folder. :)
Hey Felix, I got something that may help you but don't know for sure. On my P6T6, I obviously can't apply any changes, but when I put the system into S3 sleep and wake it up I can make changes and apply them and they work. I don't know if that is any help at all. Just thought I would throw that out there for you just in case. Let me know if you need anything that might be of help. This was on the 1.2 release, no beta.
Sorry for my inactivity, those days I was very busy!
Here there are, FELIX:
Code:CPU-Z TXT Report
Binaries
CPU-Z version 1.52.1
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium E2220
Codename Conroe
Specification Intel(R) Pentium(R) Dual CPU E2200 @ 2.20GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.F.D
Extended CPUID 6.F
Core Stepping M0
Technology 65 nm
Core Speed 1203.1 MHz
Multiplier x FSB 6.0 x 200.5 MHz
Rated Bus speed 802.1 MHz
Stock frequency 2200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 11.0x
Max VID 1.325 V
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008006h
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 1 MB, 2 thread(s)
CPUID
0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000006FD 0x00020800 0x0000E39D 0xBFEBFBFF
0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB43078
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x04000121 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04004143 0x00C0003F 0x00000FFF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x00000220
0x00000006 0x00000001 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000400 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20100000
0x80000002 0x65746E49 0x2952286C 0x6E655020 0x6D756974
0x80000003 0x20295228 0x6C617544 0x50432020 0x45202055
0x80000004 0x30303232 0x20402020 0x30322E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x04004040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x00000017 0x00000000 0x8B008B28
MSR 0x000000CD 0x00000000 0x00000802
MSR 0x0000003F 0x00000000 0x000000EA
MSR 0x000000CE 0x001D0B28 0x7F7F0616
MSR 0x000001A0 0x00000040 0x62972489
MSR 0x000000EE 0xA8000000 0xC37D4700
MSR 0x0000011E 0x00000000 0xBE702105
MSR 0x0000019C 0x00000000 0x88320000
MSR 0x00000198 0x0B280B28 0x06000B28
MSR 0x00000199 0x00000000 0x00000B28
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008006h
CPUID
0x00000001 0x000006FD 0x01020800 0x0000E39D 0xBFEBFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x0000019C 0x00000000 0x88300000
Chipset
Northbridge Intel P45/P43 rev. A3
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual, (Symmetric)
Memory Frequency 401.0 MHz (1:2)
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Cycle Time (tRAS) 18
Row Refresh Cycle Time (tRFC) 52
Command Rate (CR) 2T
MCHBAR I/O Base address 0x0FED14000
MCHBAR I/O Size 4096
MCHBAR registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10 00 00 00 80 00 A0 02 02 F7 37 64 DF 00 00 00 00
20 01 30 03 00 00 00 00 60 00 00 00 00 53 4A 04 00
30 86 5A 1F 00 10 28 90 01 00 00 00 F7 10 44 01 23
40 08 80 03 8F 00 C0 6B 00 00 00 00 00 00 00 00 00
50 01 00 84 00 02 01 8F 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 55 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 40 12 00 00 D8 00 00 00 00 00 00 00 00 00
B0 00 00 D8 00 00 00 00 00 00 00 00 00 00 00 D8 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 00 00 00 00 00 10 00 00 00 08 00 08 00 00 00 00
110 45 2C 00 00 00 9A 00 AA 58 21 7E 81 00 08 7D 00
120 5F 7F 8D 50 07 E0 3B 40 05 1F 80 00 A0 66 00 5E
130 A2 FF A9 9F 00 3C A6 29 9C 0D D4 40 1C 0E D4 40
140 49 22 0A 01 89 22 12 01 9A A6 42 01 1B A7 5A 01
150 00 00 00 00 00 00 00 00 00 00 00 00 48 82 24 06
160 99 09 00 00 0F 2E 2F 26 00 00 00 00 00 00 00 00
170 00 00 00 00 00 10 00 00 35 01 00 00 00 FF FF FF
180 04 0D C8 00 FF FF FF FF 11 BF 0F 0F 00 00 00 00
190 00 00 01 0F 33 00 00 00 AA AA AA 22 19 32 00 00
1A0 03 18 55 00 40 00 00 00 F1 00 00 00 DF 00 26 01
1B0 00 03 00 00 C0 01 00 00 00 00 00 00 02 04 06 08
1C0 20 03 00 00 00 80 00 00 00 00 00 00 00 00 00 00
1D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
200 10 00 20 00 20 00 20 00 86 86 00 00 00 00 00 00
210 3F 00 7F FF 00 00 00 00 00 00 00 00 00 00 00 00
220 17 11 00 58 01 02 23 00 02 00 00 00 00 00 00 00
230 00 00 00 00 00 00 00 00 00 14 00 00 89 7B 00 00
240 03 11 00 01 10 23 05 00 33 64 C6 0E 00 22 43 00
250 D5 03 34 CE 06 04 68 64 46 C5 0C 34 0E 12 A5 15
260 C9 3C 37 0B 89 00 0C 13 4A 30 CC CF 33 5F 55 03
270 00 0E 55 01 01 64 08 00 81 18 14 88 41 00 04 48
280 00 00 00 00 00 00 00 00 00 02 04 08 10 20 40 FF
290 1C 09 F2 04 00 00 00 00 11 00 00 00 6B 06 00 00
