Cooling doesn't matter. The most commonly argued theory is that voltage alone without the help of heat or frequency will break down the dielectric gates over time.Quote:
Originally Posted by LuckMan212
Also keep in mind that the DFI SLI-DR boards come up with 0.025 volts more than you set in the BIOS when the CPU is busy. I measured that on several instances yesterday, the effect is for real. Luckily my Infinity doesn't show any of that.
