Because I ordered a phasechangeQuote:
wow i liked that case! nice
Had fun. Didn't bring temps down much at idle but made a hugh difference under load. Now I can play FarCry at the Very High video settings available and the card temp never goes over 42c, where as before the settings were at High and I would hit over 70c. I'm gonna replace all the worm drive clamps with the same black plastic reusable ones that came with the water blocks, they are pretty sturdy. Very pleased with the performance of my choice of components: CPU WB - Swiftech Storm, GPU WB Swift MCW60, Pump-Swiftech MCP 655, Radiator-Thermochill PA120.3 w Panaflo U1 Ultra Performance fans x 3.
Benchmarks so far:
Item Idle Load
CPU 40c 49c Prime95
GPU 35c 42c FarCry
Man that's BIG! :eek2:
i think u need to update ur sig vexvegas
lol oops..done
My newest project
Sry but I dont want to post all pics twice
Nice:clap:
My Liquid cooled LinaLI PC70 :wave:
dark:
http://img54.imageshack.us/img54/3179/case19ju.jpg
light:
http://img87.imageshack.us/img87/9777/case22ie.jpg
front:
http://img87.imageshack.us/img87/4029/case33or.jpg
whats the point in having two floppy drives??
Maybe he's raiding them :hrhr: :hrhr:
-k0nsl
Originally Posted by ludeboy12
one is in the ass and i´m too lacy to change it :D
by night...
http://www.2wire.ch/ripping/bg/water...x/PICT0116.jpg
http://www.2wire.ch/ripping/bg/water...x/PICT0124.jpg
http://www.2wire.ch/ripping/bg/water...x/PICT0130.jpg
http://www.2wire.ch/ripping/bg/water...x/PICT0192.jpg
for a hot summer... but realy loud and uncool....
http://www.2wire.ch/ripping/bg/water...ool2_klein.jpg
new idea! openair with 3x120mm YS-Tech Fans @ 4000rpm
http://octs.ripping.org/nexxxos1.jpg
http://octs.ripping.org/radi-montage2.jpg
http://octs.ripping.org/radi-openair_klein.jpg
realy cool...
http://octs.ripping.org/wassertemp15.3.jpg
lol @ the reserator!
edit: if you take a tube that the reserator just fit in, and put a sanyo denki 120x38mm fan on topp sucking air trough the reserator. that would cool it enough!
still loud but very effective, and much simplier!
ROFL (no offence)
you covered that reserator like no other ...
that triple radiator cleaned things up a lot. might want to shorten the tubing though. its just killer your flow even more
My cruddy mid-tower case with air cooling
http://img.photobucket.com/albums/v6...e/P5120842.jpg
Swiftech Storm Rev 2 Cpu Block
http://img.photobucket.com/albums/v6...e/P5170875.jpg
Maze 4 Gpu Block
http://img.photobucket.com/albums/v6...e/P5170879.jpg
Maze 4 after being cleaned with ketchup
http://img.photobucket.com/albums/v6...e/P5210904.jpg
Storm after being cleaned with ketchup
http://img.photobucket.com/albums/v6...e/P5210919.jpg
Can these really win the battle against heat?...ofcourse !
http://img.photobucket.com/albums/v6...e/P5160861.jpg
My Trip Radiator..not exactly straight...dont even know how it got that way O_o
http://img.photobucket.com/albums/v6...e/P5290944.jpg
Additional Comment:
Case w/ water
http://img.photobucket.com/albums/v6...e/P5290942.jpg
Case w/ uv cathodes
http://img.photobucket.com/albums/v6...e/P5290941.jpg
I also hit this little problem which caused for me to wait another week to set everything up...
http://img.photobucket.com/albums/v6...e/P5270938.jpg
/Cpu/ Intel P4 3.06 @ 3.7
/Mobo/ Abit IC7-G
/Gpu/ Sapphire x800 Pro 475/450(900) @ 571/613(1226)
/Ram/ Corsair XMS 2gb's ddr400 2-3-3-6
Cooled via:
/Radiator/ BIPIII
/Cpu/ Swiftech Storm Rev 2
/Gpu/ Danger Den Maze 4 Low-Profile Acetal
/Pump/ Danger Den D-5
Ouch, that barb!! :(
You're very lucky you could get the threaded part out.
How did that happen?
It would seem I have a problem with over tightening things O_o
Seems like... :)
The Storm is just awesome. Very sad that it is impossible to get in europe.
Plenty possible, order from over-clock.com in the UK.
Thanks a lot creidiki !
I´m going to order it soon.
Well I finally got around to taking some pics of the new "RiG". First water setup I've done. Performs pretty good so far. All black drives. Custom 80mm blowhole and fillport, I wish I would have got some better photos of the two and the custom MaXThReAT LED name plate. Two black lights on the bottom, they heat up the case more than I thought. I keep en off unless I'm showing off.
http://img.photobucket.com/albums/v6...T/DSC00687.jpg
http://img.photobucket.com/albums/v6...T/DSC00688.jpg
http://img.photobucket.com/albums/v6...T/DSC00691.jpg
http://img.photobucket.com/albums/v6...T/DSC00693.jpg
http://img.photobucket.com/albums/v6...T/DSC00694.jpg
http://img.photobucket.com/albums/v6...EaT/case01.jpg
http://img.photobucket.com/albums/v6...T/blowhole.jpg
http://img.photobucket.com/albums/v6...Picture003.jpg
And my old setup R.I.P. She served well.
http://img.photobucket.com/albums/v6...T/DSCN4415.jpg