2A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2B0 00 00 00 00 00 00 00 00 00 18 06 00 70 70 70 00
2C0 F0 C5 0C 48 7C 00 00 00 00 00 00 00 00 00 00 00
2D0 00 31 28 FF 00 36 45 40 00 00 00 00 00 00 00 00
2E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
300 08 0A 0B 0C 01 02 04 06 00 00 00 00 05 14 04 EC
310 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 0A 00
320 00 00 00 00 00 00 00 00 00 00 04 04 04 04 05 05
330 05 06 07 08 09 09 0A 0B 0C 0D 04 04 04 04 05 06
340 07 08 09 0A 0B 0C 0D 0E 0F 10 04 04 04 04 05 05
350 05 06 07 08 09 09 0A 0B 0C 0D 04 04 04 04 05 06
360 07 08 09 0A 0B 0C 0D 0E 0F 10 00 00 00 00 00 00
370 00 00 00 00 0C A0 00 00 AA AA 00 00 00 00 00 00
380 00 00 02 02 02 02 02 02 02 03 03 03 04 04 05 05
390 06 06 02 02 02 02 02 02 03 03 03 04 04 04 05 05
3A0 06 06 0C A0 00 00 77 77 00 00 00 00 00 00 00 00
3B0 02 02 02 02 02 02 02 03 03 03 04 04 05 05 06 06
3C0 02 02 02 02 02 02 03 03 03 04 04 04 05 05 06 06
3D0 0C A0 00 00 77 77 00 00 00 00 00 00 00 00 02 02
3E0 02 02 02 02 02 03 03 03 04 04 05 05 06 06 02 02
3F0 02 02 02 02 03 03 03 04 04 04 05 05 06 06 0C A0
400 00 00 77 77 00 00 00 00 00 00 00 00 03 03 03 04
410 04 04 04 05 05 06 07 07 08 08 09 09 02 02 03 03
420 03 03 04 05 05 06 07 07 08 08 08 08 0C A0 00 00
430 77 77 00 00 00 00 00 00 00 00 03 03 03 04 04 04
440 04 05 05 06 07 07 08 08 09 09 02 02 03 03 03 03
450 04 05 05 06 07 07 08 08 08 08 12 00 00 00 12 00
460 00 00 12 00 00 00 12 00 00 00 00 00 00 00 00 00
470 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
480 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
490 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4B0 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
4C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
500 39 39 39 39 49 49 49 49 59 59 59 59 69 69 69 69
510 0A 0A 0A 0A 18 18 18 18 57 57 57 57 26 26 26 26
520 52 52 52 52 62 62 62 62 03 03 03 03 03 03 03 03
530 33 33 33 33 02 02 02 02 31 31 31 31 30 30 30 30
540 55 77 92 00 55 77 92 00 55 77 00 00 55 77 DB 00
550 55 77 92 00 55 77 00 00 44 77 FF 00 55 77 6D 00
560 73 00 00 00 72 80 00 00 73 00 00 00 73 00 00 00
570 73 00 00 00 75 00 00 00 74 00 00 00 77 00 00 00
580 43 5B 5B 00 32 32 32 32 00 00 00 00 55 55 00 00
590 55 55 3C 1E 68 00 00 80 00 33 00 00 CC CC F1 00
5A0 10 0C 00 38 00 00 00 00 00 00 00 00 00 00 00 00
5B0 00 00 00 00 FF FE 01 00 FF FE 01 00 FF FE 01 00
5C0 FF FE 01 00 07 18 00 00 55 55 55 55 55 55 55 55
5D0 55 55 55 55 55 55 55 55 0F 72 00 00 80 3F 00 00
5E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
5F0 FC 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00
600 10 00 20 00 20 00 20 00 86 86 00 00 00 00 00 00
610 32 02 64 28 00 00 00 00 00 00 00 00 00 00 00 00
620 17 11 00 58 01 02 23 00 02 00 00 00 00 00 00 04
630 00 00 00 00 00 00 00 00 00 14 00 00 89 7B 00 00
640 03 11 00 01 10 23 25 00 33 64 C6 0E 00 22 43 00
650 D5 03 34 CE 06 04 68 64 46 C5 0C 34 0E 12 A5 15
660 C9 3C 37 0B 89 00 0C 13 4A 30 CC CF 33 5F 55 03
670 00 0E 55 01 01 64 08 00 81 18 14 88 41 00 04 48
680 00 00 00 00 00 00 00 00 00 02 04 08 10 20 40 FF
690 1C 09 F2 04 00 00 00 00 11 00 00 00 6B 06 00 00
6A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6B0 00 00 00 00 00 00 00 00 00 18 06 00 70 70 70 01
6C0 A0 34 20 80 02 00 00 00 00 00 00 00 00 00 00 00
6D0 00 00 1D 0F 00 00 00 00 00 00 00 00 04 02 01 08
6E0 00 00 00 00 04 02 01 08 00 00 00 00 04 02 01 08
6F0 00 00 00 00 04 02 01 08 00 00 00 00 00 00 00 00
700 00 00 00 00 00 00 00 00 00 00 00 00 02 01 08 04
710 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 0A 00
720 00 00 00 00 00 00 00 00 00 00 04 04 04 04 05 05
730 05 06 07 08 09 09 0A 0B 0C 0D 04 04 04 04 05 06
740 07 08 09 0A 0B 0C 0D 0E 0F 10 04 04 04 04 05 05
750 05 06 07 08 09 09 0A 0B 0C 0D 04 04 04 04 05 06
760 07 08 09 0A 0B 0C 0D 0E 0F 10 00 00 00 00 00 00
770 00 00 00 00 0C A0 00 00 AA AA 00 00 00 00 00 00
780 00 00 02 02 02 02 02 02 02 03 03 03 04 04 05 05
790 06 06 02 02 02 02 02 02 03 03 03 04 04 04 05 05
7A0 06 06 0C A0 00 00 77 77 00 00 00 00 00 00 00 00
7B0 02 02 02 02 02 02 02 03 03 03 04 04 05 05 06 06
7C0 02 02 02 02 02 02 03 03 03 04 04 04 05 05 06 06
7D0 0C A0 00 00 00 00 00 00 00 00 00 00 00 00 02 02
7E0 02 02 02 02 02 03 03 03 04 04 05 05 06 06 02 02
7F0 02 02 02 02 03 03 03 04 04 04 05 05 06 06 0C A0
800 00 00 77 77 00 00 00 00 00 00 00 00 03 03 03 04
810 04 04 04 05 05 06 07 07 08 08 09 09 02 02 03 03
820 03 03 04 05 05 06 07 07 08 08 08 08 0C A0 00 00
830 00 00 00 00 00 00 00 00 00 00 03 03 03 04 04 04
840 04 05 05 06 07 07 08 08 09 09 02 02 03 03 03 03
