go go go go go go go go go go !!!!
Originally Posted by Cybertronic
Does the BIOS recovery come up?
Have you tried flashing it to an older BIOS?
If not fixable then I had a similar problem which had to be fixed by hotflashing :(
MAGIC !!!! After many differents way to solve this problems suggested from deiffernts forum of the planet I also tried yr suggest to flash with an older bios and..... ta da !! ASUS A8N32 SLI DELUXE !!!! GO GO GO GO !!!
Thank you very much really, thank you very much !!!.
Now I have small problem... everytime I power on there is a message saying "cmos checksum bad, press F1 to run setup or press F2 to load default values and continue", but this message it happen everytime I power on my system (pressing F1 no change, reboot and again same question, F2 go, load XP but next starting same message... ??) Any idea ? I tried to format my raptor having different driver from previous system (DFI NF4 SLI, Nvidia SLI - now for the beginnign just one vga, but soon 2nd).
Why this message ?
thank you again for yr help.
ciao
ANdrea
