you are the one that have to test it and tell us.... :p:
Charlie, from what i've seen, the X2s benefit more from IHS removal than Venices/SDs do. Maybe because the core is so big, there is a higher chance that part of it is making bad contact? Anyway, if your load temps exceed 50 with conventional cooling, chances are removing the IHS will help a significant amount.
im going to hazard a guess it's not, but that's based on a small theory of mine. Post your results here, and tell us how you do with it though.Quote:
Originally Posted by Smy
Just got my X2 4400+ 2 days back
Here's a screenie of it
@ Default Vcore + Stock Cool :D (Ambient @ 29c)
http://i2.photobucket.com/albums/y14/5ubz3r0/X22.jpg
don_vercetti :I am prime on 2.6ghz 1.4vcore 38c load now :banana:
I am hoping for 2.7ghz maybe 2.8ghz :D
Best i've been able to do thus far
http://img.photobucket.com/albums/v7...g/a5ce43db.jpg
Can almost get 2.9 Ghz stable but core0 fails
what is the stepping ?Quote:
where do you buy this x2 ?
Da*n, that's a WICKED good chip!!Quote:
C
I think any 3800+ would do that. Mine one included. :)
Is there a definitive way to tell this by CPU markings or software?Quote:
Originally Posted by don_vercetti
My chip is a week 26upbw from Fry's. I made a thread with all my results about a week ago but it sunk down pretty quickly.
I was able to do this, but core0 failed
http://img.photobucket.com/albums/v7...g/7fe9cf82.jpg
wow dood I wish mine will be able to do that when I can throw some volts at her, im currently on a 3800 doin 2.5 default volts so im guessin this shouldnt be a problem with me, and if I decide to go top down i think i might be in 3ghz mark :)
3 Ghz on air? Good luck buddy!
Here's 2.7 Ghz with 1.39 volts
http://img.photobucket.com/albums/v7...g/c4cc88f0.jpg
sorry but your SP is not set uo correctly...
yeah i know it isn't set up perfectly. My first stop with the overclock was 2.65 Ghz! And from there it was a 1/2 hour test at each frequency until i maxed it out. So 2.65, 2.70, 2.75, 2.80, 2.83 (took a detour here), 2.85, etc. So many of my earlier tests have no affinity checked. I can try to re-run them over teh weekend...
my X2 OC's a lot better with 1GB of ram compared to 2gb of ram... I mean higher mHz, not higher memory speed!!!
A little MUSHKIN REDLINE action :D
http://www.xtremesystems.org/forums/...chmentid=38522
default hs/f...25C ambient 1.61v
My ram timings blow, this one came out to 29.89
http://img.photobucket.com/albums/v7...g/caa09f8d.jpg
That'd be 27s if you had some BH5/UTT to run at 268, 2-2-2...Quote:
C
my new 24/7 overclock. New mobo helps ALOT. Also since its laid out much better im getting much better temps. My daily Vcore now is down to 1.40 solid instead of 1.44 with fluctuations.
http://i6.photobucket.com/albums/y24...IOverclock.jpg
What mobo did you have beforehand?
I got a few questions for you guys here, I dont know about steppings and all and mine seems wierd to me, Heres a linky
Steppings
It does 2.5 with 1.35 So a 500 mhx overclock at no vilt increase seems good to me but does anyone here know if these steppings are wierd or what? I mean the ccwbe part rest seems ok
I have a CCBWE 0529SPMW that does 2.5 GHz at 1.31V so far testing now. Prime stable for 24 hours with two instances.Quote:
Originally Posted by Philosophy
Sweet
What mobo is that on?
My mobo psu overvolts like :banana::banana::banana::banana: because of the rail mods I did which isnt really a bad thing I guess, but Im doin 2.5 with 1.35 setting
Whered u get urs from?
Monarch here and got a free bet on soldier 64bit game with it
Mines also a toledo core whats urs?
These 3800 seem to really overclock well. Almost makes me want to ditch the 4400 and try one of these. AlmostQuote:
i switched from a MSI K8N Neo 2 Platinum to my new DFI UT NF4 Ultra-D.