850 04 05 05 06 07 07 08 08 08 08 12 00 00 00 12 00
860 00 00 12 00 00 00 00 00 00 00 00 00 00 00 00 00
870 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
880 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
890 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8B0 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
8C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
900 39 39 39 39 49 49 49 49 59 59 59 59 69 69 69 69
910 0A 0A 0A 0A 18 18 18 18 57 57 57 57 26 26 26 26
920 52 52 52 52 62 62 62 62 03 03 03 03 03 03 03 03
930 33 33 33 33 02 02 02 02 31 31 31 31 30 30 30 30
940 55 77 DB 00 44 77 24 00 44 77 B6 00 55 77 6D 00
950 55 77 DB 00 55 77 DB 00 44 77 DB 00 55 77 24 00
960 77 00 00 00 75 00 00 00 70 00 00 00 71 00 00 00
970 71 00 00 00 72 00 00 00 72 00 00 00 7B 00 00 00
980 43 5B 5B 00 32 32 32 32 00 00 00 00 A5 6A 00 00
990 55 55 1C 1E 68 00 00 80 00 33 00 00 CC CC F1 00
9A0 10 0C 00 38 00 00 00 00 00 00 00 00 00 00 00 00
9B0 00 00 00 00 FF FE 01 00 FF FE 01 00 FF FE 01 00
9C0 FF FE 01 00 07 18 00 00 55 55 55 55 55 55 55 55
9D0 55 55 55 55 55 55 55 55 0F 72 00 00 00 3F 00 00
9E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9F0 FC 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A10 00 00 00 04 00 01 00 00 00 00 00 00 00 00 00 00
A20 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00
A30 18 06 00 44 00 00 00 00 00 00 00 00 00 00 00 00
A40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A50 00 00 01 00 00 00 00 00 00 00 00 00 90 01 00 00
A60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AB0 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00
AC0 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00
AD0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AE0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00
AF0 57 00 00 00 FA 00 00 00 AC 00 00 00 14 00 00 00
B00 00 00 00 00 00 00 89 00 00 00 00 00 00 00 00 00
B10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B20 00 00 00 00 00 00 00 00 89 00 00 00 00 00 00 00
B30 00 00 00 00 00 00 00 00 00 00 81 00 00 00 00 00
B40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B50 08 00 08 00 08 00 08 00 08 00 08 00 00 00 00 00
B60 10 00 00 00 00 00 00 00 00 00 00 44 44 00 00 00
B70 00 00 00 00 41 00 00 18 00 00 00 00 00 00 00 00
B80 00 01 02 03 04 05 06 07 08 09 0A 0C 0E 11 14 17
B90 1A 1E 22 26 2A 2E 32 36 3A 3C 3D 3E 3F 3F 3F 3F
BA0 00 01 02 03 04 05 06 07 08 09 0A 0C 0E 10 12 14
BB0 17 19 1B 1E 21 24 27 2A 2D 30 33 36 3A 3C 3E 3F
BC0 41 5F 41 5F 3F 5D 3F 3F 5D 3F 5D 00 00 00 00 00
BD0 17 14 10 0E 43 3B 00 00 17 14 17 14 17 14 17 14
BE0 1C 26 56 BF 00 00 00 00 00 00 00 00 00 00 00 00
BF0 00 00 00 00 FF FF 13 07 13 13 13 13 13 13 13 13
C00 32 20 01 00 FF FF FF FF 80 00 00 00 00 00 00 00
C10 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00
C20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C30 05 00 00 00 00 00 00 00 00 00 00 00 80 C1 00 00
C40 00 80 00 02 00 00 00 00 00 80 00 00 00 00 00 00
C50 05 03 03 05 FF FF 00 00 00 00 00 00 00 00 00 00
C60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C80 01 01 01 01 00 00 00 00 00 00 00 00 00 00 00 00
C90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CD0 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00
CE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CF0 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
D00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DD0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DF0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E00 00 00 00 00 00 00 00 00 42 00 00 00 C4 01 00 03
E10 00 32 22 00 00 00 00 00 00 00 00 00 00 00 00 00
E20 00 00 00 00 00 00 00 00 00 00 00 00 C0 6D A9 01
E30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E60 F0 0F 00 00 00 F0 00 00 0F 00 00 00 00 00 00 00
E70 00 00 00 00 00 00 10 00 20 F0 00 01 00 00 00 00
E80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ED0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EE0 00 00 00 00 00 00 00 00 00 00 B1 04 00 00 00 00
EF0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F00 3C 3B 3A 39 40 3F 3E 3D 3C 3B 3A 39 40 3F 3E 3D
F10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F20 FF FF FF 3F 00 00 00 00 00 00 00 00 00 00 00 00
F30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F40 00 00 00 00 00 00 00 00 E0 FF F0 FF 00 FF C0 FF
F50 00 F0 00 FC 00 80 00 C0 00 00 00 00 00 00 00 00
F60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF
F70 FF FF FF 0F FF 7F 00 00 00 00 00 00 00 00 00 00
F80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FA0 02 00 00 00 C2 00 91 21 00 D4 30 00 00 00 10 40
FB0 25 D0 00 10 42 C8 00 00 00 00 00 00 0F F0 00 00
FC0 80 40 13 80 44 22 E2 0F 00 00 00 00 00 00 00 00
FD0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FF0 00 00 00 00 00 00 00 00 00 00 E0 2F 00 00 00 00
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Kingston (7F98000000000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number
Serial number 480F4A43
Manufacturing date Week 33/Year 08n
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 4.0-4-4-12-16 @ 266 MHz
JEDEC #2 5.0-5-5-15-20 @ 333 MHz
JEDEC #3 6.0-6-6-18-24 @ 400 MHz
SPD registers
00 80 08 08 0E 0A 01 40 00 05 25 40 00 82 08 00 00
10 0C 08 70 01 02 00 03 30 45 3D 50 3C 1E 3C 2D 01
20 17 25 05 12 3C 1E 1E 00 06 3C 7F 80 14 1E 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 7D
40 7F 98 00 00 00 00 00 00 05 20 20 20 20 20 20 20
50 20 20 20 20 20 20 20 20 20 20 20 00 00 08 2D 48
60 0F 4A 43 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 39 39 50 35 34 32 39 2D 30 30 36 2E 41 30 31 4C
DIMM # 2
SMBus address 0x52
Memory type DDR2
Size 2048 MBytes
Part number
Serial number 6F0F8854
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
SPD registers
50 20 20 20 20 20 20 20 20 20 20 20 00 00 08 2D 6F
60 0F 88 54 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Mainboard Model MS-7519 (0x000001A3 - 0x005F2059)
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71882F
LPCIO Vendor ID 0x1934
LPCIO Chip ID 0x541
Config Mode I/O address 0x4E
Config Mode LDN 0x4
Config Mode registers
00 FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 05 41 20 19 34 00 00 10 40 00 44 60 08 08 00 00
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0A00
Hardware Monitors
Hardware monitor Fintek F71882F
Voltage 0 3.36 Volts [0xD2] (+3.3V)
Voltage 1 1.36 Volts [0xAA] (CPU VCORE)
Voltage 2 2.08 Volts [0x82] (VIN2)
Voltage 3 1.41 Volts [0x78] (VIN3)
Voltage 4 5.68 Volts [0x87] (+5V)
Voltage 5 9.77 Volts [0x6F] (+12V)
Voltage 6 1.47 Volts [0x5C] (VIN6)
Voltage 7 3.38 Volts [0xD3] (VSB3V)
Voltage 8 3.25 Volts [0xCB] (VBAT)
Temperature 0 35°C (94°F) [0x23] (TMPIN0)
Temperature 1 34°C (93°F) [0x22] (TMPIN1)
Fan 0 2825 RPM [0x213] (FANIN0)
Fan PWM 0 100 pc [0xFF] (CPU)
Fan PWM 1 60 pc [0x99] (System Fan 1)
Fan PWM 2 50 pc [0x80] (System Fan 2)
Fan PWM 3 50 pc [0x80] (System Fan 3)
00 FF 03 00 00 FF FF FF FF FF FF 00 00 55 4C 00 00
10 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
20 D3 9A 75 78 87 6F 5C D3 CB FF FF FF FF FF FF FF
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
60 00 00 00 00 FF FF 02 76 00 00 FF 0E 40 24 FF 08
70 FF FF 22 FF 22 FF 80 FF FF FF FF FF FF FF FF FF
80 FF FF 32 55 64 55 55 46 FF FF FF FF FF FF A8 FF
90 00 0E 0E 00 6A FF 57 FF 42 24 FF AA 55 55 FF 1A
A0 02 11 00 FF 02 0F 3C 32 28 1E FF E5 CE B7 A0 0D
B0 0F FF 00 99 03 FF 3C 32 28 1E FF D9 B2 99 80 0E
C0 0F FF 00 80 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
D0 0F FF 00 80 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 00 00 3B FF 00 29 FF 00 FF FF FF FF
Hardware monitor Intel ICH
Hardware monitor Intel Pentium E2220
Temperature 0 35°C (94°F) [0x32] (Core #0)
Temperature 1 37°C (98°F) [0x30] (Core #1)
PCI Device
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2E20
Revision ID 0x03
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Vendor Dependant
Caps offset 0xE0
PCI registers
00 86 80 20 2E 06 00 90 20 03 00 00 06 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 19 75
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 01 90 D1 FE 00 00 00 00 01 40 D1 FE 00 00 00 00
50 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
60 01 00 00 E0 00 00 00 00 01 80 D1 FE 00 00 00 00
90 10 11 11 00 00 33 33 00 40 00 4F 00 00 1A 38 00
A0 40 00 00 14 00 00 00 C0 00 00 00 C0 00 00 00 C0
B0 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 03 03 00 00 60 66 66 13 00 00 00 6E
E0 09 00 0C 91 20 45 B7 8C D2 CD 3F 82 00 00 00 00
F0 00 00 00 00 00 00 00 00 A6 0F 03 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2E21
Revision ID 0x03
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps class Subsystem Vendor
Caps offset 0x88
SubVendor ID 0x1462
SubSystem ID 0x7519
PCI capability
Caps class Power Management
Caps offset 0x80
Caps version 1.2
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x90
PCI capability
Caps class PCI Express
Caps offset 0xA0
Device type Root Port of PCI-E Root Complex
Port 2
Version 2.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
Extended capabilities
Caps class Virtual Channel
Caps offset 0x100
Caps class Root Complex Link Declaration
Caps offset 0x140
Link Entries # 1
Port Number 2
PCI registers
00 86 80 21 2E 07 01 10 00 03 00 04 06 08 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 C0 C0 00 20
20 A0 FE A0 FE 01 F0 F1 F7 00 00 00 00 00 00 00 00
30 00 00 00 00 88 00 00 00 00 00 00 00 10 01 1A 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
80 01 90 03 C8 08 00 00 00 0D 80 00 00 62 14 19 75
90 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 10 00 42 01 00 80 00 00 00 00 01 00 02 25 21 02
B0 40 00 01 51 80 25 00 00 00 00 48 00 00 00 00 00
D0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 01 00 03 41 3F 80 90 0F 03 00 00 F0 00 F0
100 02 00 01 14 00 00 00 00 00 00 00 00 00 00 00 00
110 01 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller (UHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A37
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000BC00
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 37 3A 05 00 90 02 00 00 03 0C 00 00 80 00
20 01 BC 00 00 00 00 00 00 00 00 00 00 62 14 19 75
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
50 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 2F 00 00 00 00 00 00 00 00 01 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00
Location bus 0 (0x00), device 26 (0x1A), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3A38
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000B880
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x15
Int. Pin 0x02
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 38 3A 05 00 90 02 00 00 03 0C 00 00 00 00
20 81 B8 00 00 00 00 00 00 00 00 00 00 62 14 19 75
30 00 00 00 00 50 00 00 00 00 00 00 00 15 02 00 00
Location bus 0 (0x00), device 26 (0x1A), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3A39
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000B800
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x13
Int. Pin 0x04
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 39 3A 05 00 90 02 00 00 03 0C 00 00 00 00
20 01 B8 00 00 00 00 00 00 00 00 00 00 62 14 19 75
30 00 00 00 00 50 00 00 00 00 00 00 00 13 04 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x3A3C
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE9FFC00
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x12
Int. Pin 0x03
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 3C 3A 06 00 90 02 00 20 03 0C 00 00 00 00
10 00 FC 9F FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 12 03 00 00
50 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
60 20 20 FF 01 00 00 00 00 01 00 00 00 00 20 00 C0
70 00 00 DF 0F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
D0 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 86 85 40 00 86 0F 00 00 0A 13 02 20
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A3E
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE9F8000
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x70
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
Caps offset 0x100
Caps offset 0x130
Link Entries # 1
Port Number 15
PCI registers
00 86 80 3E 3A 06 00 10 00 00 00 03 04 08 00 00 00
10 04 80 9F FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
40 01 00 00 07 07 00 00 00 00 00 00 00 00 00 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
C0 00 04 00 01 00 00 00 00 31 00 A3 02 00 00 00 00
D0 61 00 A3 02 00 00 00 00 00 00 00 00 00 00 00 00
100 02 00 01 13 01 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 80 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00
130 05 00 01 00 00 01 00 0F 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A40
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x40
Port 1
Version 1.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7519
PCI capability
Caps offset 0xA0
Caps version 1.1
Caps offset 0x100
Caps offset 0x180
Link Entries # 1
Port Number 1
PCI registers
00 86 80 40 3A 07 01 10 00 00 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 02 02 00 D0 D0 00 20
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 11 01 06 00
40 10 80 41 01 00 80 00 00 00 00 10 00 11 2C 11 01
50 40 00 11 30 60 05 00 00 00 00 48 01 00 00 00 00
80 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0D A0 00 00 62 14 19 75 00 00 00 00 00 00 00 00
A0 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 11 08 00 00 00 00
E0 00 00 C7 00 06 07 08 00 30 00 00 00 00 00 00 00
100 02 00 01 18 00 00 00 00 01 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3A42
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x10
Int. Pin 0x02
PCI capability
Caps offset 0x40
Port 2
Version 1.0
Physical slot #0
Presence detect no
Link width 0x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7519
PCI capability
Caps offset 0xA0
Caps version 1.1
Caps offset 0x100
Caps offset 0x180
Link Entries # 1
Port Number 2
PCI registers
00 86 80 42 3A 07 01 10 00 00 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 03 03 00 F0 00 00 20
30 00 00 00 00 40 00 00 00 00 00 00 00 10 02 06 00
40 10 80 41 01 00 80 00 00 00 00 10 00 11 2C 11 02
50 40 00 01 10 60 05 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x3A4A
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x10
Int. Pin 0x02
PCI capability
Caps offset 0x40
Port 6
Version 1.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1462
SubSystem ID 0x7519
PCI capability
Caps offset 0xA0
Caps version 1.1
Caps offset 0x100
Caps offset 0x180
Link Entries # 1
Port Number 6
PCI registers
00 86 80 4A 3A 07 01 10 00 00 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 04 04 00 E0 E0 00 20
20 B0 FE B0 FE F1 FD F1 FD 00 00 00 00 00 00 00 00
40 10 80 41 01 00 80 00 00 00 00 10 00 11 2C 11 06
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A34
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000B480
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 34 3A 05 00 90 02 00 00 03 0C 00 00 80 00
20 81 B4 00 00 00 00 00 00 00 00 00 00 62 14 19 75
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
Location bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3A35
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000B400
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 35 3A 05 00 90 02 00 00 03 0C 00 00 00 00
20 01 B4 00 00 00 00 00 00 00 00 00 00 62 14 19 75
30 00 00 00 00 50 00 00 00 00 00 00 00 13 02 00 00
Location bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3A36
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000B080
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x12
Int. Pin 0x03
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 36 3A 05 00 90 02 00 00 03 0C 00 00 00 00
20 81 B0 00 00 00 00 00 00 00 00 00 00 62 14 19 75
Location bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x3A3A
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE9FF800
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 3A 3A 06 00 90 02 00 20 03 0C 00 00 00 00
10 00 F8 9F FE 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 CF 0F 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0x90
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps offset 0x50
SubVendor ID 0x1462
SubSystem ID 0x7519
PCI registers
00 86 80 4E 24 07 01 10 00 90 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 05 05 20 F0 00 80 22
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 06 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
50 0D 00 00 00 62 14 19 75 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A18
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xE0
PCI registers
00 86 80 18 3A 07 00 10 02 00 00 01 06 00 00 80 00
40 01 08 00 00 80 00 00 00 81 04 00 00 10 00 00 00
60 8A 85 8E 8F D0 00 00 00 80 8B 83 86 F8 00 00 00
80 00 00 07 34 01 0A FC 00 01 0A 14 00 01 47 FC 00
A0 A0 06 00 00 09 02 01 00 13 1C 0A 24 00 03 00 40
B0 00 00 F0 00 00 00 00 00 00 00 00 08 00 00 00 00
D0 33 22 11 00 67 45 00 00 C0 C0 00 00 00 00 00 00
E0 09 00 0C 10 21 00 24 02 E4 02 00 00 00 00 00 00
F0 01 C0 D1 FE 00 00 00 00 86 0F 00 00 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3A20
Revision ID 0x00
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000B000
Address 1 (port) 0x0000AC00
Address 2 (port) 0x0000A880
Address 3 (port) 0x0000A800
Address 4 (port) 0x0000A480
Address 5 (port) 0x0000A400
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x13
Caps offset 0xB0
PCI registers
00 86 80 20 3A 07 00 B0 02 00 8F 01 01 00 00 00 00
10 01 B0 00 00 01 AC 00 00 81 A8 00 00 01 A8 00 00
20 81 A4 00 00 01 A4 00 00 00 00 00 00 62 14 19 75
30 00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
40 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
70 01 B0 03 00 08 00 00 00 00 00 00 00 00 00 00 00
80 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 0F 80 93 01 00 00 00 00 00 00 00 00 00 00
B0 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x3A30
Revision ID 0x00
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE9FF400
Address 4 (port) 0x00000400
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x0E
Int. Pin 0x03
PCI registers
00 86 80 30 3A 03 00 80 02 00 00 05 0C 00 00 00 00
10 04 F4 9F FE 00 00 00 00 00 00 00 00 00 00 00 00
20 01 04 00 00 00 00 00 00 00 00 00 00 62 14 19 75
30 00 00 00 00 00 00 00 00 00 00 00 00 0E 03 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x3A26
Revision ID 0x00
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000A000
Address 1 (port) 0x00009C00
Address 2 (port) 0x00009880
Address 3 (port) 0x00009800
Address 4 (port) 0x00009480
Address 5 (port) 0x00009400
Subvendor ID 0x1462
Subsystem ID 0x7519
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x13
Caps offset 0xB0
PCI registers
00 86 80 26 3A 07 00 B0 02 00 85 01 01 00 00 00 00
10 01 A0 00 00 01 9C 00 00 81 98 00 00 01 98 00 00
20 81 94 00 00 01 94 00 00 00 00 00 00 62 14 19 75
40 07 A3 00 80 00 00 00 00 01 00 01 00 00 00 00 00
50 00 00 00 00 30 10 00 00 00 00 00 00 00 00 00 00
90 00 00 03 01 00 00 00 00 00 00 00 00 00 00 00 00
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5B63
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF0000000
Address 1 (port) 0x0000C000
Address 2 (memory) 0xFEAF0000
Subvendor ID 0x1462
Subsystem ID 0x0964
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
Device type PCI-E Endpoint Device
Port 0
Version 1.0
PCI capability
Caps offset 0x80
Caps class Advanced Error Reporting
Caps offset 0x100
PCI registers
00 02 10 63 5B 07 00 10 00 00 00 00 03 08 00 80 00
10 08 00 00 F0 01 C0 00 00 00 00 AF FE 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 64 09
40 00 00 00 00 00 00 00 00 00 00 00 00 62 14 64 09
50 01 58 02 06 00 00 00 00 10 80 01 00 A0 04 2C 01
60 10 09 00 00 01 AD 00 00 40 00 01 11 00 00 00 00
80 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 00 00 00 00 00 00 00 00 00 11 20 06 00
110 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 04
120 0F 17 00 00 3C 00 07 01 DD 5F 3A AC 00 00 00 00
Description Display Controller
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x5B73
Revision ID 0x00
PI 0x00
SubClass 0x80
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEAE0000
Subvendor ID 0x1462
Subsystem ID 0x0965
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
Port 0
Version 1.0
PCI registers
00 02 10 73 5B 07 00 10 00 00 00 80 03 08 00 00 00
10 00 00 AE FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 65 09
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 00 00
50 01 58 02 06 00 00 00 00 10 00 01 00 80 04 00 00
60 00 00 00 00 01 AD 00 00 00 00 01 11 00 00 00 00
100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x197B
Model ID 0x2368
Revision ID 0x00
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000DC00
Address 1 (port) 0x0000D880
Address 2 (port) 0x0000D800
Address 3 (port) 0x0000D480
Address 4 (port) 0x0000D400
Subvendor ID 0x197B
Subsystem ID 0x2368
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x68
Caps version 1.1
PCI capability
Caps offset 0x50
Device type Legacy PCI-E Endpoint Device
Port 1
Version 1.0
PCI registers
00 7B 19 68 23 07 00 10 00 00 85 01 01 08 00 00 00
10 01 DC 00 00 81 D8 00 00 01 D8 00 00 81 D4 00 00
20 01 D4 00 00 00 00 00 00 00 00 00 00 7B 19 68 23
30 00 00 00 00 68 00 00 00 00 00 00 00 10 01 00 00
40 B1 00 C0 00 CC 08 80 E0 00 00 00 00 00 00 00 00
50 10 00 11 02 00 00 00 00 00 20 08 00 11 F4 03 01
60 00 00 11 10 00 00 00 00 01 50 02 00 00 00 00 00
80 00 00 00 00 A0 01 00 00 0F 00 00 00 00 00 00 00
B0 31 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00
C0 C3 8B 38 70 03 45 02 00 00 00 00 00 00 00 00 00
D0 18 00 00 80 00 00 00 10 00 00 EB 00 00 00 00 01
Description Ethernet Controller
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x02
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000E800
Address 2 (memory) 0xFDFFF000
Address 4 (memory) 0xFDFE0000
Subvendor ID 0x1462
Subsystem ID 0x519C
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Port 0
Version 1.0
PCI capability
Caps class MSI-X
Caps offset 0xB0
PCI capability
Caps class Virtual Product Data
Caps offset 0xD0
Caps offset 0x100
Caps offset 0x140
Caps class Device Serial Number
Caps offset 0x160
PCI registers
00 EC 10 68 81 07 00 10 00 02 00 00 02 08 00 00 00
10 01 E8 00 00 00 00 00 00 0C F0 FF FD 00 00 00 00
20 0C 00 FE FD 00 00 00 00 00 00 00 00 62 14 9C 51
30 00 00 00 00 40 00 00 00 00 00 00 00 11 01 00 00
40 01 50 C3 FF 08 00 00 00 00 00 00 00 00 00 00 00
50 05 70 82 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 B0 01 02 C1 86 28 00 10 50 19 00 11 3C 07 00
80 00 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
B0 11 D0 01 00 04 00 00 00 04 08 00 00 00 00 00 00
D0 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 14 00 00 00 00 00 00 00 00 30 20 06 00
110 01 20 00 00 00 20 00 00 A0 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version V1.3
date 06/27/2008
DMI System Information
manufacturer MICRO-STAR INTERNATIONAL CO.,LTD
product MS-7519
version 1.0
serial To Be Filled By O.E.M.
UUID 00000000-00000000-00000021-851C5BD9
DMI Baseboard
vendor MICRO-STAR INTERNATIONAL CO.,LTD
model MS-7519
revision 1.0
serial To be filled by O.E.M.
DMI System Enclosure
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Processor
manufacturer Intel
model Intel(R) Pentium(R) Dual CPU E2200 @ 2.20GHz
clock speed 2200.0 MHz
FSB speed 200.0 MHz
multiplier 11.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 4096 MBytes
DMI Memory Module
designation DIMM1
size 2048 MBytes (double bank)
DMI Memory Module
designation DIMM2
DMI Memory Module
designation DIMM3
DMI Memory Module
designation DIMM4
DMI Port Connector
designation J1A1 (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation J2A2 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation J4A1 (internal)
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation J2A1 (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation J6A1 (internal)
designation Audio Mic In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio Line In (external)
DMI Port Connector
designation J6B1 - AUX IN (internal)
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation J6B2 - CDIN (internal)
DMI Port Connector
designation J6J2 - PRI IDE (internal)
connector On Board IDE
DMI Port Connector
designation J6J1 - SEC IDE (internal)
DMI Port Connector
designation J4J1 - FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation J9H1 - FRONT PNL (internal)
connector 9 Pin Dual Inline (pin 10 cut)
DMI Port Connector
designation J1B1 - CHASSIS REAR FAN (internal)
DMI Port Connector
designation J2F1 - CPU FAN (internal)
DMI Port Connector
designation J8B4 - FRONT FAN (internal)
DMI Port Connector
designation J9G2 - FNT USB (internal)
DMI Port Connector
designation J6C3 - FP AUD (internal)
DMI Port Connector
designation J9G1 - CONFIG (internal)
DMI Port Connector
designation J8C1 - SCSI LED (internal)
DMI Port Connector
designation J9J2 - INTRUDER (internal)
DMI Port Connector
designation J9G4 - ITP (internal)
DMI Port Connector
designation J2H1 - MAIN POWER (internal)
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCIE1
type A5
width 32 bits
populated no
DMI Extension Slot
designation PCIE2
type A5
width 32 bits
populated no
DMI Extension Slot
designation PCIE3
type A5
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 4
DMI Memory Device
designation DIMM1
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM2
format DIMM
type unknown
DMI Memory Device
designation DIMM3
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM4
format DIMM
type unknown
Graphics
Number of adapters 2
Graphic APIs
API ATI OD5
API ATI I/O
Display Adapters
Display adapter 0
Manuf. API index 0
Display name \\.\DISPLAY1
Name Radeon X300/X550/X1050 Series
Memory size 128 MB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1462)
Model ID 0x5B63 (0x964)
Performance Level 0
Display adapter 1
Display name \\.\DISPLAY2
Name Radeon X300/X550/X1050 Series Secondary
Memory size 128 MB
PCI device bus 1 (0x1), device 0 (0x0), function 1 (0x1)
Model ID 0x5B73 (0x965)
Performance Level 0
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
...sorry mate, I am very busy in this time.
Could you try this version and tell me the result.
Thank you very much, my friend, it's working now (on one computer, I will try later on other)...
Sorry for taking Your time!
Kind regards!
EDIT: Thanks one more time, now it's working on my both computers! ;) You are the man! :)
Thanks very useful to me for my overclock soon lack the utilizare
cpu tweaker 1.3 b3 :up:
The memset 4.1 beta 4 not compatible to me ftw evga does not release me wrong error :(
http://www.pctunerup.com/up/results/...4_I5DEFAUL.JPG
4.557 Ghz / 217 fsb x 21 / Memos 2170 Mhz / CAS 9 - 9 - 9 - 26 / SPI 2MB 20.110 Seg
http://www.pctunerup.com/up/results/...0I54.56GHZ.JPG
Nice software and support.
